Question about Xerox DocuColor 12 Color Copier
Docucolor 12 a error code 10-162 appears and say paper jam on 3 and 4 but is no paper jam any where, what I can do?
    Genius:
  • 3,422 Answers
Here are few solutions to fix your problem:
1)there may be a very tiny bit of paper stuck somewhere - look very carefully. Also, open all areas and then close them - sometimes a printer has to have that before it resets from a jam. Check your paper to see if it is being grabbed by the rollers. if they are dirty or worn, the paper will not catch and the printer thinks it is jammed. wipe the rollers with a bit of alcohol on a paper towel (barely damp) if that is the case.
2)Check all the sensor flags (little black tabs that move when the paper bumps into them) in the paper path. Make sure they all move freely when you push them and there is not a little bit of paper making it stick in place. There should be virtually no resistance to actuate them. A sensor may have become unseated. If everything looks good there, the next step would be to use a can of dust spray to blow any paper dust out of the photosensors, which are usually near the sensor flags mentioned above.
Goodluck,
Please don't forget to rate the solution
Posted on Apr 03, 2008
  • 818 Answers
The problem is with fusor, you can check it, if not work you must replace it.
Sergio
see also this site.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=14,E=0000000000567450747,K=6140,Sxi=13,UseTemplate=FaultCodeSearch.tem
Sergio
    Master:
  • 555 Answers
What is the model of this Docucolor?
  • Matt Jurach
    Matt Jurach Apr 03, 2008
    A manual for your DocuColor 12 printer is available here.
    Since the fault code begins with "10," the error indicates a problem in the area of the fuser.
    Paper can get balled up in the fuser and cause a jam, even though you can't immediately see the jam.
    Instructions on clearing jams in the fuser area are on page 88 in the above manual.
    Be very careful, as the fuser can get very hot. Let it cool down before attempting to locate a paper jam inside.
2 Suggested Answers
  • 2072 Answers
SOURCE: error code 10-162 docucolor 12
I honestly can't find that code in the documentation or I would have sent it to you.
Posted on Apr 05, 2008
Error code 8-139
the sensor detects the paper tray 5 has an actuator which must be broken, this is on the top of that lift the tray when paper is jammed.
May 12, 2014 | Xerox DocuColor 12 Printer
Error 9343
Wait please.FF: Types of Jams
T04-201-01
Code Type 00xx none 01xx delay jam 02xx stationary jam 0Axx stationary jam at power-on 0Bxx front cover open jam
Mar 13, 2010 | Xerox DocuColor 12 Color Copier
Xerox DocuColor 242 Fusor Error/ Paper Jam
Those coded normally are related to something not being seated properly in the paper transport in the fuser area.
Mar 02, 2010 | Xerox Office Equipment & Supplies
Hallo there i have an error code 10-389on docucolor12
The code refers to a paper jam in the fuser, although this may not be technically correct, the fuser heats the paper and melts the toner if this process is comprmised it may slow the progress of the paper through the fuser. Try the 3 links below see if they help, if necessary power down the printer and disconnect the plug for 2 minutes to reset the sensors
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=x_main_en,Company={683D76C8-B5C5-416E-9754-DD015FDB4F2E},ts=x_main_en,ques=ref(Country):str(USA),ques=ref(Prod_DC12):str(DC12CP),question=ref(ProdFamily):str(Prod_DC12),varset=Xcntry:USA,varset=Xlang:en_US,varset=prodID:DC12CP,varset=objID:8273,varset=prodName:DocuColor%2012%20Copier/Printer
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=x_main_en,Company={683D76C8-B5C5-416E-9754-DD015FDB4F2E},ts=x_main_en,ques=ref(Country):str(USA),ques=ref(Prod_DC12):str(DC12CP),question=ref(ProdFamily):str(Prod_DC12),varset=Xcntry:USA,varset=Xlang:en_US,varset=prodID:DC12CP,varset=objID:8024,varset=prodName:DocuColor%2012%20Copier/Printer
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=x_main_en,Company={683D76C8-B5C5-416E-9754-DD015FDB4F2E},ts=x_main_en,ques=ref(Country):str(USA),ques=ref(Prod_DC12):str(DC12CP),question=ref(ProdFamily):str(Prod_DC12),varset=Xcntry:USA,varset=Xlang:en_US,varset=prodID:DC12CP,varset=objID:8278,varset=prodName:DocuColor%2012%20Copier/Printer
Sep 16, 2009 | Xerox DocuColor 12 Printer
Paper feed error on machine
I am going to assume that your exact error message is No Paper Fed. This is mentioned on page 12-3 in Chapter 12, Troubleshooting and routine maintenance, of the Users Manual.
Since you said that paper is in the unit, the most likely cause is a jam. See pages 12-5 through 12-8 of the Users Manual for instructions on clearing jams.
It is possible that the error message is a "false positive." Power down the unit for at least one minute, then power it up again.
If the aforementioned advice does not resolve the problem, the printer probably needs to be serviced. You can find authorized service centers within a certain radius of the ZIP code of your choice by following this procedure:
1. Visit http://www.brother-usa.com/Service/.
2. Select Fax/MFC (color) in the --Please select product group-- selector box.
3. Type the ZIP code of your choice (presumably your home ZIP code or work ZIP code) into the Zip Code: text box.
4. Click on the radio button for the desired radius from your specified ZIP code. (If you want to "walk" your unit into a repair center, click the 20 miles radio button.)
5. Click the Next button. A list of authorized service centers should appear.
Jul 14, 2008 | Brother MFC-3240C All-In-One InkJet...
Error 10186 docucolor 12
10-186 is a fuser problem.Check for jammed paper in fuser or low fuser oil.Might have bad fuser lamp or fuser thermal fuse.
Apr 23, 2008 | Xerox DocuColor 12 Color Copier
Error code 10-162 docucolor 12
Apr 03, 2008 | Xerox DocuColor 12 Color Copier
Docucolor-12 10-389 CODE
That is a fuser jam indication.
  1. Clear the Paper Jam and Obstructions in the Machine
  2. Make Sure the Paper is the Correct Size, Type, Weight, and Orientation
  3. Make Sure the Paper Supply Setting Matches the Type of Paper Loaded in the Paper Tray
  4. Load the Paper Trays Correctly
  5. Fan the Paper, Turn the Paper Over and Reload the Tray
If the above are all correct, you may just have a small piece of paper stuck on a sensor. Just has to be a small piece of paper directly on one of those. Also see if a sensor flag is dislodged. A sensor may be bad but not likely
Mar 11, 2008 | Xerox DocuColor 12 Printer
Docucolor 12 error code HELP
9-357.
Black toner problem.Probably You have low toner sensor defect.
But try first to vacuum and clean black toner dispenser.You must vacuum whole path wich is used to transport black toner to developer unit.Then if printing B/W print only, you must print 10 full color sheets every 100 copies.
Sep 13, 2007 | Xerox DocuColor 12 Color Copier
Xerox DocuColor 12 Color Copier Logo
157 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
