Question about NEC Pinwriter P2X Matrix Printer
NEC Pinwriter P3300 Printing
My NEC IS 1990 it is a work horse but lately it won't print correctly it is faded.I replaced cartridge ribbon, and clean inside it. I don't know what to do
Kathy
    Genius:
  • 2,785 Answers
Reinstall the driver.if not solved then your printer needs servicing
Posted on Apr 04, 2008
My zebra id card printer p120i does not print very sharp
zebra p120i TROUBLESHOOTING LINK
Printing shows blurry printed image.
Possible Cause:
•Ribbon cartridge may not be correctly positioned.
Solution:
•Check that the ribbon is properly rolled onto the ribbon cores of the cartridge, with no wrinkles.
•Replace ribbon cartridge, making sure it locks in place, and print again.
Possible Cause:
•Ribbon may not be synchronized on the correct color panel position.
Solution:
•Open lid, then close lid to synchronize ribbon.
Possible Cause:
•Cards may not meet specifications.
Solution:
•Use a different supply of cards.
Possible Cause:
•Dust or embedded contamination inside the printer and/or dirty Cleaning Roller.
Solution:
•Clean the Print Head.
•Replace Cleaning Roller
Jan 30, 2011 | Zebra P120i Thermal Card Printer
Printer 5510
If you use your printer occasionally, it might be that the print head on the cartridges is clogged. I don't know what was serviced, but if your cartridges haven't been printing for a while, that is surely your problem. You can try this:
  1. Try cleaning the print cartridge from the Maintenance utility by following the steps below:
    1. On the all-in-one front panel, press Setup (or Menu) repeatedly until "Maintenance " displays, then press Enter .
    2. When "Clean Cartridges " displays, press Enter .
    3. At the end of the cartridge cleaning cycle, a page will print. Examine the page to determine if the problem is corrected.
  2. If the problem still exists, clean the cartridge following the directions below in the "Clean under the cartridges and the carriage " section below.
  3. Verify that the ink cartridge is not low on ink by checking the estimated ink levels as indicated in the "Colors on printout are wrong or fade in and out while printing " section above.
  4. Replace the print cartridge for the color that is not printing correctly.
Mar 05, 2010 | HP 5510 4-in-one Printer
Datacard sp55 printer won't recognize ribbon
PR-01726 Ribbon Out
Out of print ribbon.
Possible Cause 1 : The print ribbon Cartridge is empty.
Solution 1 : Reload the print cartridge. Change the cleaning sleeve and replace the cartridge in the printer. Run a cleaning card as soon as printing is completed.
Possible Cause 2 : The printer ribbon is not loaded correctly.
Soultion 2 :Load the printer ribbon correctly and then close the cover.
Possible Cause 3 : This ribbon has been completely used.
Solution 3 : Use a new roll of ribbon.
Tips for Success
* When this message appears, replace the old ribbon with the new ribbon of the same type. The printer has already prepared the card data for this ribbon type. You can change the colors of monochrome ribbon (such as from dark blue to gold).
* If you must change the type of ribbon (such as (YMCKT to KT) when this message appears, install the new ribbon, cancel any cards waiting to print, and change the ribbon type settings. Finally, return to the card creation program to send the card data to print.
* If the ribbon was repaired, the wrong take-up spool was used. Repair the ribbon again, using the correct take-up spool.
If you cannot fix the problem contact your service provider for assistance.
FTB
Nov 23, 2009 | Datacard Group SP55 Card Printer
Cleaned printer but printing is faded...
You may need to replace the toner cartridge or replace the transfer roller, I believe that's what it's called. It's the roller that transfers the ink from the toner cartridge to the paper.
Oct 02, 2009 | Brother Office Equipment & Supplies
Faded print job
ok...have you tried a clean and re calibrate lately on those print heads?
Mar 20, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
Faded print on one side of page
I have a SCX-4100 Samsung, replaced the tonger cartridge, it was working fine for a few hundred sheets of printing, but after that, the left side of the page was printed very light, faded.
If I run the "Clean Drum", it will print a litter better, but still faded.
What can I do to correct this problem?
Thank you
TT
Nov 24, 2007 | Samsung ML 1710 Laser Printer
HP Officejet 6210 printing blank pages
Hi steve well I suggest that you remove the cartridges and clean the little gold contacts on the carriage and the cartridge. If this doesn't work then install brand new original cartridges as the cartridegs that you have refilled the data ribbon may have been damaged when you refilled them..
Try the above and I hope it works for you
Thanks J
Oct 23, 2007 | HP LaserJet 4 plus Printer
Printing
please check the cartridges holders and clean it
Oct 05, 2007 | Lexmark X85 All-In-One InkJet Printer
NEC pinwriter P20
Very funny. There are a number of things you can try. Start by checking for very small debris in paper feeder area and inside unit, especially around printhead carriages. Clean your unit thoroughly, including rollers and run allignment checks. Also check all printer settings for normality. Only load small amounts of paper at one time as this helps to avoid pressure on feeder rollers, and may alleviate 2 sheet feeding.
Aug 11, 2007 | NEC Pinwriter P2X Matrix Printer
449 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
