Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
I purchased a Singer CE-200 and have not been able to load the software so that I can use my machine.  I first tryed to load it in a laptop with XP and it would got to a certain point and stop working.  I then purchased a new taptop with Vista and still have the same problem except,  this time, the machine starts flashing an 88 error message, the light on the front of the machine starts flashing red and I get a message that the machine is not connected or turned on, both of which are not the case.  I have been trying to get this solved for a year and a half and it is a real nightmare.  I am about to the point of throwing this unused sewing machine in the trash and going back to my 28 year old machine.  I am not very computer literate but, when I purchased this machine I thought I would really enjoy it.  WRONG.    Please help!!!!!!!
  • 2 more comments
  • jeveritt2 Apr 03, 2008
    I have downloaded it at least 10 times. I have also checked the Singer website and they had a patch for XP and Vista but, I followed the steps as far as they worked and did not get the problem solved. I printed the instructions out and got thru the Task Manager and Futura Software Properties just fine. I do not have a HYPERFONT CD so I skipped that and doubleclicked on the Futura Icon, clicked to allow and then it says "Enter code" in instructions. What code??? A screen with a flower came up and I could not get any farther. A screen that was supposed to have Don't show this message again & "Run Program" do not come up. From there, I was lost.
  • jeveritt2 Apr 05, 2008
    It took 2 days but I finally was able to download the Vista drivers and the patch. I was overjoyed when they finally downloaded until I got to a place where the Futura.QZ file stopped running. Will not finish the download from there so I still cannot use my machine. Any suggestions short of purchasing the newer version of Auto-Punch? I currently have the version 1.0.0.1.
    I updated the Auto Punch and followed the directions to turn on the machine & double click the Futura Icon. The Futura logo came up but, I immediately got the following message: Connection Error - Check that USB cable is connected & the power switch is turned on. The cable was already connected & power was on. I have loaded and deleted, and reloaded so many time that I am just about ready to give up. Do not know what to do next. Thanks, Janice
  • jeveritt2 Apr 08, 2008
    Did everything you suggested but, in the end, I finally, after being on hold a total of 1 1/2 hours and 3 calls, did talk to someone at Singer and she sent me an email that told me exactly what I needed to do based on the Connection Error message that I kept getting.
    I appreciate all your help and time. The info you provided did help. Thanks
    Genius:
  • 3,422 Answers
HI,
The problem is with the software disc. the best solution is to download it again and install it.You should also check wether the software is for Xp or Vista.
Goodluck,
Please don't forget to rate the solution
Posted on Apr 03, 2008
  • 4 more comments
  • Priya darshan Apr 03, 2008
    If you need more suggestions and solutions please click HERE
    If you are talking about the basic Futura software, there are no access
    codes, but if you want to install autopunch or hyperfont you will need
    the access codes.
    I think this link will help you fix the problem.Click HERE
  • Priya darshan Apr 05, 2008
    HI,
    I suggest you not to purchase it now.First try to update the auto punch and see if that helps.
    Goodluck..
    Ok this is the final solution i can give if this doesn't work it is up to you to decide what to do next.
    Unplug all th cables from back of the modem including the power cable of the modem.Now unplug all the modem cables which is connected to your PC.Let it reset.wait for 30 min and then put all the cables back.Make sure that all the cables are connected firmly.
    Now give it a try.
    Goodluck,
    Please don't forget to rate the solution.
  • Priya darshan Apr 08, 2008
    I am really happy to hear that your problem is solved.
    Thank you for using fixya!!
  • 790 Answers
Hello jeveritt2 ,
You gotta download vista compatible drivers and install it..
  • Kanth raj
    Kanth raj Apr 03, 2008
    you can try with ur old laptop with XP itself by downloading the updates from here click here or try vista patch also
Software for singe futura ce-200
That is called the upgrade or compatibility software, and I would recommend that you search on eBay under Singer CE-200.
Nov 17, 2015 | Singer CE-200 Quantum Futura Computerized...
My futura does not have button holds programmed into the machine so I cannot make a button hole with this CE-200 machine can it be downloaded and programmed into the machine? Thanks, jan
You can download the latest software from here.
Make sure you follow the procedure outlined in the manual carefully. The manual is located here.
If you still have problems, you might have better luck getting more specific answers by posting to a forum that is more sewing centric. Find such forums by searching google for: CE-200 futura forum
Feb 12, 2012 | Singer CE-200 Quantum Futura Computerized...
I cannot seem to down load my software onto my computer tried it on vista tried it on windows 7 i am peeved
Have you downloaded the patches for your software to upgrade to Vista? I would suggest that you visit the Singer support page on their website and read through the patches information.
http://www.futura-support.com/downloads/patch.htm
Your software is probably built for XP operating system so you would need to patch it for the newer Vista - there is not yet a patch for Windows 7.
Oct 10, 2011 | Singer CE-200 Quantum Futura Computerized...
Will any CE 200 and CE 250 software interchange? I have purchased both machines and am curious.
You can purchase an upgrade for the 200 to bring it up to the 250, so it works in that direction. I'm not sure the 250 would work with the older 200 software, though.
Oct 06, 2011 | Singer CE-200 Quantum Futura Computerized...
I have lost the Access Key from my CD to the Futura Software. The software is loaded on my system but is asking for the key. (Singer Quantum Futura CE 200)
You will have to contact Singer customer service.
They have a website where you can look at FAQ and Futuras to see if this has been addressed before sending the question.
Mar 27, 2010 | Singer CE-200 Quantum Futura Computerized...
Singer CE0100 Futura connection error....
Hi I had the same problem sent question to Singer and this was their reply
"Do you have Vista 32-bit or Vista 64-bits? Unfortunately the CE-100/200 machine will not be compatible with either Vista 64-bit systems or the newest Windows 7 computers. The CE-100/200 will only be compatible with Windows 98 through Vista 32-bit operating systems.
This appears to be a hardware issue and not something that we will be able to create a patch to correct. Drivers necessary for 64-bit operating systems are not compatible with the CE-100/200 machines." so I guess we are SOL
Sep 27, 2009 | Singer CE-100 Futura Computerized Sewing...
Singer CE-200
You can run it on vista. Go to singerco.com and download the patch.It should work.
May 19, 2009 | Singer CE-200 Quantum Futura Computerized...
Cannot load software
Had the same problem.You need to go to singerco,com and download a patch.They have one for XP and Vista.
Apr 02, 2009 | Singer CE-200 Quantum Futura Computerized...
Futura CE-200 Software fails to initialize on XP sp2
Maybe you should try to contact singer south africa and ask them whats wrong, my laptop did the excact same thing switch over to home pc and no problem ever again.
Mar 02, 2009 | Singer CE-200 Quantum Futura Computerized...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
227 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
