Question about Lexmark T632 Laser Printer
Will not print
Display shows " Load MP Feeder Letter" but plenty of paper in trays.
  • Anonymous Aug 28, 2008
    Tried the fix listed.....still the same error?
Try to power down the printer (including unplugging it from the wall) then take out the paper trays. From there, reseat the tray guides (so pull them all the way in, then all the way out). From there replace the paper in the tray, and then re-align the guides to the paper. Plug it in, and then try a test print.
Posted on Apr 18, 2008
2 Suggested Answers
Corysf62
  • 188 Answers
SOURCE: Will not print
This usually happens when the paper tray is set to the incorrect paper size.
This printer determines what size paper is installed in it by the little "fingers" on the left side of the tray. When you adjust the paper tray, it determines how those fingers are positioned, and therefore, how the switch reads the paper size.
If the tray setting is off, even by one little click, then the machine may read the paper size as other then letter. If this happens, you send a letter size job to the printer, and it doesnt think it has letter size paper, it will tell you to put letter paper in the MPF feeder.
If the tray is definately set to letter, but the machine still thinks it does not have letter, then the tray or the switch that reads the tray is defective, but 99% of the time it is just the tray is not set correctly.
The MPF door can be open or closed 100% of the time with NO EFFECT on how the printer works.
Posted on Nov 22, 2008
Testimonial: "Absolutely useful although I didn't see it when I worked it out by my own."
Load mp feader a4
Please determine what size you are trying to print (A4, Letter, Legal, etc.). The printer is requesting A4 sized paper in the maunal paper feeder becuase either you selected manual feed or the setting for the default try (usually tray 1) is not set to the correct paper size. In your case, make sure the green slide adjustment on tray 1 is set to A4.
Mar 22, 2014 | Lexmark T632 Laser Printer
Message window shows "load mp
The printer tells you to insert a letter format paper in the mp (multi purpose) feeder (the manual tray).
If you press the GO key the print probably proceeds with print job (if has the paper loaded in mp feeder)
Jun 15, 2011 | Lexmark T634 Laser Printer
My lexmark t430 says load mp feeder letter. what does this mean?
You have send a print job from your application (ex. word), and the paper format in this appl. is letter. The printer tells you to insert a letter format paper in the mp (multi purpose) feeder (upper the tray).
If you press the GO key the print probably proceeds with print job (if has the paper load in mp feeder)
Feb 23, 2011 | Lexmark T430 Laser Printer
Load mp feeder error optra t 642 printer
I received this message when I was trying to print a pdf file. I attempted messing with the positioning of green paper guide to no avail. My co-worker suggested I uncheck the Choose paper source by PDF page size box on the Print pop-up box. This did the trick.
Dec 08, 2009 | Lexmark T642 Laser Printer
I keep getting a Load MP Feeder Letter message. I can't clear what to do?
MP Feeder refers to Multi Purpose Feeder or Manual Paper Feeder or just plain bypass feeder. There should be a door that folds down to gain access to your MP Feeder tray. Try loading letter size paper on this tray.
Nov 24, 2009 | IBM Infoprint 1332 Laser Printer
I have a T620 that won't print from the trays because it continues to show ''Load MP tray'' on the display. When I drop down the tray and load the multi-purpose feeder, it will print what's in the queue....
Turns out that the paper tray was damaged - the tray was unable to determine the correct paper size, despite fooling with the green paper stop. I had to compare it with a known-good tray to see the problem.
Apr 28, 2009 | Lexmark Optra T620 Laser Printer
Lexmark t642 load mp feeder with letter
The reason that your printer is asking you to load paper into the MPF is that it doesn't think it has that size paper in tray 1 or 2. Make sure that the green paper guide in the paper tray that you want to print from is latched in the correct position. This guide tells the printer what size paper is in the tray. If you have it even slightly out of position you'll get this message.
Mar 11, 2009 | Lexmark T642 Laser Printer
Will not print
Oct 10, 2008 | Dell W5300N Laser Printer
Paper tray selection
Go to Paper Menu > Paper Size > Tray 1 - note what the Auto setting states (Letter, A4, Legal, etc.) Pull the tray out to set what it is configured for. Then reinsert it & pull it out a few times, noting what the display show the Auto size show. It should match the tray's settings.
If the Display indicates otherwise, it means one of two things:
1) The "auto size sensing" board on the left may be defective. The left side of the tray has a matrix of 3 plastic tabs that stick out in certain order depending on the tray setting. If this board fails, it may show Executive or A4 when the tray is set for letter.
2) The tray may be in-between two settings. Try to readjust the tray length setting between sizes. (You will notice the plastic tabs will change order.) The last time you loaded paper it may have pushed it just enough so that it is no longer seen as letter by the auto sensing board.
I hope this helps...
Nov 28, 2007 | Lexmark Optra T610 Laser Printer
Lexmark T632 Laser Printer Logo
372 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
