My Brother printer MFC_210C model shows on LCD screen "Unable to print" have followed instrs and LCD screen shows "Machine error 41" with 4 green status buttons, below LCD screen, flashing green continuously. What do I do now to fix the problem?
  • 19,396 Answers
First reset the printer by unplugging from power cable, and see if the problem persists on startup.
Posted on Apr 03, 2008
  • Ginko
    Ginko Apr 03, 2008
    If the reset did not work then you may have a problem with the printer head, infact error 41on MFC printers means: printhead defective. needs replacement (there is no toner in your printer ).
    Master:
  • 555 Answers
Have you recently changed the toner is this printer?
  • Matt Jurach
    Matt Jurach Apr 03, 2008
    In Brother printers, the infamous "Error 41" indicates that the printhead has failed. This is a permanent error that isn't normally user-servicable.
    Some users report that cleaning the printhead will sometimes clear the error for a certain period of time.
    Contacting Brother support
    and complaining will sometimes get a result as well, especially if the printer is fairly new. This problem has frustrated lots of their users, and by now they are sensitive to customer backlash.
"UNABLE TO PRINT 50" appears
Error: -------- Unable to Print XX
Problem: ------------ The machine has a mechanical problem. -OR- A foreign objects such as a clip or ripped paper is in the machine.
Solution: ------------- Open the scanner cover and remove any foreign objects inside the machine. If the error message continues, do one of the following: ?? (MFC-440CN only) See Transferring your faxes or Fax Journal report on page 139 before disconnecting the machine so you will not lose any important messages. Then, disconnect the machine from the power for several minutes and then reconnect it. ??
May 22, 2011 | Brother MultiFunction Center MFC-440CN...
I'm getting the error message Unable to print. check user guide on my brother mfc 210C all in one printer. I don't have my user guide. Please help. Tiare'
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41,49 or 4F the print head is defective.If the error is 48 -defective print head cable or circuit board.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the annoying cannot clean message.
Nov 17, 2009 | Brother MFC 210C All-In-One InkJet Printer
Unable to clean,check manual
LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the error is 50 or
Oct 25, 2009 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C Machine error 41
Error 41 refers to the printheads which is a common problem with Brother machines. The printheads will need to be replaced. On some machines, Brother has extended the warranty to cover printheads because of the excessive failure rate. Contact Brother to see if you qualify and they may send you new printheads along with easy instructions to replace them. Also please rate this solution with a fixya rating. Thanks!
Dec 27, 2008 | Brother MFC 210C All-In-One InkJet Printer
[HELP] MY BROTHER MF-210C "UNABLE TO INIT"
Dear Guru,
I have a same problem" UNABLE TO INIT " but my printer DCP 110.
Please can help me.Thanks
Sep 19, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C
I am unable to clean and ended up with these notice (unable to print see troubleshoot in user's guide book).pls send the solution to the e-mail address provided.
Apr 03, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother Machine Code 41
error 41: ph is defective and needs replacement.
Mar 18, 2008 | Brother MFC 210C All-In-One InkJet Printer
Unable to print
press menu then start mono (blue button) then fourtimes arrow up (tel-index). Machine will be in maintenance mode and lights will flash. What error code does the machine display?
(to leave the maintenance mode press 9 then 9)
Nov 26, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother mfc-215c unable to clean?
I have the same problem my printer (a MFC-215C) is unable to clean and when I press Menu/set I do not have "Black print"? So what do I do now?????? HELP... Thanks Nathalie
Nov 09, 2007 | Brother MFC 420CN All-In-One InkJet...
MFC-210C displaying "Unable to Print"
press menu then start mono (b/w) then 4x arrow-up-button. What error code does the machine display?
Sep 24, 2007 | Brother MFC 210C All-In-One InkJet Printer
51 people viewed this question
jasbo
jasbo
