Computers & Internet Logo
Posted on Apr 03, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a windows 98 disk to upgrade to windows 2000. Where can I get one?
Hollyecho Montgomery
Level 2:
Sergeant:
  • Expert 318 Answers
  • Posted on Apr 03, 2008
Expert
Level 2:
Sergeant:
Answers
318
Questions
0
Helped
158192
Points
845
I have bought a BTC extrenal disk drive USB 2.0 CD-RW 52x24x52x. My computer is regestering that it is in the usb port but it will not read any disks. I have an Acer travel mate 2300 laptop
A BTC CD-RW drive is compatible with Windows 95/98/NT/ME/2000/XP and it can read and write under Windows 95/98/NT/ME/2000/XP.
Under DOS, the drive can read CDs only.
The quality of CD-R/RW media varies from different brands. A CD-R/RW media with bad quality causes writing error and makes a CD-ROM drive difficult to read.
Please check if the disc has deep scratches, fingerprints, or other contaminants on the discs surface. Clean the disc if it is necessary.
1. Use the burning software which is provided by original supplier and bundled with this CD-RW drive or download the update file from internet. 2. More capacity of hard disk is needed if using hard disk as temporary buffer. 3. Place the disc correctly. 4. The blank disc needs full format first if using Packing Writing software.
Software such as; EasyCD Creator, Nero-Burning ROM, NTI CDMaker are the only supported.
Flash firmware for Windows mode: 1. Please download the appropriate driver file you need from this page. 2. Run the flash program under Windows. 3. Click on the ¡uUpgrade¡vbutton under the flash program 4. ¡uStatus Upgrading¡vis starting to flash the F/W 5. After flashing, the system will appear ¡uComplete¡IPlease restart your computer¡v, then, restart your computer to finish the flash procedure. Note: 1. BTC do not recommend you to upgrade your F/W, if the drive is working properly and does not encounter any irreclaimable problem issues. 2. BTC is not responsible for any defective reasons if the upgrading process caused the issue. Firmware for windows:V000F.exe
A printer error has occurred. See your documentation
What are the system requirements for using this printer? A: PC Compatible Requirements
- An IBM (r) compatible PC with at least a 486/66 MHz (for Windows 98) or Pentium (r) 133 MHz (for Windows 2000) processor (Pentium or higher processor recommended)
- Microsoft (r) Windows 98 or Windows 2000
- At least 16MB (for Windows 98) or 32MB (for Windows 2000) of RAM (32MB for Windows 98 or 64MB for Windows 2000 recommended)
- 50MB of free hard disk space (100MB or more recommended)
- VGA or better display adapter and monitor
- CD-ROM or DVD drive for installing the printer software
- USB connection: a computer running Windows 98 or Windows 2000, with a Windows-compliant USB port and a shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable-especially a cable more than 6.5 feet (2 meters) long-may cause the printer to malfunction. Apple Macintosh Requirements
- An Apple (r) iMac (tm) series or Power Macintosh (r) G3 or G4 with USB port
- For iMac: Mac (r) OS 8.5 or later (Mac OS 8.5.1 or later recommended)
- For Power Macintosh G3 or later: Mac OS 8.5.1 or later If your iMac is running OS 8.1, you need to upgrade your operating system before installing your printer software. To find out which operating system your iMac is running, select About This Computer from the Apple menu. If you're running OS 8.5 or 8.5.1 on your iMac, Apple recommends that you install iMac Update 1.1. Download the update for your system from Apple at http://asu.info.apple.com. Contact Apple if you have problems installing an update.
- 16MB of available RAM (more recommended)
- 50MB of free hard disk space (100MB recommended)
- VGA display or better
- A shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable-especially a cable more than 6.5 feet (2 meters) long-may cause the printer to malfunction.
3answers
Hi i am trying to upgrade my window 98 to window 7 but explorer won't let me download it how can i upgrade my computer to window 7
:L You Cant Upgrade From WIndows 98 To Windows 7 Your Pc is too old and The hardware is Gonna be outta date
1helpful
2answers
Invalid systme disk. Replace the disk and press any key
its domnickr,
its so we can not install xp in model 1255 it will spoils your hard disk all you can install win98 ED 2 only..... so its wise not to try it and reinstall using win 98 install disk. if format is not possible do format using Fdisk command.
step 1 :enter dos floppy
restart ur lap enter from insulation option.
chance boot perority to floppy disk ie Shift +.
restart lap
enter fdisk in commant
format using instruction for any help mail at [email protected]
I want to upgrade to windows 2000 on the net can i do it.
Hi
If you buy the windows 2000 cd you can install windows 2000 to your computer or upgrade if you buy the upgrade version.
I bought a new laptop tried to install software for my all-in-one printer but the disk handles windows 98,me,2000,xp I have vista
Hi Stoney520, Use your search window and go to your model of Printer, eg, Hewlet Packare 1350 and click the search button. after you get to your appropriate printer manufacturer they will have upgrade software for Windows Vista. Its usually free because everybody upgrades.Good Luck.
Big problem no windows 98 un-locking Key
if the windows xp isn't an upgrade from 98 then it will install on your computer over the 98 without problem, bearing in mind that all information on the disk will be lost once you format it with the disk, but if it's an upgrade disk you might have to check with your friends to see if they have the same version of 98, the other thing if the computer came with 98 installed the product key should be on the case on the back or the side is normal postioning for this altho some techs use to put in the inside of the case.
hope this helps.
2answers
98 loading error message
When you format something you WILL lose all of the data that was there. I would also recomend upgradeing to XP, 2000, or NT. You may need to reinstall the OS. If you need instructions ask me and I can help.
RCF
I have the Windows 98 disk not have lost the key codes, I am trying to reinstall this onto a new hard drive with no operating system so I can then upgrade to windows xp, help anyone?
You don't need a windows 98 disk to install XP. It will load directly from your Cd drive. You have to set the bios to be the first boot disk. It is much easier to install XP on an empty drive than to upgrade.
Delstar mp3 ds 801
If you are running Windows 98 First or Second Edition, you may want to use the driver CD that came with your player and install the driver. If it is not supported by Windows 98 First Edition, upgrade to Second Edition. If you are using Windows 2000 or XP, you may want to check on the Device Manager to see if the player is connected. If the selected player shows an "?", it means you will need to update the driver. Run the Update Driver wizard, and install the player as removable disk.
Grand Canyon Tech
Grand Canyon Tech
