Question about HP LaserJet 2840 Printer
Problem printing from adobe
When i print from adobe only it prints a red tint over the entire page. i can print from word or any other application just fine.
    Problem Solver:
  • 14 Answers
Try using the postscript driver (PS) instead of the PCL6.
Posted on Apr 11, 2008
SOURCE:
CHEQUE PRINTING CONFIGURATION IN CANON LBP3300
How to specify the paper size and page setup
This section describes the procedure for specifying the paper size or page setup when printing from an application, taking Adobe Reader 6.0 as an example.
Note: The screen shots used in this section are from Windows XP Home Edition.
1. Open the PDF file to print with Adobe Reader, and then select [Print Setup] from the [File] menu.
2. Specify the paper size of the document and the printing orientation, then click [OK].
3. Select [Print] from the [File] menu.
4. Select this printer for [Name] or [Printer Name], and then specify the printing preferences.
Note: The printer name displayed in this dialog box can be changed in the [Printers and Faxes] folder (the [Printers] folder for Windows 98/Me/2000).
Jan 27, 2011 | Canon LASER SHOT LBP 3300 Printer
Tip
How To Add Page Numbers to Prints / Copies on a Sharp Copier
This is a simple question that I am often asked, and I decided to put together a little guide on how to add page numbers in various programs/applications as well as from the copier's touch screen. Originally I thought this was something that could be dictated from a Sharp print driver, but it's not. It's accomplished by adjusting the settings of the actual document before you print it out.
Print Page Numbers Onto Copied Documents
1. On the Home screen, touch Copy
2. On the Copy screen, touch Others at the bottom-left
3. On the Others Screen, touch Stamp
4. On the Stamp screen, move to the Page No. tab, then choose the location of the page where you want the page number. You can also choose the pattern or text style that you want the page number to be on the left side of the menu.
5. Touch OK. Your copies will have the page number stamped in the position you chose.
Printing Page Numbers from Microsoft Word or Excel on a Windows PC
1. Open your document
2. Once you're ready to print the document, move to the Insert Tab, and choose Page Number, then choose the position where you'd like the page number printed, and the type/style of the numbering.
3. Your print outs will now have the page number printed on them.
Printing Page Numbers from Adobe Acrobat / Adobe Reader
First of all, Adobe Reader cannot add page numbers to PDF print outs. It's a READ ONLY tool incapable of editing documents. You'll need either Adobe Acrobat Pro, or software similar to what BatesNumberer.com offers.
There is a great video on tv.adobe.com that details how to add page numbers via Adobe Acrobat.
In Conclusion
Make the necessary changes to your document to add page numbering before you print it, or before you copy it. There are a ton of other great tutorials for Sharp copiers/printers at www.youtube.com/equipmybiz
Copier Collin Houston TX Copier and Imaging Expert
on Feb 09, 2015 | Sharp Office Equipment & Supplies
I can print PDFs if I print from Preview (mac) but when I try to
You can try these steps and let me know the result.
=== Problem Printing from Adobe ===
1. Open PDF document.
2. Click on 'File' menu.
3. Click on 'Print'. Print window will open up.
4. Click on 'Advanced' button on the left bottom of the popup window.
5. Put a check mark next to 'Print as image'.
6. Click on 'OK'.
7. Select the 'Current Page' from the 'Print Range' option.
8. Click on 'OK' to print one page of the document and see.
=== Enable Background Services ===
Background Services to reduce the memory for printing issues from applications like Adobe, Power Point,etc.,
1. Click on 'Start'.
2. Right click on 'My Computer'.
3. Click on 'Properties'.
4. Click on 'Advanced' tab.
5. Click on 'Settings' under 'Performance' Settings.
6. Click on 'Advanced' tab in 'Performance options' window.
7. Select 'Background Services' for 'Processor Sceduling'.
8. Click on 'Apply', then 'OK'.
9. Click on 'ok' button on 'System Properties' windows.
Sep 28, 2009 | HP LaserJet 3600n Printer
The printer is printing an addition page each time a page is sent
Are you using a custom written language application or are you using an application such as Word?
It appears that you are using a PJL wrapper around the print job. Please create a print to file (off of the driver screen) and send it to me at [email protected]. I'll be able to look at the job and see what ie happening.
Right now I suspect that you are not clearing out the PJL properly.
Don
Apr 04, 2009 | Lexmark T520 Laser Printer
My Kodak ESP 5 Won't print entire documents, only first page
Scott,  If you are using Mac and Adobe 8 or 9, see solution from Kodak site at:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=12998/7269&pq-locale=en_US
Feb 03, 2009 | Kodak ESP 5 Printer
Can't print to the edge of the page
I don't know many inkjet printers that can print to the edge of the page on all four sides. The area in which the rollers feed the paper often can't be printed to and neither can the very bottom.
Dec 04, 2008 | HP PSC 1210 All-In-One InkJet Printer
Canon i860 won't print deep colors
I had similar problem: everything muted and with brownish tint. Tried everything, finally discovered that I installed wrong cartridge: 6PC instead of 6C. The "photo" cartridges are pretty much the same, make sure you have the right ones: 6C, 6M, and 6Y.
Nov 17, 2008 | Canon i860 InkJet Photo Printer
Printer womt print Adobe pdf file
Hi , Have you checked with -
1. uninstalling and re-instlling the Adobe application once more?
2.the spooler - opn run on your computer and type down "net stop spooler"- let the command window close - then again pen ru and type down " net start spooler " and let the DOS / command window open and close again. Try taking the print with the printer in the ready status.
3. usbcable detection
Step 2 and 3 will not be most effective if the other applications are printing fine.
Try uninstalling and re-installing the Adobe application.
Or else you have to contact the Adobe vendor for further issues. It could also conflict if you have older version of IE in your computer.Becaus Adobe 8.0 is the latest version that might conflict with the older version of IE
Apr 08, 2008 | HP Officejet 4215v All-in-One Printer
HP LaserJet 2840 Printer Logo
117 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
