Question about Refrigerators
The icemaker is leaking again. The cube tray has frozen spill, below the basket is a pillar of ice. Soon the door will be obstructed. A tube was added/repaired on 1/11/08. Something is still not right. I think the icemaker is faulty and should be replaced. George Wieland
  • edgett Jan 04, 2009
    I have the same problem on a GE Monogram refrigerator. Did you ever resolve your issue?
    Problem Solver:
  • 5 Answers
Replace the water valve..........
Posted on Apr 03, 2008
How do i fix my whirlpool icemaker it seems that it gets stuck half way into icemaking and does not produce ice.the model is ed5hhaxv002 it is very frustrating i havce tried a blow dryer to heat the r
Your rubber tube is most likely not freezing up and therefore does not need to be heated but only you would know for certain. My experience with ice makes spans several different models but I've found the most common problem for me with no ice being produced is when the bar that shuts of the icemaker gets stuck in the up position because - ice cubes have frozen into a big clump, Ice cubes have jammed the bar by sticking between the ice tray and the bar, or the gear inside that rotates the ice cube tray is stripped in that area because of previous jams and needs to be replaced.
Dec 01, 2014 | Whirlpool Refrigerators
Ice cube tray does not fill up water feeding tube is frozen.
The problem you are having is caused by water leaking past the=> MJX42111401 Water Inlet Valve Change the MJX42111401 Water Inlet Valve and this will solve the water freezing between ice harvest. On most refrigerators this part can be found on the back of refrigerator and near floor, Let me know if you have other questions, Thanks Sea Breeze
May 24, 2012 | LG LSC27910 (265 cu ft) Side by Side...
Ice cubes not freezing completely before dumping
check evaporator fan if working or u may have a leak , or check condsr fan motor :)
Aug 28, 2009 | Amana ARS2464B Side by Side Refrigerator
My ice maker has quit working. The water is not filling the tray.
Pour 1/2 cup of water into icemaker . If it dumps the cubes when frozen , then check the fill tube going into the icemaker , to see if it is frozen solid . If it is , remove and clean and replace water valve ( drip seeping ) . If not frozen , replace the wqter valve anyway . If the icemaker doesn't dump the cubes , and holds the frozen ice , replace the icemaker , after making sure the coils under fridge are free of dust , lint , pet hair etc.The icemaker needs to be 5 degrees to operate , and , dirty coils could bring the temp up to 6 or higher in the freezer section .
Aug 27, 2009 | Whirlpool Refrigerators
Kitchenaid Icemaker does nothing. Ref. Mod.kscs25Inssoo
This also happened after I changed the water filter. The small black rubber tube that fills the tray was plugged with ice. Instead of hot wash cloths I used a hair drier for a couple of minutes.
Jan 14, 2009 | KitchenAid Superba Architect KSCS25INSS...
Funny fridge noise, kenmore elite trio
I have a Kenmore Elite Trio and the freezer was making a frog sound. I found the solution.
My model number is 596.75523400. The sound will stop when the freezer is opened. It will stop again when the freezer drawer is open and the light switch is pressed to turn off the light. The ice drawer was full but it had stopped making ice.
Here is the fix in less than 10 minutes using only a screwdriver.
  • Take out the two freezer baskets
  • Remove the freezer door from the two slide tracks.
  • Unplug the icemaker electric connection at the back wall. Depress the clips on the side of the plug and wiggle it loose.
  • There are 3 screws that attach the icemaker to the left freezer wall. Remove the lower screw and unscrew the top two about ½ way out.
  • Slide the icemaker up so the slots slip over the 2 screws.
  • Put the icemaker in the sink and run a bit of water on the frozen cubes until they fall out.
  • Take the screwdriver and check the water inlet hose/pipe for ice that obstructs the flow of water into the ice maker.
  • Re-mount using the 3 screws and plug in the electric connector. Make certain the water inlet tube is positioned thru the retaining hole before you remount the screws.
  • Replace freezer door and baskets.
Nov 01, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Ice frozen together
you can adjust the amount of water by popping the front white cover off the icemaker and adjusting a screw . depending on the model the screw will be a flat head on the side of the icemaker or a phillips screw on the front of the icemaker.
Aug 17, 2008 | Viking VCSB423 Side by Side Refrigerator
GE Monogram ZICP360SRSS - Ice cubes spill out of icemaker bucket
sorry, but not unless you want to get into spending some serious time.
Jul 29, 2008 | GE Refrigerators
Lg side by side Ice maker not filling all of the tray/dripping
You may have a restriction in the icemaker.  Remove the icemaker and make sure that there is no ice buildup other than in the cube slots.  Also make sure that the fill tube is clear of any ice obstruction.
Mar 21, 2008 | LG LRSC-26922 Side by Side Refrigerator
Ice accumulating in freezer
There should be a tube that brings water to your icemaker from the back of the fridge into the icemaker. This tube is frozen with water, or the inlet where this tube feed the icemaker tray is frozen. The result is that water cannot go to the ice maker, and instead, goes over the top of the inlet area.
Verify that this is indeed what is going on.
The fix is to remove the blockage/buildup of ice at the inlet. You may have to detach the icemaker to get to it. Be carefull with electricity! Also be carefull as plastic can break under stress!
The tube may be frozen to the inlet, channel locks can be used to gently twist the tube to break it free.
Good Luck!
Jan 01, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
104 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
