Yamaha 4hp outboard does not pump much water, we replaced the entire pump assembly. I removed the lower unit and rigged a water line to the water intake tube but very little water comes out even with the additional water pressure. Could it be the thermostat (if it has one) Removed the powerhead from the base but it is difficult to tell where there might be blockage.
    Genius:
  • 3,422 Answers
If no water enters the washing machine, but the drum starts turning (as though washing normally) then you should stop the washing machine as there may be a fault in the pressure system that controls the levels of water. This fault can cause the timer to receive a false signal that water is already in the washing machine and the heater may be energized. This can damage the heater or burn the clothes inside. A blocked pressure chamber can trap air in the pressure tubing and leave the pressure switch on. If this happens, when you put the washing machine onto a wash program it doesn't take any water in and starts washing because it thinks there is water inside. This fault should also prevent the washing machine going into spin though too.
If the washing machine is not taking in water from one side only, (i.e.just the hot or just the cold) then the obvious thing is to check that water is actually available through the plumbing from the offending pipe. Turn off the tap on the affected supply and unscrew the hose from the valve at the back of the washing machine machine. Then simply hold the fill hose into the sink or into a bucket and turn the tap back on. If water comes through at a decent flow rate then check the filter in the water valve on the washing machine. You can pull it out with a pair of pliers and clean it. However, this will only explain your fault if it is severely blocked up, which is rare.
If no water comes through the hose, or the flow is very slow, then the fault is in the plumbing. This is actually also quite rare, but if your machine was plumbed in using those self plumbing taps that clamp on to the copper water pipes then they do sometimes get clogged up and need the hole clearing. If this happens to the cold supply it can be achieved by turning the stop tap off first, but if the hot supply is blocked - which is the most likely of the two - then you have to turn off the cold supply and then drain the hot water tank by turning on the hot tap until the water is drained out (unless you know where the valve is to turn the hot water off in your water cylinder).
Goodluck,
Please don't forget to rate the solution.
Posted on Apr 03, 2008
    Genius:
  • 1,665 Answers
The thermostat must be warm to let the water flow out
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Apr 03, 2008
    Who asked for a washing machine?
    Around cylinder liner there are passes of circulating cooling water.
    If there are salt deposits clogging , they must be removed using salt-deposit disolver there and in all water circuit, so the water can circulate freely.
    Water pump usually has two rubber impellers. They must better be replaced to ensure efficient pumping.
    Inspect also the condition of suction area to be well cleaned.
After running my johnson 4hp 2s for a couple of hours in the bay it starting giving a strange noise and then cut out.i managed to get it started again but coudnt get above half speed.
Hey Pete.. this sounds serious.... will it rev up while in neutral? If it revs freely and high.. the power head should be ok.. if it will NOT rev up freely and high.. STOP - you are causing more damage..
Check the compression with a good gauge..it should be 125psi minimum.. with no more than 10 psi difference between any two cylinders.. DO this WITH the THROTTLE WIDE OPEN...
Can you turn the propeller by hand while it is in neutral?..Of not.. this is the problem.
Shop Evinrude Outboard Parts Johnson Outboard Parts
Lower Unit Replacement Rebuilt Lower Units Aftermarket Lower Units
REMANUFACTURED LOWER UNITS
https://www.boatengine.com/lower-units/remanufacture
Refurbished Lower Units for Yamaha Mercury OMC Johnson Evinrude
Jul 09, 2017 | Cars & Trucks
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
https://www.youtube.com/watch?v=R6wVMc8GD0w
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
https://www.youtube.com/watch?v=DnU7vKcJkeE
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views · 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
https://www.youtube.com/watch?v=_ygxZSxU6-I
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
https://www.youtube.com/watch?v=Hv8gXqsO2fg
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
How do I winterized a 40hp evenrude 2stroke
There are videos all over YouTube that cover this subject quite nicely.
winterizing an outboard motor YouTube
Nov 15, 2014 | Boating
Yamaha 40 hp outboard
Look below lower mountings you will see the shift rod with along nut and a lock nut,undo long nut,do this with motor in reverse gear,some 40s have a stainless plate cover which you have to remove first
Aug 18, 2014 | Clymer Marine Maintenance and Repair...
1988 evinrude outboard
You need to replace the oil seal on the main shaft located below the water pump. Your lower unit gear oil is seeping into the water pump housing. I had the same problem on a Yamaha that I just repaired. Not a hard job. 7_12_2013_1_59_18_pm.png
Jun 17, 2013 | Boating
Yamaha 4HP outboard - cannot pull starter cord - jammed.
Engine or gearcase seized...
Remove the recoil starter ( 3 bolts and the startingear link)
If you can turn the flywheel slightly: Gearcase seized
If you can't turn the flywheel at all: Engine seized.
In both cases: If you can't disassemble and have the job done yourself, forget that motor...
Dec 09, 2012 | Clymer Marine Maintenance and Repair...
Gear shifter for 40 h. p. mariner outboard
With your lower unit off have someone shift the engine into forward while watching the gear shift select shaft's rotation,let gearshift remain in forward,now place your lower unit in forward and reinstall. In the future just put engine in forward when installing a water pump as there won't be a need to move gearshift
Jul 23, 2009 | 2004 Mercury Mariner
Suzuki 4hp two stroke impellar
Dropp the lower unit, should be only 4 bolts holding it on. Impellar housing should be located right on top of the lower unit. four screws it the housing slides off the shaft, insall in reverse order with ne gaskets, make sure you re- align the waterhose/pipe from the lower unit back to the head
Mar 22, 2009 | Boating
Washing Machines Logo
180 people viewed this question
Top Washing Machines Experts
