Grundig gu15wdpcx. unable to access any of the dtv menu's not even to scan for channels etc, please help
With this model you can access everything apart from the DTV menus inc DTV tuning without the remote, for DTV menus and tuning you must use the remote.
Posted on Jun 03, 2010
Does my grundig tv model g2412 fledv support mpeg 4? I only get sound and no picture for the new free to air channels.
Free-to-air, or DTV, is Mpeg 2 and is supported. Mpeg 4 is supported for playback via files on external storage connected via the USB port.
Try doing a Restore to Defaults via the on-screen-menu in case there is a bad setting somewhere.
Apr 04, 2016 | Grundig Televison & Video
I am trying to program the RCA ColorTrak Plus TV to my satellite receiver and I get nothing but snow
You will need to get a "regular" Universal remote and program it for that particular model of TV. You will need to access the on screen setup menu for the TV and then have it scan the channels. Make sure your DTV box is on and connected with the coaxial cable. If the "TV Input" button on your DTV remote works and you can get it onto the Video Channel, You can connect your DTV receiver with the RCA Cables (Red, White and Yellow) and get your picture that way. If you access the on screen menu, you will need to scan for Analog and Digital channels as the receiver transmits in Analog. hope this helps.
Sep 24, 2012 | Televison & Video
Vizio vm60p hdtv scanning problem
I had the same problem. Change your input to dtv even if you are using coaxial input. Then go to the menu screen and select tuner settings. Dtv setting should appear.
Nov 17, 2011 | Vizio VM60P 60 in. Plasma TV
Following the beginning of digital switchover, pressing the menu button only comes up with 'picture quality' and is unable to access 'installation'.
If your TV is not in Digital it won't give you the tuning option.
Select DTV from the on screen menu, (like scart 1 scart 2 etc). When you have found DTV select it and then press menu for tuning.
Hope that helps.
Mar 30, 2011 | Televison & Video
I have grundig lenaro 32"tv
Sounds like you're only viewing analogue channels.
Go into Menu and find Inputs and select & choose DTV. This will restore reception of Freeview (Digital TV) channels.
Mar 30, 2011 | Grundig Televison & Video
How do I manually/automatically update the channels on my Samsung DNli DV3 TV?
Hi Hugh.
Please follow these instructions to manually/automatically update the digital (DTV) channels on the Samsung LE26R73BD.
Please use the following buttons on your Samsung remote control to navigate the on-screen menus:
- "D.MENU" - Opens/closes the on-screen menu (below the numerical key "0")
- DIRECTIONAL ARROW KEYS - To navigate up/down/left right through the on-screen menus
- "ENTER/OK" - Selects/confirms a selected option (in the centre of the arrows)
Automatic Channel Scan / Update:
1. Make sure you are in digital TV mode - Press the "TV/DTV" button on the remote to switch between analogue (ATV) and digital (DTV) modes.
2. Press the "D.MENU" key
3. Highlight "Installation" (first option) and press "OK/ENTER"
4. If asked for a PIN code, enter 0 0 0 0 using the numerical keys on the remote. If you have set a different PIN code, please enter your own code here.
5. Highlight "Select County" and press "OK/ENTER"
6. Use the LEFT/RIGHT arrows to select "UK" then press "OK/ENTER"
7. Highlight "Auto Scanning" and press "ENTER/OK"
8. Highlight "Scan Mode" and use the LEFT/RIGHT arrows to set the value to "Digital"
9. Highlight "Start Frequency" and use the LEFT/RIGHT arrows to set the value to "CH 21 . . ."
10. Highlight "End Frequency" and use the LEFT/RIGHT arrows to set the value to "CH 69 . . ."
11. Highlight "Start Frequency" again and then press "OK/ENTER" to start the channel scan.
Some of the options above will already be selected so will not need to be changed. I've provided the correct settings just in case they are incorrectly set. Note: UK Freeview stations are on channels 21 to 69 inclusive.
The scan will take a few minutes to complete and the progress will be displayed. When the channel scan is complete, the menu should close automatically and the TV will return to viewing mode. If not, press either the "D.MENU" or "EXIT" button to return to watching TV.
Manual Channel Scan / Update:
7. Highlight "Manual Scanning" and press "ENTER/OK"
9. Highlight "Channel Number" and use the LEFT/RIGHT arrows to choose which channel number you wish to scan . . .
UK Freeview stations are on channels 21 to 69 inclusive. In manual tuning mode, these need to be scanned one at a time. Please note, many of these channels are "empty". UK Freeview only uses 5 of these channels (called Multiplexes or MUX) or 6 if you have HD. I am unable to tell you which 5 channels these are as they vary according to whichever transmitter or repeater station your aerial is aligned to.
10. Press "OK/ENTER" to start the channel scan.
11. Repeat steps 9 and 10 for each additonal channel you wish to scan.
Please note: Manual scanning can cause some unexpected results - particularly if your aerial has a reception from more than one transmitter/repeater. For this reason it is better to use the automatical scan unless you have a specific reason for needing to scan manually.
Hopefully this will be all you need to update the digital channels on your TV. If you have any questions or need further assistance, please let me know.
Regards,
BElectric
Jan 07, 2011 | Samsung Televison & Video
Problem, unable to access any digital channels. TV displays error message Database Empty, any way of removing this message and accessing DTV again. Thanks
If the database is empty you need to re load the system.
With your remote controller, go to menu and from that you need to select install or setup.
This will scan for all available channels and store them for use.
Hope that helps.
Nov 19, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Cannot access channel 73 on TV2
If you are unable to access the TV menu using the buttons on the TV itself it is possible you can with the TV2 remote if it still controls the volume etc. for this TV. If it doe not you will need to find a code for your set in the manual for the receiver or you can go to the following link to find that info as well.http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/receiver/625.shtml
Assuming you have control of the volume still press the small TV button on the top left of the remote. Now press the menu button and you may be able to access the TV's menu. If so you need to run a channel scan/auto program the TV. You may need to use the buttons on the TV still to maneuver through the menu.
If you are still unable to access the menu you may need to purchase a universal to access the menu.
Jan 11, 2010 | DISH Network DVR-625 DTV Receiver /...
I can't scan DTV channels on my vizio 52''
do you have antenna or cable? if you have antena hook directly to the coax, go to menu, TV, tuner and pick antenna and scan. If you have cable hook directly to your coax repeat the previous step but pick cable instead of antenna. Notice if you have a cable box, you will not need to scan for channel since it will be on channel 3, 4 or any other input you may use.
Jun 20, 2009 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
114 people viewed this question
Top Televison & Video Experts
