Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Whirlpool 25.6 cu. ft. side by side with overflow pan underneath spilling over.
  • 254 Answers
Make sure that condensor fan motor which evaporates that water is running..
Posted on May 21, 2010
  • Whirlpool Master
  • 1,606 Answers
You have a bad water filter . Replace it by turning the knob on the lower kickplate and remove old filter . The rubber seal on the old filter has worn out causing the leaking seal to drip into the drip pan causing it to overflow .
Posted on May 23, 2010
SOURCE:
Drain Pan fills and overflows. Cannot get to drain pan to empty. Why the water and how do I get to the drain pan ? Also the refrigirator door maes a loud sound when It's opened and closed. It seems to...
The water is normal....however the evap motor and fan should be drying the water before it overflows. THe evap fan motor may need replaced. You will have to pull the unit from the wall and take the back panel off or tilt the unit back towards the wall and go in from the underneath side. As far as the door goes....you might need to tighten or replace one of the hinges.
Sep 01, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
Wirlpool model GS6SHEX9S00 water pan underneath completely full and overflowing? I beleive this is the evaporative pan? Suggest lower temp on Freezer to solve? What setting would should be best we have...
This is not your defrost water. Look closely at the water filter housing where the hoses connect to it. They are likely leaking. Let me know what you see...defrost water never gets that high...not even close.
Kelly
Mar 23, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
The drain pan at the bottom of the freezer side is overflowing.
If your water filter is " thru the kick plate , at the bottom , replace the filter . I have found several times now , where the filter rubber seals , have leaked into the drain pan , causing it to over flow . You do not have to replace the filter housing , just the filter .
Nov 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
WHIRLPOOL MODELED5VHGXML10 HAS WATER RUNNING FROM UNDERNEATH
is it over flowing on floor ? the pan is the one under fridge on the out side ? it should be full but not over flowing.
find where line comes out under fridge in pan and blow back through line with shop air. clean evap pan inside freezer by defrosting and cleaning pan.
Sep 24, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water pan overflowing from icemaker
This is a symptom of a faulty defrost heater..
Regards:
Dont forget to rate:
Jul 05, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool side by side defrost drain pan overflowing
Maybe your machine has a leaky door, letting moist air inside. Make sure your compressor area is lint free. The heat from the compressor is supposed to evaporate that water. Make sure the pan is exactly in the right place, level, not cracked.
Feb 28, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Danby freezer leaking water
there is a line from the freezer defrost pan to the evaporation pan at the bottom. They often get clogged with bugs, dirt,etcWhen that happens, the defrost pan overflows resulting with a spill of water. Find it, blow it free , and you should be OK.good luck, John
Nov 05, 2008 | Danby 5.5 cu. ft. / 156 liter Chest...
Whirlpool side by side refrigerator
Had excess frost buildup in the freezer due to humidity or door ajar or to much door traffic.
May 26, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
823 people viewed this question
Top Whirlpool Refrigerators Experts
Bruce Denton
Steve Allison
Steve Allison
Norman Worley
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
