Question about Logitech DRIVING FORCE FEEDBACK STEERING WHEEL W/PEDALS USB FOR PS2 (VGITECHWHEELPEDALSUSBPS2)
Just over 2 Years old DRIVING FORCE PRO
Steering wheel won't calibrate(turn left and right) when starting a game(For example Gt4). DFP can be found on my computer...but that's all..Can't calibrate,press buttons..well actually can't do anything at all. Pedals doesn't work either . All I get is those two blinking lights. I checked adapter and that works. All wires are ok too(well at least my electric-meter gave some values so they are more or less ok I think).
Now I'm out of ideas.
DFB was out of use for few months...thats all it takes to get it xxxxx I guess...
  • manny1222 Sep 25, 2008
    I have the same problem. Worked fine until a month ago. Mine's three years old. Called logitech today, and couldn't recalibrate after doing all they told me to. Warranty was only for two years. They said I could get a new one for half the cost of new.
5 Suggested Answers
SOURCE: G25 Wheel No Longer Responsive
I have this problem and i emailed logitech, they told me to send the wheel back to the dealer for a replacement :(
Posted on Sep 19, 2007
SOURCE: Re: Logitech GT Force Wheel
I know this sounds stupid, but mine did the same thing until I remembered that it also has a power supply that has to be plugged into an outlet. I had simply connected the USB cable and got the green light on the top left hand side but it wouldn't respond otherwise. Sorry if you already have this checked but it solved the problem for me.
Posted on Feb 16, 2008
  • 4 Answers
SOURCE: Logitech Momo Force Feedback - out of center
are you shure you have installed the driver for the steering weel i have the same steering weel and it works fine
Posted on Feb 17, 2009
SOURCE: logitech Driving Force GT wheel won't work at all
Ive had this problem yesterday. Confirmed.
Call them to have words. Have respect and they refund you full.
Towards the G25.
I did that. Cause if I broke 1 DFGT then I will break more.
I think that the G25 withstands even drifters technique.
See you on PS3 Tag: DriftMagnet
Logitech Tech Support. Call 1-646-454-3200
Posted on Jul 01, 2009
  • 118 Answers
SOURCE: I have a LOgitech Formula Vibration Feedback
make sure you have the latest service pack if vista can see the controller in the control panel>gamecontrollers>properties and it tests fine then it is not the wheel. it just the game
turn off your antivirus temporarily and start the game again.if it still does not work in the games you mentioned look for patches on the games web sights.
Posted on Jul 21, 2009
How to connect logitech g27 paddles to ps3
Plug the device into your console.
In a racing game, Go to options, Logitech Racing Wheels, Steering Settings. Steering type=simulation. Power-Assisted Steering=Off. Force Feedback is up to you (I use 8).
Then, exit Steering Settings and scroll right. The G25 is not listed in the options menu. Use the DFP to map the controls. Paddle shifters are L1 and R1. Buttons on wheel are L2 and R2. D-pad is same as DS3, as are the four black buttons above it. The four red buttons are (from left to right), L3, Select, Start, R3. The forward/back on the sequential shifter can also be mapped if you choose to do so. Hope this helps.
Dec 24, 2011 | Logitech G27 Racing Wheel
I have a Logitech Driving Force Force Feedback wheel for the PS2 (USB connection) and wondered if this will work on the PS3 and more specifically on the new Gran Turismo 5. I use the wheel on the PS2 for...
Hey man,
I have the exact same wheel, and it works... BUT the forcefeedback doesn't do anything!
Hopefully they will come out with an update to support this... argh
Dave
Dec 08, 2010 | Logitech DRIVING FORCE FEEDBACK STEERING...
Hi...I just bought the Logitech Driving Force GT steering wheel and pedals...the pedals work fine, the buttons ON the steering wheel work fine...but the actual steering part DOES NOT work..so I can...
-Check if the connections are plugged in properly -Does the wheel calibrate (turn left and right and then centres) when you turn on the wheel. -Doe the game support the wheel? - Plug the DFGT into the USB port 1 of the console AFTER you turn on the console. So turn on the console and then plug in the DFGT into the USB port 1 and turn it on.
ALSO if you are using the DFGT for pc, make sure you install the "Logitech Gaming Software" from the logitech website =
Sep 25, 2010 | Logitech Driving Force GT Wheel for...
When I plug in the wheel to my PS3 and put the adapter into the wall the wheel calibrates and works but when I plug the wheel into my PS2 nothing happens! I've even left it plugged into my PS2 for an hour...
frkzila2, did you ever find a solution to this? I bought this for my son a few years ago and he NEVER used it... now he's in his teens and tried using it but it doesn't work... left light blinks, right light is solid, wheel moved slightly when initially plugged in, but no power what-so-ever to the pedals??? did you ever fix yours?
Oct 04, 2009 | Logitech Driving Force Pro Steering Wheel...
Driving Force Pro wheel resets randomly
Mattyb21, did you ever fix yours? My son is having the same problem and i'm about ready to give up on this wheel!
Sep 27, 2009 | Logitech Driving Force Pro Steering Wheel...
Driving force pro wont work on my ps3
The correct voltage output on the power supply is 24 volts and .75 amps. Center positive outside sleeve negative. Hope this helps.
Mar 09, 2009 | Logitech DRIVING FORCE FEEDBACK STEERING...
Steering backwards
Maybe it got calibrated backwards, so know the wheel guesses that right is left and left is right... you might need to look at the CONTROL PANEL / GAME CONTROLLERS to find a way to calibrate it right...
Jan 03, 2009 | Guillemot NASCAR Pro Digital Wheel And...
Driving force pro steering wheel
A solution from Youtube comments:
"if u realy want this wheel to work u need to open it up, and there is a rail u can move foward to lock the wheel into 180, then fire up your pc ps3 or game and let it calibrate. and it will stay in 180 (left led on)then after it has done that push the rail backwards for 900 (both leds on). and its all good, the rail is white plastic and is under the big metal bar. u cant miss it.
ive cut a hole in mine at the top so i can move the rail whenever :)"
Aug 03, 2008 | Logitech DRIVING FORCE FEEDBACK STEERING...
STEERING WHEEL DOESNT WORK
Find the controller setting within the Game as there is a few settings for wheels. Find the setting that suits your wheel configuation and set it. Should be go to go.
Apr 20, 2008 | Logitech DRIVING FORCE FEEDBACK STEERING...
Logitech DRIVING FORCE FEEDBACK STEERING WHEEL W/PEDALS USB FOR PS2 (VGITECHWHEELPEDALSUSBPS2) Logo
258 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Rob boss
Level 1 Expert
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
