RCA DRC247N DVD Player
Problem for RCA DRC247N DVD Player
TV Screen
By Bette4 on Apr 17, 2008
There is no picture on the screen of my player. Used to work just fine. Remote working OK also.
Bette4
Comments:
Apr 17, 2008
- No tv-dvd connection. This is a portable dvd with tv included.
Apr 17, 2008
- Power supply OK. All functions work except picture itself. Thanks anyway.
Apr 17, 2008
- No HDM1 button or output. What is HDM1 anyway? Thanks.
Apr 17, 2008
- My cable input reads "DC in 9V". That's the only place the cable fits. I don't know what a ribbon cable is. Maybe beyond my expertise. ?
Apr 17, 2008
- The manual troubleshooting page that came with my dvd doesn't seem to address my problem. Don't know why I just can't call or write RCA, but no add. or tel.no. in manual. Cannot solve my problem by list on TV because I hv no picture.
Apr 17, 2008
- Actually, my unit is an RCA DRC615N but was told on-line to use the 247N as 615N colutions not available.
Apr 17, 2008
- No function switch. I hv a yellow input "video" and a white input "audio" and an s-video input (all on the side of the dvd) plus volume and phones input.
Apr 17, 2008
- The on-line manual is same as my manual that came with the unit.
Apr 17, 2008
- These are output plugs to use a TV. I hv the cables. Also, do u mean a line select switch inside the unit where I wd hv to unscrew the bottom?
Apr 17, 2008
- Going off-line. Will check again later. Thanks.
Solution #1
posted on Apr 17, 2008
Not Rated)
micromaster
Rank: Wiz
Rating: 82%, 762 votes
Check the ribbon cable connector could be broke, or it has a defect.
Let me know.. Post back again..
Thanks
Comments:
Apr 17, 2008
- yah, thats what i mean a built-in video used a ribbon cable to still connect to the main board..
Solution #2
Not Rated)
The Machine
Rank: Wiz
Rating: 83%, 374 votes
What king of connection are you using between the tv and dvd player? Is it component, composite, dvi, hdmi?
Comments:
Apr 17, 2008
- I meant "kind" not "king"...
Apr 17, 2008
- Right! Sorry, did not notice that.
Could be the back light, you would see a VERY faint image if that was the case.
Does the unit have a TV out? If so, did you try it to see if there is picture?
I suppose there is sound then? If the TV-out works and you've ruled out the backlight then either the unit is not processing an image or the LCD is not getting power. The best this you could do in this case is to open the unit up and look for obvious problems like loose cables, or burnt or loose components.
Apr 17, 2008
- The DC 9V is for the AC adapter so that you can run the DVD player without batteries, or recharge it's battery. It doesn't have a yellow TV out?
Apr 17, 2008
- Can you provide the full model number then as DRC247N is a stand-alone DVD player and not an all-in-one. Thanks.
Apr 17, 2008
- Is it possibly the DRC628? That is RCA's current portable DVD player model.
Apr 17, 2008
Does your unit have a function switch on it? It should be set to DVD, not usb or av in.
Apr 17, 2008
- If you press the setup button on the remote do you see the menu on the screen?
Apr 17, 2008
- According to RCA to have the machine replaced or repaired under warranty you are to ship it to:
Thomson Inc.,
Product Exchange Center,
11721 B Alameda Avenue,
Socorro, Texas 79927
Only if you have proof of purchase date and you have owned the unit for less than a year. You must pay labour for repairs between 91 days and 1 year after purchase.
Apr 17, 2008
- Are you certain those are inputs and not outputs?
If they are in fact inputs, do you have another device you can use to test this unit with? Plug in a playstation, or a stand-alone DVD player into it to see if you get a picture. You would plug in using either S-Video or the Yellow RCA connector. Even a VCR or cable/sattelite box would work this would turn the DVD player into a TV and you confirm if your screen is working or not.
Apr 17, 2008
- I found the manual for the DRC612N, does your 615 have a line select switch? It should be on in do use the internal display, on out it would expect to be plugged into a TV.
Apr 17, 2008
- Actually that was wrong, you want out to watch a DVD, in to watch the output from another device.
Apr 17, 2008
- No on the 612 it's between the dc 9v jack and the video jack.
Apr 17, 2008
- If you could use the cables and plug the DVD into a TV to try to see if it can output to TV? Thanks.
Solution #3
Not Rated)
coolguy008
Rank: Wiz
Rating: 83%, 591 votes
Check if all the connections are tightly fixed in the holes.
If you are using the HDMI output, you must press the HDMI button on your remote control.
Goodluck..
Solution #4
Not Rated)
maklean
Rank: Guru
Rating: 86%, 641 votes
It may be a power supply problem.If you are not familiar with electronic repairs better take it to an authorized service shop.
Comments:
Apr 17, 2008
- Below have a look at your online manual
http://www.fixya.com/support/p517623-rca_drc247n_dvd_player/manual-20284
Apr 17, 2008
- see troubleshooting page 1 at online manual
Popular Solutions for RCA DRC247N DVD Player
Questions and Unsolved Problems for RCA DRC247N DVD Player
Do you recommend RCA DRC247N DVD Player?
Answer
Answer
how do i take off the progressive scan after i enabled it and now my screen is un recognizable. i... (More)
Answer
My dvd player is starting to freeze up while playing a dvd. Is there anything I can do to correct... (More)
Answer
I am unable to play my burnt DVD-R in my RCA player. What can I do?
Answer
i was putting in code for new remote when the screen started flicking vertically and does'nt stop.... (More)
Answer
I have hooked up by DVR using component cables to a Samsung LN32B360 tv and the picture when I view... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Players Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
