Ihave a HP Pavilion ze4500 laptop , and when turned on it lights up the fan runs for a few seconds then all goes dead
    Sergeant:
  • 349 Answers
Laptop does not post: (then it is a hardware problem)
· try the following first.check battery is seated correctly and that the power pack is functioning,
· if the battery has gone flat and the power pack is not working ,the laptop will not start.
· Remove any hardware you may have installed prior to you having the problem.
· remove the screw(s) holding the cover plate on the back of the laptop where the ram lives and remove the memory sticks,
· clean the gold edges both sides, with rubbing alcohol or a pencil eraser, and re-insert them, (not an ink eraser as it will do damage)
· swap them around if you have more than one,
· try one at a time.
· if you only have one, borrow one from a friend or try the ram in your friends laptop ,if that's possible, or
· get a friend or family member to download a "memory chip diagnostic's" program such as memcheck 1.70 and boot up of it ,it will check your ram ,if not
· take the ram to your local pc shop and ask them to check it for you (they may do that for you)
· if you can establish that the ram and power pack is ok,
· it may be that the motherboard or the cpu is failing
· Generally a dead hard drive would not stop the laptop from posting.
good luck with that and let me know how you get on
please rate my efforts
Terry
Posted on Apr 04, 2008
SOURCE:
My hp Pavilion dv6000 keeps restarting each time and the screen is left blank all the time. I don't hear any sounds either to detect any hw failure. It's reseting each 13-15 seconds after turning on so I'm...
dv6000, NO OS stated, whY? XP?
for now we get bios going first, damn the OS.
first take the old shorted main battery out,
run on AC only. run now? fan must blow first does it?
also the CCLF go dead, at 20k hours used. black screens for ever now. CCLF is dead LCD backlamps. but fan dead is other issue.
the COin cell goes bad now, ever replace that?
HP RTC coin cell battery , tiny, a $2 fix.
they dont last for 11 years, sorry.
power button dead?
fan dead,?
screen dead. (never ever shows text)???
hdd does not spin making normal noise?
cd eject button dead.?
no beeps?
no caps lock blink codes.?
the AC pack is dead if the PC is %100 dead on AC most times
I can show you 10 to 20 more things inside that can do that.
takes a full dismantle to fix some,
My guess a shop repair is not in the cards?
Jan 06, 2018 | HP Pavilion dv6000t Notebook
HP Pavilion DV6700 won't boot
Possibly overheating? As you say that when you press and of the F-Key option nothing is happening, and also the fan is running at full power, if the fan is louder than usual, then it could be overheating in the air vents which you can find either at the sides, back, front and underneath the laptop, try getting the compressed air, and giving the air vents a blast to get all dust out. Or a vacuum. Do it whilst laptop is turned off though!
Jan 26, 2010 | HP Computers & Internet
When I try to power up the machine, the green power switch blinks a few times and the fan runs for a few seconds then it goes dead.
Start here, then see also here, here and here for help troubleshooting this error.
Your home support page here.
A generic startup troubleshooter here.
Good luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 29, 2009 | HP Pavilion N5150 Notebook
Hp Pavilion Dv600 Wont start up!!!
it looks like your mainboard is cutting the power. and need to get servvice.
May 29, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
My laptop is not turnnig-on!
Try removing the battery and running from the AC power supply only. If this works, your battery probably can no longer hold a charge and the battery will need to be replaced.
Removing the battery allows the power supply to power your laptop rather than trying to charge a dead battery
May 17, 2009 | HP Pavilion dv2214us Notebook
Hp pavillion ze4500 fan running continuously
weel its seems ur laptop is Clogged with Dust .the reason the Fan is Spinning fast is because parts r getting Heatedup.as a matter of fact wht u can do is |if ur r a pro open up ur laptop and clean the heatsink.that should take care of it.
May 10, 2009 | Gateway 5200S PC Desktop
Hp ze4500 laptop wont turn on
HAVE TRIED FOR CHARGING. THE BATTERY MAY BE DEAD.
Mar 12, 2009 | HP Audio Players & Recorders
I need modem pci and compatible vga hp pavilion ze4500
can I use a 2 wire Router with a SB5101 modem?
Nov 18, 2008 | Computers & Internet
HP Pavilion N5470 problem (can use the Omni X3 mainboard)
press f11 or f10 when your laptop first turns on and maybe u can reset it
Sep 16, 2008 | HP OmniBook XE3 Notebook
Open Questions:
ZONEALARM toll free phone +$&{[email protected]*1O69} NuMbEr USA .Anita This ZONEALARM USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 ZONEALARM USA techs tried our tools and information and gave us feedback after they called. The reason techs call # I:8OO:,:8O31069 is to reach the ZONEALARM USA toll free department for problems like Where to buy, Complaint, toll free, Repairs, Returns. As far as we can tell, ZONEALARM USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. ZONEALARM USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I8OO8O31O69 and ways to call or contact ZONEALARM USA with help from techs like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling ZONEALARM USA Calling ZONEALARM USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from ZONEALARM USA toll free can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with ZONEALARM USA's toll free department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare ZONEALARM USA's phone numbers against each other. Contacting ZONEALARM USA in General While I8OO8O31O69 is ZONEALARM USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I8OO8O31O69 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach ZONEALARM USA help by calling them, is that other techs give their toll free at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact ZONEALARM USA.Anita
Oct 17, 2019 | Best Computers & Internet
MCAFEE toll free phone +$&{[email protected]*1O69} NuMbEr USA This MCAFEE USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 MCAFEE USA techs tried our tools and information and gave us feedback after they called. The reason techs call # I:8OO:,:8O31069 is to reach the MCAFEE USA toll free department for problems like Where to buy, Complaint, toll free, Repairs, Returns. As far as we can tell, MCAFEE USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. MCAFEE USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I8OO8O31O69 and ways to call or contact MCAFEE USA with help from techs like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling MCAFEE USA Calling MCAFEE USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from MCAFEE USA toll free can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with MCAFEE USA's toll free department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare MCAFEE USA's phone numbers against each other. Contacting MCAFEE USA in General While I8OO8O31O69 is MCAFEE USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I8OO8O31O69 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach MCAFEE USA help by calling them, is that other techs give their toll free at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact MCAFEE USA.Anita
Oct 17, 2019 | Mcafee Computers & Internet
BITDEFENDER toll free phone +$&{[email protected]*1O69} NuMbEr USA This BITDEFENDER USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 BITDEFENDER USA techs tried our tools and information and gave us feedback after they called. The reason techs call # I:8OO:,:8O31069 is to reach the BITDEFENDER USA toll free department for problems like Where to buy, Complaint, toll free, Repairs, Returns. As far as we can tell, BITDEFENDER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. BITDEFENDER USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I8OO8O31O69 and ways to call or contact BITDEFENDER USA with help from techs like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling BITDEFENDER USA Calling BITDEFENDER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from BITDEFENDER USA toll free can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with BITDEFENDER USA's toll free department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare BITDEFENDER USA's phone numbers against each other. Contacting BITDEFENDER USA in General While I8OO8O31O69 is BITDEFENDER USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I8OO8O31O69 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach BITDEFENDER USA help by calling them, is that other techs give their toll free at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact BITDEFENDER USA.Anita
Oct 17, 2019 | BitDefender Computers & Internet
CHARTER helpline phone {&$&{[email protected]*1O69} NuMbEr USA AsIf This CHARTER USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 CHARTER USA techs tried our tools and information and gave us feedback after they called. The reason techs call # I:8OO:,:8O31069 is to reach the CHARTER USA helpline department for problems like Where to buy, Complaint, helpline, Repairs, Returns. As far as we can tell, CHARTER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. CHARTER USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I8OO8O31O69 and ways to call or contact CHARTER USA with help from techs like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling CHARTER USA Calling CHARTER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our desk call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from CHARTER USA helpline can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with CHARTER USA's helpline department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare CHARTER USA's phone numbers against each other. Contacting CHARTER USA in General While I8OO8O31O69 is CHARTER USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I8OO8O31O69 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach CHARTER USA help by calling them, is that other techs give their helpline at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact CHARTER USA.
Computers & Internet Logo
261 people viewed this question
Ekse
Alun Cox
