Question about GPX DV-1010 DVD Player
GPX DVD HI, The DVD is stuck on stop. The only thing that works on it is the little green light. It is only a few months old (Bought it last Dec.) no problems till now. The remote has no effect on it and manually nothing happens. It reads B1 Stop in the little blue rectangle in the upper left hand corner. Thanks, Blaze Compton
5 Suggested Answers
MrARCADIAN
  • 284 Answers
SOURCE: player won't work
i am afraid it is a defective player
alot of cheap dvd player are on the market
even sony player goes bad.
they made them cheap and fast.
if it gave you more than 4 month of service then
it was worth the money
time for a replacment
Posted on Aug 16, 2008
  • 52 Answers
SOURCE: universal remote
i would go to the rca website and check with them there is a way to do it with out a code from the book i just cant remember the exact sequence,i think you turn on the device then press the devise button and hold power till the power button starts blinking then keep pushing the power button till the devise goes off then you must hit the stop button on the remote right after the devise goes off then you should beable to turn the devise on using the remote
Posted on Aug 20, 2008
  • 4 Answers
SOURCE: GPX DVD player flashing power light
Ihave a GPX portable dvd player that has a broken charging jack on the unit itself. The model is a GPX 808.
Posted on Mar 25, 2009
marketex
  • 371 Answers
SOURCE: Flashing Battery Symbol on GPX PDL805
The appearance of a battery symbol while you are using just the battery means that you are using just the battery.
That's it.
No Problem.
The flashing battery symbol is a constant reminder to you that a power intensive function is only supported by the battery, and that you should make external power available so as to complete the task without losing power in a battery drain event.
Posted on May 08, 2009
  • 12 Answers
SOURCE: I have a GPX DVD player that has the model number
You can always go with the logitech even if toy cant find the remote code this is a learning remote. But this remote programs though a web interface and it will have the remote codes.
Posted on Mar 08, 2011
I bought a dvd player last month and after
that a manufactures problem, if you have a guarantee go back to the store and return it, because it looks like an electric issue.
Dec 30, 2009 | Memorex MVDP1072 Portable DVD Player
Standby light is blinking red will not open dvd or play at all
in a situation like this, there are only a few things you can do.
unplug the unit and wait for an hour or 2, and plug it back up and see what happens. if the unit is making any unusual noises (listen carefuly to it) then it will more than likely need to be repaired.
depending on the price, you might just consider going and picking up a cheap dvd player from wal-mart or something.
Sep 24, 2009 | GPX D1816 DVD Player
Blinking standby light, dead dvd player
Hello illeanaceres,
I'm sorry to hear about the bad news, I had something similar happen to me around a month ago.
Honestly there is not much you can do if it is damaged due to a power surge. Resetting it would be the normal procedure.
Surge protectors only protect equipment up to a certain amount of joules. Basically if the lightning is powerful enough it can damage electronics with that initial surge. You should replace your surge protectors every few years if it is 2-3 years old then it may not be as effective.
Post back if you have anymore questions or comments. Thank you for choosing Fixya!
Jul 13, 2009 | GPX D1816 DVD Player
Mar 11, 2009 | GPX D1816 DVD Player
GPX portable DVD model PD808B - wrong region message
Turn on power. Open lid. Enter 9735 with the remote and press 'enter', you can now choose between regions on the screen. Select the desired region unlock and press 'enter'. This works well!
Benony Jonsson
Feb 20, 2009 | GPX PD808B Portable DVD Player with Screen
I bought the GPX DVD player in dec. 08 and need help to use
I am rtaking the product back for a refund this site is a joke just to get money for services when the product is not worth the hassel to buy if this is how to conduct business.Maybe the Better Business Bearul would like a notice on how the price to FixYa wants to charge for your product.
Jan 06, 2009 | GPX D1816 DVD Player
Hi this is amanda i get a gpz PDL805. When I put a dvd in the player it loads for a while and than its stop and said to check disc, when i did. and its says the same thing i know it was working a week ago...
have you tried other dvds and cds?
If they work, the dvd you are trying to load is either scratched or dirty. Clean using a cotton, lint free cloth (no circular motion).
If they dont work, your lens is dirty. Use a lens cleaner CD.
put it in the dvd player and let it run until it stops by itself.
this should clean the lens.
Aug 27, 2008 | GPX Televison & Video
Player won't work
Aug 16, 2008 | GPX PDL805 Portable DVD Player
Portable DVD player- screen problem
cheap product and cheap material, have you tried another video??
most players dont last more then a few month of hard core playing like every day for 4 hours since youve bought it.
im sure its burned out. laser eyes can go bad or even the invertor since there is no real way the dvd player can be cooled.
so im sure its burned itself out
Aug 11, 2008 | GPX PDL805 Portable DVD Player
Error not disc
Have you reset the little eye under the dvd.  Gentlly slide it to the middle and turn it back on..  sometimes that works
May 19, 2008 | GPX PDL705
GPX DV-1010 DVD Player Logo
Top GPX Televison & Video Experts
Blake
sonic boom...
sonic boom...
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
