Question about Cameras
I have a Power Shot S3IS (purchased 11/30/06). When I turn the camera on, I LCD monitor and view finder remain dark. By tinkering with switches I can sometimes get them to work....often for only a few seconds...can the camera be repaired....is the warranty still good...(the camera was purchased at Costco. Need help. Thanks.
    Master:
  • 555 Answers
If you have the Costco warranty, I would get the unit serviced to repair the problem. Costco's warranty policy is excellent, and you could ultimately even get a replacement unit.
It does sound like a hardware fault of some kind, so it would be best to get it fixed under warranty before it gets worse.
Posted on Apr 03, 2008
  • Matt Jurach
    Matt Jurach Apr 03, 2008
    The new Costco return policy is 90 days on electronics. This changed in Feb '07, so there might be a different policy in effect for this unit purchased in Nov '06.
    Costco's current warranty policy is to extend the manufacturer's warranty to two years. That would cover this unit.
    I would contact Costco and verify your warranty coverage for this unit, and inquire about repair options. It should be honored.
    Genius:
  • 3,587 Answers
Warranty is usually 1 year..
Fujifilm FinePix S1600 The monitor display is not working. Can it be replaced and if so how easy is it?
It could be that you have it set for EVF which means that you are using the tiny view finder instead of the LCD screen? It should have a button close to the view finder labeled EVF/LCD, you can alternate between the LCD screen or the tiny viewfinder? This function if mainly to conserve battery power or if you are out in the sun and cannot frame a shot and so you use the view finder like the old cameras, hope this might help you?
Dec 09, 2014 | FUJIFILM Cameras
Why is my viewfinder black when the camera is on and able to take pictures using the LCD screen?
some camera will inactive the electronic view finder if you shot through the lcd monitor, try to find out in the manual book about shooting trough view finder.
May 04, 2013 | Canon PowerShot SX40 HS--Black
View finder on my Sony HVR-Z5U isn't working, I can film through the flip out screen, but unable to use the eye piece view finder
POSSIBLY THE RIBBON CABLE THAT RUNS FROM THE EVF (VIEWFINDER) TO THE MAIN PROCESS BOARD SHOULD SWITCH REFERENCE TO EVF WHEN LCD PANEL MONITOR IS CLOSED REGARDS JOHN
www.jvsvisual.com
Mar 14, 2013 | Sony HVR-Z5U High Definition DV Camcorder
Turn on s3is cannon power shot to take pictures and the led screen is black cant take pictures
The image in the LCD monitor will darkn in strong SUNLIGHT. This is normal, is not constitute a badfunction. This iamge will not recorded when shooting still photos, but it will be recorded when shooting movies.Read your owner manual section troubleshooting
God bless you
Sep 22, 2012 | Canon PowerShot S3 IS Digital Camera
Sony cybershot t300 lcd screen remains dark when switched on
Your camera must be experiencing these symptoms due to a faulty CCD, and not due to other problems. If the problem is due to your dropping the camera, you might be out of luck.
If you have not dropped your camera and still facing this problem, then contact service people to replace the CCD imager in your camera .
Hope this helps .
Shane
Dec 21, 2011 | Sony Cyber-shot DSC-T300 Digital Camera
Can't take any photo with my Canon S3IS any more. The view finder and the screen is black when I try to take some photo but I am able to see all photo that is already on my memory card in the view finder...
Look into the lense while setting the shutter speed at a half second or so (slow enough for you to see the shutter open and close) and click the shutter release... you should see the shutter open and close. If you don't see this, then you may have a 'sticky shutter' resulting from lubricant seeping into the shutter/aperature mechanism and preventing the shutter from functioning as it should.(Common problem reported with the S2 and S3 cameras... and probably the S1 as well)
I have gotten my S3IS to take pictures by turning on the power, then opening the battery compartment door and reclosing it repeatedly until the shutter opens (from the power surge) and an image appears on the LCD.
After confirming the sticky shutter was indeed the problem, I pursued a more permanent fix.
Jan 30, 2011 | Canon PowerShot S3 IS Digital Camera
I have canon sd 750. its lcd gets black. Shows pictures etc but view finder remains dark. display is zz. what to do?
Look for DISP or DISPLAY button in the lower-right corner of the back of your camera. Press this once while the camera is turned on. The DISPLAY button manually turns the screen on and off. This is to save battery power for extended use. You would then use the optical viewfinder in its place.
Oct 25, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
My sony DSC-H1's LCD is not showing anything...but I can operate the camera with its view finder... Do you have any idea why it happens? and is there any master reset option for this camera?
I have a similar SONY camera. Turn the camera on and to the right of the viewfinder (or perhaps in a different location on your model) there will be a small button that reads, "FINDER/LCD". Press that button once to see if your view switches back from viewfinder mode to LCD display mode.
Jun 23, 2009 | Sony Cyber-Shot DSC-H1 Digital Camera
View finder displays "busy" and the shutter is half open
I can help you fix the BUSY Error or Error 99 of your Canon EOS Digital Rebel XS.
Installation of this Canon EOS Digital Rebel XS firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
May 28, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Canon S1 IS view finder / LCD monitor black out
This is a defective CCD that Canon is repairing free of charge. Go here for details: http://www.usa.canon.com:80/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=223&modelid=8044&keycode=2112&id=29819
Nov 24, 2006 | Canon PowerShot S1 IS Digital Camera
Cameras Logo
65 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
