Back to:
Tags:
PC Laptops
Generic problem for all PC Laptops
Acer Extensa 5420 laptop memory upgrade
posted by DeeJay Ray on Apr 03, 2008
Can't seem to get panel off of bottom even with all screws removed. Don't want to force it or break it
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Apr 04, 2008
Not Rated (0)
djenigma
Rank:Wiz Wiz
Rating: 83%, 20 votes
Are you trying to Upgrade the Memory ?. .then all you have to do is take of the screws that have a small picture of a Memory chip next to it. and pop off the small lid to reveal the Memory Bank. You may want to use a really thin flat head to pry the cover off.
If you are trying to take apart the whole back cover for whatever reason, There is a little "clip" type things for a lack of a better word. Just kind of try and get a finger nail in there and move it around. It'll "snap" out of there. And be careful, there is a thin plastic peice that goes around the DVI connector at the back, and if you're pulling ******* it to get it out, you run the risk of snapping it. But no, nothing special, just try to not break it
Just be gentle and pull UP if its kind of Hanging where the windows Vista sticker is.
good luck,
djENigma
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Acer Extensa 5420 laptop memory upgrade:
I don't want to Accept this solution
Can you Help with these PC Laptops problems?
PC Laptops
bt freestyle 3200 phone i have a twin set and both...
Dell Latitude D600 PC Notebook
What is the best way to sync files between 2 desktops. ...
PC Laptops
on my Medion Mim2120 laptop, I installed Vista onto it...
Dell Latitude C610/C600 Pentium III...
I received a laptop with no info on its working condition...
Fujitsu Siemens AMILO Pro V2000...
Hi.i wana know which model,reference,of internal dvd...
Loading problems.
Repair Service
Find PC Laptop Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
