Question about Refrigerators
Magic Chef Refrigerator Model # CTB1723AR
The refrigerator appears to be in very good condition. I've owned it for five years, however, I do not know the age of the unit since it came with the house. It has run perfectly as a second refrigerator in our basement. Suddenly it loses all refrigeration....no water leaking even after I left the unit unplugged with doors open for 24 hours. Any idea what may be happening here?
Thank you
  • robert samples May 11, 2010
    is the compressor running
Yes it is
Posted on Apr 16, 2008
That means your ref.is not functioning,simple just show to the doctor of refrigeration or technician and he will tell you the exact problem hehe okey.so many cause maybe not functioning hermetic compressor,no freon gas cause of leak,or the wiring is cut by rat..
Posted on Apr 03, 2008
SOURCE:
Magic Chef RB15FA0AA Refrigerator I have this refrigerator and it still works fine. I would like to know it's total cu ft capacity. Also what the refrigerator and freezer each cu ft capacity is.
After some work online...I found this advertisement buried among a bunch of other ads:
Magic Chef RB15-1A: Top-freezer style with 14.6 cubic ft. capacity and optional ice maker -- $439.
So, as I suspected the "15" in the model number is the cubic feet (total I would say). The 14.5 is probably actual, with the unit "rated" as a 15 CF.
Naturally, to find the cu. ft of the freezer, measure in inches then multiply the width X height X depth and divide that resulting rather large number by 1728 to get your cubic feet of the freezer.
You could also do the same with the refrigerated section, and add the results together and they should be near 14.5 total.
Aug 03, 2015 | Magic Chef Refrigerators
What is the Cu Ft. of my Magic Chef Refrigerator
Hello there.
First you need to find your refrrigerator Model number.and put that in your question friend.
Go here and see for yourself how many Magic Chef models there are friend.
http://www.ebay.com/sch/i.html?_odkw=magic+chef&_from=R40&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR4.TRC1.A0.H0.Xmagic+chef+refrigerator&_nkw=magic+chef+refrigerator&_sacat=0
Sep 21, 2014 | Magic Chef Refrigerators
Why won't my magic chef model rb171a refrigerator stay cold?
I recently had the same problem on a Westinghouse fridge freezer. There was a vent bringing cold air from the freezer to the fridge. This vent was in the freezer low down behind the evaporator coil. It had become blocked when a piece of insulation had moved over several years. Might be worth checking.
May 12, 2014 | Magic Chef Refrigerators
Where can I find out where the drain hose is located on my Magic Chef refrigerator?
It should be under the fridge. If you remove the lower acess panel on the back you should see a little tray wich is your drain pan. Mike
Mar 19, 2013 | Magic Chef Refrigerators
I have a Magic Chef refrigerator Model # GT17Y7A that I want to know what cubic feet it is? Can you help me?
I believe if you look under magic chef with the model number and serial number on google it will tell you, my sq ft is not written in the fridge.
Feb 23, 2011 | Magic Chef Refrigerators
Loud buzzing noise on a Magic Chef compact refrigerator help!
Disconnect power from unit. Remove the cover at the bottom, rear. Examine all refrigerant tubing for contact with other tubing or other surface. Carefully adjust the tubing to prevent contact vibration.
Sep 12, 2009 | Magic Chef CTB1821AR Top Freezer...
Magic chef refrig model # MCBR1000W defrost thermostat
RepairClinic.com is a fantastic online site for ordering appliance parts.
Jul 29, 2009 | Magic Chef CTB1821AR Top Freezer...
How many cubic feet (what size) is my fridge?
Need the cubic feet on our 16 year old Amana BX22A2W.
Jun 23, 2008 | Magic Chef CTF2125 Top Freezer...
Refrigerators Logo
324 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
