EPSOM C62 PRINTER
I have dropped an item on the on / off switch and it is now depressed and will not return. How do I get ti to pieces to replace the switch.
Where would I get a service / repair manual
    President:
  • 2,712 Answers
You can find one here.
Unfortunately, its not free. I think its about $8.99
Posted on Apr 18, 2008
  • 1 more comment
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    If you find that the solution/answer I provided led you
    to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
    rating under my solution.
    I would be very grateful for your show of appreciation.
    Should you have any further questions, please feel free to
    post them here.
    Thank you for using FIXYA!
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    IrishDruid
  • Swilin Sampson
    Swilin Sampson Jun 28, 2008
    Kindly close this thread with a “Fixya” rating if you have been able to
    fix the problem, so that I can remove it from my work queue.
    If the issue is not resolved, please post back with latest developments, what
    steps you took, etc. and I will assist you further as best I can.
    Thank you for understanding,
    IrishDruid
    (We care!!)
Epson Stylus C62, Yanked overfed amount of paper from printer. Printer was jammed. Paper would not feed. After yanking out paper the carridge will not return, paper wont feed, printer shuts doown after a...
Probably not - a belt was either yanked out of its cog or a roller was popped out of its bearings. Since you have nothing left to lose just dismantle the printer (only a screwdriver is needed) and try to put the parts back together. If you fail, just get a new one.
Aug 27, 2010 | Epson Stylus C62 InkJet Printer
Plastic part that holds down black inkjet Epson Stylus C62
yes it is possible however cheaper to replace the whole printer
Oct 30, 2009 | Epson Stylus C62 InkJet Printer
How unstick calculator key - depressed key won't
Just a thought: Use twizzers to grab the key and pull it up.
Hope it helps.
Oct 10, 2009 | Texas Instruments TI-83 Plus Calculator
I want to block drop detector in hp plotter 1050c plus
If you are running the Drop Detector Test then all you have to do is open the Window and insert a thin piece of paper inside the Drop Detector in order to block it.
If you want to disable the Drop detector altogether than you can simply unplug the drop detector. This will result in a system error 0C0030 Bad Drop Detector.
WARNING Switch off the printer and remove the power cord.
1. Remove the Printhead Cleaners (Refer to the User Guide).
2. Remove the following
  1. Right Hand Cover
  2. Service Station Assembly
3. Disconnect the Drop Detector cable from the Service Station Cable.
4. Remove the screw (item 1) that attaches the Drop Detector
Assembly (item 2) to the Service Station (item 3).
5. Remove the Drop Detector from the Service Station
Sep 21, 2009 | HP DesignJet 1050c plus InkJet Printer
EPSOM STYLUS C62 COLOUR PRINTER PROBLEM! HELP! URGENT!
If both lights are flashing, it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and use it to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
If this solution helps you, please rate it; if it doesn't, please provide further information by posting a new comment.
Feb 23, 2009 | Epson Stylus C62 InkJet Printer
Epsom C62
Try putting your question in the correct section: Epson C62. This section is for the CX6600 and is not appropriate for your machine.
Jul 02, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus C62
If your printer documentation includes any troubleshooting information, perform those troubleshooting steps.
If possible, perform a self-test on the printer. These "self-diagnostic" tools can often resolve or diagnose basic issues with your hardware.
also:
-click start, point to setting and then click on printers
- right click on the printer that you want to check and then properties
- verify that all of your printer properties are configures as recommented by your printer manufacturer. to do so, view the documentation included with you printer
-if needed go to control panel and then to printers/cameras and try to set up your printer through there, you may need to update drivers.
May 15, 2008 | Epson Stylus C62 InkJet Printer
Red "drop" shaped light blinking
On my C62 I it usually shows the "Status Monitor" when trying to print, which shows the levels for B/W & Colour.
If not go to CP/Printers, select the C62 (make sure ON) then Properties, then the Printing Prefs button (at bottom). The Main tab usually has this fill level indicator; also try the Maintenance Tab Status Monitor option. These are real awkward to find from scratch but useful when you get to know they're there.
Also if you remove and replace a cartridge you are usually given the option to say whether it is a new or old cartridge - choose new if you know it's nearly full. Don't take NO for an answer to their stupid questions!!!
Clwyd
Apr 15, 2008 | Epson Stylus C62 InkJet Printer
Computers & Internet Logo
241 people viewed this question
David Payne
David Payne
