Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Ice maker We purchased a new fridge with water/ice on the door. The ice maker works great except when trying to get ice out of the door - it keeps freezing. We have to take the whole bucket off the inside and dig out the ice cubes that have gotten stuck in the opening. They are not melted, just stuck. Any ideas???
    Novelist:
  • 184 Answers
MAKE SURE THE DOOR CLOSER IN THE DISPENSER IS OPERATING PROPERLY. IT SHOULD SLOWLY CLOSE THE DOOR AFTER YOU STOP PRESSING ON THE PADDLE.
EITHER THE DOOR IS CLOSING TOO QUICKLY, NOT AT ALL, OR THE DISPENSER IS RUNNING AFTER THE DOOR HAS CLOSED. CHECK THE OPERATIONS OF EACH OF THESE AND SEE IF YOU CAN TELL WHICH.
Posted on Apr 04, 2008
SOURCE:
My Frigidaire refrigerator works find; Freezer stays cold but doesn't freeze food or ice
Its defrost assembly parts issue or the compressor is getting waek indication.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
There isnt any water getting thru to the icemaker. i changed the watervalve and still no water i cannot locate the water filter even tho i removed the bottom grill, water is still getting to the water...
if you put a new water valve on the fridge then you either have a bad ice maker or the line is frozen where the water fills the ice maker,a bad water valve will make the line freeze,water keeps dripping through the valve and freezes the fill line behind the ice maker cup,you can remove the ice maker and check the fill line,if it's frozen get a hair dryer,shut down the fridge or unplug it and blow the hot air into the fill line until the ice melts,then get a piece of wire and after you reinstall the ice maker pop off the cover to the ice maker and jump it out with the wire,stick it in the t and h for 15 seconds and pull it out,if the ice maker is good it will start turning and when the arms get at like 11 oclock it should fill,also you can jump out the fill valve from the ice maker,stick it in v and L and if water fills the ice maker you know you have a bad ice maker if the fill line isn't frozen.hope this helps.next time you need help send the model number,on your machine look in the fridge section on the right hand wall up near the ceiling to find it,if it's older look down near the bottom hinge on the fridge door and you'll see a tag with the model number.good luck
Sep 12, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
SMEG FA550X fridge freezer. The ice maker has stopped working, freezer has thick ice built up at bottom, fridge does not appear to be keeping food cold enough as milk etc is going off quickly. Two to...
Your Ice maker may be the cause. if it is not holding water the water may be landing on the bottom and freezing, causing the ice build up and obstructing the air transfer from the freezer to the refrigerator. You can remove or replace your Ice maker. Then you will have to defrost your freezer to get everything back to normal.
May 11, 2011 | Microwave Ovens
Ice maker freexes ice together
maybe too much water going in to the ice maker
Jun 30, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Freezer and icemaker freezes, jams.
I have run into this before and found it very helpful to re-level the refrigerator. By leaning the fridge back toward the wall about an inch helped keep the water and ice in the tray. Remember to remove items that block air flow in the freezer. Remove the ice bin and clean it then start over with the fridge leaning back a little. Hope this helps.
May 01, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Ice Maker not making ice in new fridge
make sure the metal bar is in the down position
Apr 16, 2009 | Refrigerators
Water does not flow through the dispenser
sounds like the sensors are playing up causing the bottom of the fridge to freeze, this will also cause the water reservior to freeze thus no water to the ice tray and water dispensor. do a full defrost then see if you gain back all the functions proving the sensor fault.
Apr 05, 2009 | Frigidaire FRS26R4A Side by Side...
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water line in freezer for ice maker keeps freezing
I have had this happen to me before. What happens is the water fill valve
does not completely close and the tube will freeze shut as a small ammount of water will continuosly dribble into the tube when the valve shuts off causing the tube to freeze solid. I tried to clean the valve but that did not work so I replaced it and that ended the problem. A new valve is not expensive.
Oct 08, 2008 | Whirlpool ED2FHEXN Side by Side...
Lg refrigerator LFX25960SW
do not purchase lg refrigerators or products. they are junk!
Aug 15, 2007 | LG LRFD25850 French Door Refrigerator
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
130 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
