Question about Samsung DVDR120 DVD Recorder
Does not recognize a blank DVD
This may be a very basic problem, but I just purchased a Samsung DVD Record which I hooked up to my VCR (I get a signal just fine.) When I insert a blank DVD, it says it "cannot play disc" and to insert another. However, it's supposed to say something along the lines of "do you want to initialize this disc?"
What is the fix?
Thanks!
-Eric
[email protected]
i have had the same problem getting my DVD Recorder to read the blank DVD i am buying.
evry singlwe type i buy, whether its +R, or +RW etc, it never initializes the disk.
i emailed Samsung and they said that there was none they could advise me to buy!
HELP!
    Problem Solver:
  • 3 Answers
I bought DVD-R 1-16xspeed made by TDK which work fine.... it seems to be a bit of a mine field of discs available but I do remember these were recommended by Samsung via a leaflet in the box.
Posted on Aug 06, 2008
SOURCE:
My Insignia DVD/VCR will play VHS tapes, but does not record on them when I put a blank in and it shows recording on the VCR, but when I rewind and playback, just get blank sometimes wavy nothing and snow!...
First thing to check is does the video actually get a TV signal to record? When you set the recording going is the channel viewable?
Next thing to do is clean all the video heads, this will include the erase head! If you still can't get it to record and the VCR does pick up a signal to record, then there will be an electronic fault that is causing the no record signal.
Aug 20, 2013 | Insignia Televison & Video
It doesn't recognize DVD types when we want to record from TV
Check you are using DVDR+ or DVDRW and that they are blank
Jan 13, 2012 | Lite On LVC-9016G DVD Recorder/VCR
How do you find a dvd recorder that does not need and external tuner? Does the new tv's have a tuner that you can use with the current dvd recorders
U have cables or satallites tvs services hook up.U can record VHS tapes and used any DVD/VCR recorder machines hook up.Because the pay services does convert the signal back to analoge tv signal so u can record VHS tapes.
May 12, 2011 | Toshiba DVR620 DVD Recorder/VCR
I am trying to record cartoons for my 4 month old onto dvd from cable... I cant quite figure out how to hook it up.
The device unit?U must have DVD/VCR recorder player to record things out of cable tv or other tv signals.Not just a DVD/VCR player.Read ur manual for instruction,u hook up a VCR before right,the same principle.
Dec 07, 2010 | Samsung DVD-VR357
I have a Toshiba D-VR16. How do I copy a VHS video onto a CD?
Just put the tape and a blank cd in and just press the Copy from the case.
Aug 10, 2010 | Toshiba Televison & Video
Samsung DVD-VR300 - cannot get VCR or DVD to play
cable from wall/outside to cable box in, cable box out to dvd/vcr in ...dvd/vcr out to tv...........set both tv & dvd/vcr to Ch 3.........
note you will not be able to record (probably) HBO on to DVD (vcr yes)
Jan 31, 2009 | Samsung DVD-VR300 DVD Recorder/VCR
Samsung DVD recorder will play but not record blank discs
Had mine into the repair shop. Junk it, processor is toast. Not worth the money to fix. The guy said he wouldn't even touch it.
Jan 19, 2009 | Samsung DVD-VR330 VCR and DVD Recorder
are you putting in the right type of disc? dvd -r or dvd +r or dvd rw?
which type does the player take.
Feb 19, 2008 | Samsung DVD-HR720 DVD Recorder
Recording TV
Hi.. it looks as if that particular dvd/vcr is not compatible with the coding digital signals that the hdmi is putting out so it's not converting the signal over correctly.. if you try just using the regular analog cable instead of the hdmi, that might solve your problem.. i hope this helps..d
Jan 24, 2008 | Samsung DVD-VR357
Samsung DVDR120 DVD Recorder Logo
202 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
