Question about LG LRSC-26922 Side by Side Refrigerator
Dispenses Small Particles in Water
My LRSC-21935 is about 18 months old and I change water filters every six months.  Lately, the family noticed tiny semitransparent  "floaters" in the water and won't drink it - a major marital crisis is in progress!  Only found one article on the web that suggests some unknown bacterial/algae growth in the water tank or lines.  How do I flush/clean the system or disassemble the door to get at the offending components?
  • 3,037 Answers
I would try cleaning all of the hoses and components with a little bleach and water, and just run the mixture through a few times and then continually run clean water through the system to rinse it and anything that may be flaking off should hopefully be removed if the problem is coming from the refrigerator itself, which I believe is your problem since the filter should be stopping the particles so most likely something is flaking off of the water reservoir or a hose in your fridge which if the cleaning doesn't fixed, can get replaced and that should solve your problem.
Let me know how this goes and good luck.
Posted on Apr 03, 2008
    Genius:
  • 3,422 Answers
Click HERE to download the service manual.This will guide you to disassemble the door.
Goodluck,
Please don't forget to rate the solution
  • Priya darshan Apr 03, 2008
    You can also check THIS out for some solutions to your problem.
    Click HERE
    You need to have
    adobe acrobat reader to view the manual in pdf format.
    Click here
    to download it if you don't have.
Where is the water filter what is the part number and how do you change it
Hello Dwane;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number of your unit. The water filter location is dependent on the model number. The model number is located on a label on the inside of the fresh food section liner.
You have a bottom freezer. In general the water filter is located in the upper right hand corner of you right side fresh food section.
You may have a screw on the side panel to remove the cover, or some retainer clips, of which you must squeeze the cover housing to remove, or you may have free access.
Once locating, or accessing the water filter, grab the base and turn 1/4 turn clockwise to release and pull down. Insert the new water filter, insert and turn counter wise to the right.
Purge the air out of the filter system. Water filters are dry and have air in them. With your water dispenser fill several cups until al of the air is purged out. There will spiriting sounds.
You replace your water filter when you notice your ice cubes are small & when the water flow from your dispenser is low. The change water indicator light is a timer. It is set to cycle every six months. It is like a egg timer. It is not connected to anything.
Depending on the size of your family, and the usage you may need to change the water filter every six months or every 1-1/2- 2 years.
Nov 08, 2014 | Refrigerators
Im at the six month point, red light flashing, which of the filters do i replace and do i need to sanitize the storage tank?
The filters that you should replace every the six months are the two pre/post filters (FQROPF). The membrane (FQROMF) needs to be replaced every 1 to 2 years. During the filter change, bacteria could be introduced, so it is recommended that you sanitize the tank while changing the filters. Here are the filters you need to replace:
http://www.freshwatersystems.com/p-7787-ge-profile-fqropf-smartwater-ro-pre-and-post-filter-set.aspx
Apr 09, 2013 | General Electric Profile Smartwater Ultra...
I have a side-by-side ref. It use external filter. I notice that water out of filter (before going into ref) is clear but when I collect water from water dispenser of my ref is cloudy and some very tiny...
was the outside filter factory? by this I mean does the unit have an internal filter ? if no, then you need to flush the system, clean the outside dispenser components, lime or rust has accumulated on the dispenser if the water from the outgoing side of the filter is clear ( is the ice clear and fed by this same water source? if so,, its just outside build up that needs to be cleaned
Jul 03, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Water and ice taste bad
How long has it been since you replaced the filter in the waterline, or in the refrigerator section waterline? This filter is to be replaced usually every six months. This filter is usually a canister about the size of a car oil filter and is usually located in the upper right side of the fridge. May be hidden by a plastic shield over the light. Replacing this filter should eliminate your problem. Remember to read the instructions that come with the new filter as to filling it with water before installing or not and the purge time or amount before using it for drinking, to flush any particulate out of the new filter. Usually 60 seconds of running water from door in to a glass and dumping that water...or run water into a glass til it dispenses clear water. Remember to turn off the water to the fridge and have a towel handy when replacing the filter. Some refrigerators have a function where by when you unscrew the old filter it automatically shuts off the water, but I would not trust that to actually work...Ha!
Jan 21, 2011 | Kenmore 53642 / 53644 Side by Side...
My Keurig dispenses about 3oz of water on next to largest setting
I JUST fixed (I Hope!) my 11 month old B60 by taking a paper clip and a straightened safety pin to the top of the coffee maker (where the top pin punctures the top of the cup) and the BOTTOM pin which punctures the bottom of the cup. (remove the bottom dark brown holder by pushing up on it).
After one or two attempts, I ran water through it without the coffee cup, then used a decaf cup and brewed it just fine....
Aug 25, 2009 | Keurig Platinum B70 Coffee Maker
Water dispenser dispenses particles into the water. Drained about 7 pitchers of water. Particles are smaller but still coming. Restaurant water looks better than this. What's happening and what can I do?...
first; turn the water of to the machine next, remove the water line in front of the filter using a large bowl place the loose hose into the bowl and turn the water on for a minute turn the water off and, check the bowl for particles then reattach the filter and do the same thing on the other side of the refrigerator if this water is clean the interior refrigerator filter must be checked usually it is the carbon filter inside the refrigerator that is bad you can find the drawings location and, procedure for this part at: searsparts.com
Apr 25, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Dirty pieces of ''onionskin'' in water after changing water filt
Same problem in my 1 year old Maytag side-by-side. I let the stuff it sit in a cup for about 5-7 days, and it turned into a fuzzy mess of mold. Obviously a problem. However, Maytag WILL NOT admit a problem. Home Depot would not override Maytag's decisions. They did arrange for an appliance repair company to replace internal tubes, but after about a month of drinking it again, (WITH A NEW $35 FILTER) I found lots of new MOLD last night. Filled a pitcher a couple of times to find six "onion-like" pieces. This has been an ordeal of about 9 months. My family has had unusual illness (colds, flus, stomach problems) for the past 9 months. I am about to take it to the city dump.
Mar 21, 2009 | Refrigerators
Dirty water line from filter
Attach flexable rubber line from water bottle, like is used for race bicycle riders,or tape up a hose to a water bottle. Turn off valve at water pipe leadign to line to filter. Remove filter. place a pan to catch water under the machine. Attach A small diameter hose to water line where water exits to glass.With machine turned on and your rubber hose attached turn bottle upside down and squeeze while pressign glass lever. Flush through approximate one quare or until water stream is clear. Their is no pumb ofor flow the line preaure is al that moves the water so backflushing is easy.
Dec 14, 2008 | Frigidaire FRS26R4A Side by Side...
Particles floating in whirlpool filtered water.
okay - we have had this same problem for around 6 weeks - We called a service repairman to come out and he said that these "floaties" are harmless bacteria. We should disconnect the filter and flush the system by using 1 gallon of water a day (wasting it) after the chlorine in the water is allowed to build up again then the "floaties"- bacteria- will go away---- gross :-( We will see if it works---
Oct 16, 2007 | Refrigerators
LG LRSC-26922 Side by Side Refrigerator Logo
312 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
