Question about Mitsubishi WS-55513 55" Rear Projection HDTV
WS-55513 Mitsubishi 55" TV fix
Friend,
I noticed your post regarding the capacitor replacement on your 55" Mitsubishi, but for some reason the link in your post doesn't work. Would you be able to forward any information to me regarding what capacitors usually need replacement, and maybe where you were able to buy them?
Thanks a lot,
Russ
  • 3 more comments
  • Russ Nixon Apr 04, 2008
    Steve,
    Thank you so much for your response. I will order those capacitors tonight so they'll be in the mail to me soon.
    My skill level with a soldering iron I would also describe as 'average,' so I hope I'll be ok. Would you say that bad caps is consistent with the green light that just constantly flashes as soon as I plug the TV into power? It sounds like this is an extremely common problem, and a relatively easy fix for someone comfortable with soldering a little bit.
    Thank you so much,
    Russ
    Okay, very good to know. I will definitely keep you posted on my progress. I can't wait to get started.
    Talk to you soon, and thank you again for your kind assistance! You have been most helpful.
    Russ
  • Russ Nixon Apr 10, 2008
    Steve,
    Thanks again for your guidance on this project. My parts arrived yesterday, and I began work. With your guidance, I was able to get the platform slid out, and I see the board that you are talking about. I actually just moved into a new house, and I can't find my skinny screwdriver that I'll need to unmount the DM board, but I'm darn close! I will definitely keep you posted.
    Something funny happened - as I was taking the TV apart, I discovered that someone else has tried this procedure in the TV's past. I found a step-by-step article from this website that details how to do this same procedure, rolled up inside the TV. I HOPE that this means someone started the procedure, and maybe decided they didn't want to screw with it. I got this TV for free from a friend of a friend, and I think he may have started this procedure before he may have decided to just buy a new TV instead.
    I will probably get that DM board out onto a table tonight... I wonder where my soldering iron is. Probably in a box somewhere. :)
    Thanks a lot,
    Russ
  • Russ Nixon Apr 12, 2008
    Tonight I was able to get the DM board out of the TV, and I believe I
    see the capacitors in question. However, I am a bit concerned - the
    capacitors are not swollen at all, and they actually look like they've
    already been replaced. The solder joints look a little bit different
    than all of the others...
    Nonetheless, I still plan to replace them and see what happens. I don't see very many articles around these forums that describe a scenario where replacing the capacitors DOES NOT fix the problem! It seems like they're always to blame. I have the parts, and I have the DM board removed, so I have to give it a shot.
    More to come... Thanks.
    Russ
  • Russ Nixon Apr 13, 2008
    Steve,
    Bad news, the capacitor replacement did not do anything at all. I was suspicious when I saw evidence that they had been replaced already. Bummer!
    I have read elsewhere around the internet that there is a way to put the TV into a diagnostic mode that is supposed to flash a diagnostic code to help point to the failure, but I haven't been able to get it into that mode. Any tips on that, or do you think it will tell me anything important?
    At this moment, I feel like I may be looking at purchasing a whole new DM board, unless there are any other easily-replaceable components on it that might have failed. Any other advice you can offer me?
    Thanks so much,
    Russ
    Genius:
  • 1,694 Answers
Www.chrisandnat.com/projects/blinkingtv/blink.htm ...
Also,check the three surface mount 4 amp fuses on the trace
side of the board................................T.
Posted on Apr 24, 2008
    Problem Solver:
  • 5 Answers
Russ,
I just checked the link and the bookmark I had, and it seems the post has been removed. It was in the How-To section and included pictures and part numbers for the capacitors. I will try to find it and let you know if I have any luck.
Here is the part number for the capacitors and a link to the place I bought them. They were very easy to deal with and their shipping was FAST. You can buy in bulk to save a little money. I bought 10, even though you only need 4 for the repair, this way I have spares in case it happens again (or if I screw up soldering)
They are about $.39 each if you buy 10.
The part # is P13119-N
and here is the link
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=P13119-ND
Without the repair link I can try to explain as best I can what the repair involves.
You are looking for the DM board. It sits upright in a metal enclosure on the left side of your TV when you are looking at it from the back. You will have to take a few things off as well around it to get it out. Once you pull the board out you should see 4 capacitors grouped together at the upper right corner of the board (I think it was the upper right...it's been a while) you will likely see that the tops of these capacitors are bulged out (clear indication of blown caps) Simply replace those 4 with the part number I linked to and you are back in business. I would say the repair took me about 2 hours start to finish and my skill level is only average.
I hope this helps, I will still try to find that link as it was very useful and even had pictures.
Good luck, hope to hear back with good news.
Steve
Posted on Apr 03, 2008
  • 1 more comment
  • Anonymous Apr 04, 2008
    Russ,
    This is the exact model TV I have and the blinking green light was the exact same problem I was having, so I fully expect it to be the problem with your set. It is fairly common as you've probably seen searching this site. Once again, good luck.
    Steve
  • Anonymous Apr 10, 2008
    Russ,
    Sounds like you have a good handle on it now....hope to hear good news soon.. :)
    Steve
  • Anonymous Apr 12, 2008
    Thanks for the update Russ....now I want to hear good news next time. :)
SOURCE:
Mitsubishi WS-55513 55 in. - Picture to latge for scheen
Change your Display Format (widescreen mode) . You're using ZOOM. Press FORMAT on the TV remote control to cycle through the available display formats.
Feb 09, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55513 blinking light
Try first unplugging power cord for one hour.
Oct 06, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Blinking Light Problem on Ws-55513
If bad capacitors are the problem then replacing them will involve soldering.
If the problem is something else less visible then fault finding will be difficult without the proper service manual.
http://www.completeservicemanuals.com/mitsubishi/crt-projection-television/ws-55513-service-manual/prod_37.html
This will show the correct disassembly and test procedures.
Good luck.
Oct 20, 2007 | Mitsubishi WS-55513 55" Rear Projection...
I have a mitsubishi wd-62725. my tv wont turn on and the timer light wont stop blinking.
Sounds like the classic bad capacitor problem on the DM pwb. You can get the V26 DM pwb repair kit at the following link which will usually repair the issue. Kit contains replacement capacitors and CD with chassis dissasembly and explains which capacitors need replacement.
http://servicemanuals.vstore.ca/
Nov 28, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Code 21
Its very frustrating when we think we have something fixed and then forget to do something or hook something up wrong to only make what seemed like a simple repair much more complex...Here are a couple manuals if you don't have them that will help..Not sure if the last are the same as your TV but thought I would post them all in case they are...Good luck!
Mitsubishi Electric WS 73513 Service Manual Mitsubishi Electric WS 48513 Troubleshooting Manual Mitsubishi Electric WS 48513 Service Manual
Feb 10, 2018 | Mitsubishi WS-55513 55" Rear Projection...
I got a Mitsubishi WS-55513 55 in and the guy said i have to replace a fuse do you know anything about a fuse and the cost
What does the set do when you try to turn it on? What does the led light on the front of the set do?
let me know so i can help
Tim Nolan
Sep 17, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi 55" Projection TV / Horizontal Wavy Lines at Start Up
this is very common with these sets. the fix is to replace 11 very very smal capacitor on what is known as the hypermodule. The ideal sitation is to replace the hypermodule. if you can find it. I can do this repair. I have done about 10 at the shop. if you need to i would suggest finding someone who is very experence in surface mounted repair
Mar 18, 2008 | Toshiba 65H81 65" Rear Projection...
Mitsubishi WS 55513...
www.chrisandnat.com/projects/blinkingtv/blink.htm
Also,check three 4 amp surface mount fuses on trace side
of board.............T.
Mar 10, 2008 | Mitsubishi WS-55513 55" Rear Projection...
WILL NOT TURN ON
Did you say you got it from an X friend? LOL Sorry, its not funny, It obviously didn't like being moved. Sounds like solder problem in the power supply somewhere, hunt round locally for a good shop. (probably a few hundred dollars to get fixed.)
Aug 01, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
254 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
