Question about Cooktops
Gas cooktop BOOM
My Wolf 4 burner (36") gas cooktop will, when on the simmer or lower setting, all of the sudden "kind of blow up" (big boom). I do not notice the click,click, click of the burner trying to ignite at any time before this happens. I don't smell any gas but I would bet that is what the "BOOM" is all about.
  • gswann2 Nov 19, 2008
    My gas cooktop has blown up twice. The first time, the tech replaced all the rings. Yesterday, it did it again. It literally blows the control knobs off of the unit.
  • 135 Answers
Gas is taking too long to ignite. Make sure the burner rings are installed properly. They have grooves that need to line up. Also make sure all the holes are clean.
Posted on Apr 07, 2008
I am not sure of the model number but the gas cooktop was purchased in 1998. The 2 burners on the left side all of a sudden are not ingiting. There is no gas and the igniters are not sparking. the other...
Hello Sharon,
are the two left hand burners "simmer burners" that low come on and go off to simmer a pot?
and the right side just set on and turn off without the simmer option?
if yes this pretty much describes your cooktop the part called the potentiometer is going the be the problem.
Aug 26, 2011 | Thermador SGS36GS Gas Cooktop
We can't turn off the igniter on our gas cook top
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Mar 27, 2011 | Wolf Range RHP-6-36 12 in. Gas Cooktop
Electronic igniters will not turn off when the gas burner lites. all four igniters run untill you turn off the nob or unplug the unit
I'm dealing with this same problem. This cooktop has a dedicated simmer burner which is the only thing going on the lowest setting. This simmer burner seems to be how the igniter senses that it can stop. If it doesn't light, the igniter keeps clicking. Usually cleaning the burner will solve this. You may need to unscrew the nut holding the lower piece of the burner in place in order to clean it up.
Apr 17, 2010 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
The flame is too high on my GE Profile gas cooktop
I had the same issue on my jgp975 and sadly I had to purchase a different unit. I use simmer frequently and I made the assumption that low was simmer. Wrong. I believe a true simmer is 450 btu and my unit did not go that low. I had to check the fine print/specs page and on some units the manufacturer had to be called. I did replace with another ge profile that did have the low setting.
Apr 06, 2010 | GE 36 in.JGP970 Gas Cooktop
I use one of the large burners most of the time and the minimum setting(simmer or ?) seems to have increased over last 4-5 years so that I have to turn burner off and let food cool, then turn on again,...
I am not sure of this Model but most of the Gas Rail Cocks ( Taps) when you remove the knob you will find either a small hole drilled into the spindle This would be the Low Burner (simmer Rate) Adjustment there would be a small screwdriver requiredto do this , if its not there ,then there is usually a small screw on the side of the tap under the Knob Hope this will help you
Jul 18, 2009 | GE 36 in. Profile JGP963 Stainless Steel...
Clogged burner on gas cooktop
lowly is it the left burners that won't lite? I only ask as depending on the model some of the Thermador cook tops had simmer control burners. This is a 3 part system on the burners. 1 a simmer control, 2 electric solenoid, 3 potentiors. When you turn on the burner the potentior tells the simmer control to send power to the gas solenoid. At the same time the unit will spark. If your unit has extra low on the left 2 burners then you have this system. The usual problem in the potentior. Hope this helps.
Aug 07, 2008 | Thermador SGS36GS Gas Cooktop
GE 36" Monogram Gas Cooktop - low flame
I would have someone come out. Perhaps a gas plumber first. Gas is not something you want to fool around with yourself.
Aug 01, 2008 | GE 36 in. JGP628 Gas Cooktop
GE Profile Gas Cooktop, Model JGP975SEKSS
Buy the Burners for my 36" GE Gas cooktop.
Jul 09, 2008 | Cooktops
Thermador SGCS456R 36' gas cooktop
Take apart the cooktop and it is the potentior on the valve for the simmer burner that is usually the issue.
Aug 15, 2007 | Thermador 37 in. SGSX365 Gas Cooktop
Cooktops Logo
153 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
