Trying to reconnect a set of Harman Kardon candlestick computer speakers to a Dell Dimension E520 computer. I got three plugs and dell has 6 holes...what the heck goes where? Nothing I seem to try works...
  • Anonymous Mar 25, 2014
    how to sync my dell dimension e520 with Jawbone speaker. Not working. Help
    Sergeant:
  • 202 Answers
Hi rjlevesque
For the speakers, you need only connect to the GREEN jack at the back of your computer. It's OK to leave the others blank.
Your two HK speakers will, with one wire, connect to each other and, w/ another wire (usually having a GREEN connector on the end), connect to the computer.
I'm not sure what the 3rd wire is unless it's (1) the power connector or (2) for connecting to a sub-woofer.
Does the speaker set include a sub-woofer? Or does it include a "surround sound" or 3rd speaker?
You can find pics & symbols (the symbols are helpful if your sound card jacks are not color-coded) for (3) of the most common audio connections HERE.
Usually the color of the connector on the wire is matched to the sound card jack w/ the same color. (green to green; pink to pink; blue to blue).
green = speakers
pink = mic
blue = line in
Make sure you are connecting to the active sound connectors - the ones you used b4 the HK speakers.
If you have "integrated audio" (audio that is built into the motherboard) and you have an audio expansion card installed on the computer as well, one may be disabled or not selected in your computer's audio configuration.
If that's the case (that you have two sets of audio jacks to choose from), try connecting the speaker wire from the HK speakers 1st to the green jack (or the jack marked w/ the symbol of a speaker) at the bottom of your computer. (There'll only audio jacks here if there is an audio expansion card installed on your computer.)
If that is the case, there'll be other (usually) colored jacks running horizontally next to the speakers jack.
If you still have no sound, connect the speaker wire to the GREEN jack that is (usually on Dells) up by your PS2 (round - one purple and one green) keyboard and mouse connectors (also at the back of your computer). The other jacks in that set (of audio jacks) will be situated vertical to one another and on the left-most side at the back of your computer.
Please, let us know if this response was helpful for you or, of course, if you have any further questions.
Thank you
BJ
Posted on Apr 03, 2008
  • Anonymous Apr 03, 2008
    To clarify....
    By (audio jacks oriented horizantally) "at the bottom of your computer" I meant meant to say at the back of your computer towards the bottom. The pics you'll see at the link I gave you will best depict what I'm describing for this example.
  • Anonymous Apr 17, 2008
    Hello rjlevesque
    How did it go? Did the information and links I provided you w/ enable you to get your speakers hooked up OK?
    I DO hope that is the case. :) If it isn't, please, post back here and we'll continue to assist you.
    If it is the case, would you kindly take just a moment to close the problem by assigning a FIXYA rating for my "solution"? I would be very grateful for your generosity and show of appreciation.
    Thank you once again for using FixYa! Have a beautiful day.
    BJ @:)
6ya staff
SOURCE:
Will Harman Kardon HK 206 speakers work with Windows 8
I just purchased a Dell XPS 8500 with Windows 8 and decided to keep using my old Harmon Kardon HK 206 speakers because I'm quite satisfied with these speakers. When I hooked them to my new PC, Windows 8 recognized them right away. The speakers work great on my new PC. Try going to the Control Panel and see if your speakers were recognized. (On my PC they're referred to as "Speakers (Realtek High Definition Audio). That's due to the default drivers in Windows 8. As long as you see speakers in the control panel, you should be OK. In that case you should check your connections. If you don't see speakers in the control panel, go back one screen and select add a device and let Windows 8 scan for any device that it hadn't recognized before.
Jan 23, 2013 | Harman Kardon HK206 Computer Speakers
No sound from brand new speakers Dell Dimension e520
please check the connections and speaker settings.
Jul 25, 2010 | Dell Dimension E520 PC Desktop
Somehow I apparently deleted the softward drivers for the speakers - my computer says I have no speakers I have unplugged, restarted and plugged in again to no avail - still no sound dell dimension 4500...
Go to www.dell.com (The site of your computer manufacturer), click on "drivers and downloads" which is at the bottom of the page, after then, click "select a model". Select the product of your computer and the model, there you will find the drivers for your computer speaker then you can download. You can download any other drivers that belongs to your Computer.
I wish you the best.
Nov 05, 2009 | Harman Kardon HK695 Computer Speakers
Dell dimension e520, speaker problems
Don't you have a CD that have the drivers needed? There should be a support section in the Dell website. I'm talking about the drivers of course, but, is everything hook up right?
Oct 13, 2009 | Creative Labs Inspire 5200 Computer...
Harman-Kardon HK695-01 Speakers Connection Quesion
According to the manual
http://tv.manualsonline.com/mdownloads/14ae515f-03bc-a2d4-8940-672bfa19f017.pdf
leave the black connector unconnected.
Hope that helps.
Oct 02, 2009 | Harman Kardon HK695 Computer Speakers
No sound coming from my speakers
Hi !!
Cause: Drivers for the sound card are removed.
Here's the link to download the drivers for the Dell Dimension 2350 sound card.
http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R56339&SystemID=DIM_PNT_CEL_2350&servicetag=&os=WW1&osl=en&deviceid=2430&devlib=0&typecnt=0&vercnt=2&catid=-1&impid=-1&formatcnt=1&libid=3&fileid=67126
Download the drivers first.
Install the drivers & Restart the machine.
Restart the machine & you are good to go.
Regard'
Anurag Shukla
Sep 07, 2009 | Harman Kardon Audio Players & Recorders
No sound
You can find the drivers on the Dell website under the support section. You will need your computer model or your Dell service tag. Hope this helps & please remember to rate my answer. Thanks.
Jan 09, 2009 | Harman Kardon HK695 Computer Speakers
Replacement speakers
Try www.support.dell.com
www.bestbuy.com
Theses sites do sell spekers just enter what you are looking for.
Jan 04, 2009 | Harman Kardon HK595 Computer Speakers
Speakers
Hook on speakers to the right jack.
Most of times it is the Green Jack you must plug in the speaker. See for the speaker icon below the jack, that should give you the clue...
Hope this helps...
Jun 21, 2008 | Computers & Internet
HK206 SPEAKERS WITH USB PLUG
have you plugged anything else in to make sure the usb port is working? does the computer recognize the usb speakers when you plug the usb plug into the computer? do the speakers work on another computer? if you wiggle the usb wires around does it make a sound through the speakers? eliminate these questions so that we can move on to isolating the issue.
Oct 13, 2007 | Harman Kardon HK206 Computer Speakers
Open Questions:
Computers & Internet Logo
231 people viewed this question
Ekse
Marvin
Marvin
