Question about Alesis Multimix 8 USB 8-Channel Mixer Spdif System
Problem hearing a new recording after I press '2trk ito mix button?
I have always had this infuriating problem. The mixer is excellent but I can't seem to find a work-round to how to monitor a new track recording (I use Magix 12 deluxe software on my computerwhich is great). I can hear what I've already recorded but when I press the '2 trk to mix' button to stop the already recorded music from going on to the new track I can no longer hear what I am playing or singing. I can just about manage with acoustic guitar and vocals but when I use the electric or bass guitars or keyboards, I hear nothing as I record although I can see the signal being recorded and in fact I have recorded dozens of songs labouring under the problem but I am now fed up wither restriction when all I desire is the the new sound to come through the headphones as well as the previous recordings. Have you any idea how to solve this problem?
Alex
  • 192 Answers
You need tro set up the monitoring capability in your recording software under either hardware profiles or audio settings. All "good" recording software has this monitoring capability. There's another thing - I got rid of my Multimix 8 USB, because it wasn't allowing me to monitor as I recorded new tracks. At first it did, then about a year into using it, this function stopped, and when I investigated further, it was coming up as a single duplex sound card in my hardware profiles in Windows XP. It is as if that functionality of the soundcard component had burned out. Maybe on the circuit board...
I now have a gina Echo that I bought off eBay, and it was the best thing I ever bought. It is a hard card - no latency! Full monitoring! 24 bit recording! A hard card with a breakout box instead of USB! My recordings have never sounded better. The best thing about it is that I sold my ALesis adn was able to by the gina and have money left over - they are out of production (stupidly) and can still be purchased for anywhere between $50.00 - $80.00
You may or may not have a problem with your mixer - check your software settings first. If that isn't the problem, eBay is open 24 hours...
Mark
Posted on Jul 04, 2009
    New Friend:
Well, i am mainly an old school guitarist and not real familiar with some of the new production tech. i have recorded some stuff but always on the business end of the tracks. i would recommend running the signal from your bass or guitar through a pre amp. sansamp makes a pedal type designed for direct recording in situations like yours.the signal from an acoustic guitar is typically weaker than the other instruments you mentioned. make sure the channel you are using is not muted and not "clipping".try a different channel.try panning your pre recorded tracks to the right and then your live channel to the left.
Posted on Aug 26, 2010
3 Suggested Answers
SOURCE:
SOURCE: Multimix 8 USB
sounds like you ports on your computer got all messed up. you should call tech support on you computer and they can tell you how to fix it.
Posted on Oct 18, 2007
SOURCE: cant record vocals while listening to beat without the beat being recorded twice
so how do i do it
Posted on Oct 17, 2008
My Hamilton Beach model 63220 mixer won't mix motor is running but mixer is frozen and will not turn
If mixer is locked in down position, and you hear motor running, the problem could be worn gears in mixer head. Check warranty and return to place of purchase or take to small appliance repair shop for estimate.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apr 20, 2016 | Hamilton Beach Food Mixers
What USB adapter is best to use with the GXL2200?
If you're going to use a mixer anyway, it'd probably be better to run the mixer into the line-in of the computer. Even better would be to just get a USB recording interface, and do the mixing in the software.
Otherwise, Behringer, Alesis, Yamaha, and probably other all make USB mixers that should be of similar quality (i.e., very low).
Mar 20, 2014 | CAD Microphones GXL2200 Professional...
Latency during recording - makes playing in time impossible
I can totally relate, Tom. Good old multitrack recorders!
This may sound stupid, but you don't have like a slap back delay turned on by mistake, do you? Other than that, I'm afraid I'm not much help.
Mar 11, 2014 | Behringer Xenyx 802 8-input 2-bus Mixer W/...
How do I attach power amp to 1832 mixer
There are a number of configurations for a mixer like the 1832, the most common are PA system and Recording system. There are Main output jacks which carry the mix as summed in the main faders. These in a PA system would feed the pa amplifiers which drive the house speaker system for the audience. These connectors are XLR 3 pin type on the rear, intended for professional pa amplifiers which use balanced +4dbv line input level. Amplifier which have 3 pin XLR connectors for input signals can accept that high level signal. For home style HiFi amplifiers, the signal level is nominally -10DBv and balanced or unbalanced signal lines with 1/4in diameter phone plugs which are connected to the mixer by way of a second set of Main output connectors which are 1/4in phone jacks. Use whichever amplifier input level your amp has.
If you are not using it as a main PA house mixer, but using it for recording, the main output connectors go to a 2 channel recorder or computer sound card recorder. The power amp and your monitor speakers are connected to the connectors labeled "Control Room" (CTRL Rm). These output are useful for recording because the signal through the mixer can be monitored from several buses, Solo, main mix, selected by buttons provided. The buttons only affect the signal heard through the control room monitors, and not the main output which only sees the main mix so selecting "solo" does not interrupt the signal going to the recorder while the engineer in the control can be checking other signal paths through the board.
Jan 21, 2011 | Behringer Xenyx 1832fx Mixer 18 Input 32...
I bought a used Hobart A200 20 quart stand mixer that hesitates or 'gets stuck' when mixing dough or other thick (hard to mix) material. When running without a load, or only a light load it doesn't stick...
First of all, I want to say that it is common for people to overload the A200 mixer when mixing dough. The owner's manual gives an extensive chart for various substances typical of what people may mix. Depending on the consistency of the dough, the maximum batch size varies, but as an example: 9 lbs. max with 40% absorption ratio thin pizza dough, 1st gear only, 5 minutes maximum mix time. I remember this particular batch size/specification because as a technician who works on these mixers frequently, I had a customer attempting to mix 20+ lbs. of that 40% pizza dough for much more than 5 minutes and didn't understand why the mixer would stall and why his mixer was so hot he could nearly cook eggs on it's transmission case. So, a word of caution (9 lbs. at 40% A.R. is approx. 7 lbs. flour, plus the water) about overloading these. If used to mix reasonable batches, they are excellent mixers and will last a lifetime (I regularly service 40-50 year old A200 model mixers that run very well).
If you don't hear any grinding when it's stalled (which would indicated stripped gears, damaged keys, etc. in the transmission) I would say you are overloading it. Many people want to say the motor is weak when the mixer stalls, but unless the motor has been repeatedly and severely overheated to the point of shorting some of the motor's windings, that's not the case. I suggest finding the recommended capacity chart from Hobart and abiding by it and you'll love your new mixer for years.
Jan 04, 2011 | Hobart A200 Stand Mixer
I plugged a mic to my dell laptop but it isnt working, do i need a sound card?
No, if you have a jack to plug the mic into you have a soundcard. However the mic is probably muted in the mixer software. Go to the control panel, left click on sounds and audio, then click on the advanced button; this should open the mixer in the play back mode, at the top left of the mixer go to options and select properties, a new page will come up with a radio button showing playback or recording, switch the radio button to the recording list and check everything in the checkboxes including the mic and press ok. A new mixer should come up with your recording deviced, from here you can set your microphone device volume.
Jul 01, 2009 | Computers & Internet
Don't know how to actually record
To record you need to first assign your input to a track, then arm the track for recording, and then press play + record at the same time.
1. So you would patch you mixer's output into an input on your DP01 (say input A). You can run some audio to set the level with the input level knob (located next to input A on the front panel).
2. Then to assign that input to a track simply press and hold the 'input A' button and then press the 'rec' button of the track you with to record on. The 'rec' button will flash rapidly to indicate that the input is assigned to the track.
(To assign the input to a different track you have to clear the input assignment from the first track and assign the input to a new track. To clear an assignment press the input assign key, A in this case, and the track it's assigned to will flash its 'rec' button. Hold down the input assign key and then press the flashing 'rec' button. The button will stop flashing and the input can then be assigned to another track by following step 2 again).
3. Next, to arm the track for recording simply press the 'rec' button for that track. The 'rec' button with flash slowly.
4. To begin recording press play + record together in the transport section and the 'rec' light for the armed track will stop flashing and light steadily. Press 'stop' to end recording.
This should get you started. The operation of the DP01 is actually pretty intuitive once you've gone through it a couple of times (which is one of the real strengths of the unit). You'll be multitracking like an expert in no time.
Cheers,
bd.
Nov 20, 2008 | Tascam DP01 All-In-One Recording Package...
MicroTrack Levels are off balance
That sounds like a hardware problem requiring a service. The front-case buttons are sensitive to pressure and I suspect that they go bad if stored where something is pressing against them.
May 28, 2008 | M-Audio MicroTrack 24/96
How do I record my own message for the answering machine?
1. Press and hold down the announce button.
2. You will hear record announcement after the tone.
3. Once you hear record announcement after the tone continue holding the relase button and record your message.
4. When you are done recording release the release button.
5. To hear your recorded message press and hold the release button and release after you have heard your message.
6. If you are not pleased with your recorded message, repeat the steps obove.
Nov 01, 2007 | Uniden DECT 6.0 Cordless Telephone...
Alesis Multimix 8 USB 8-Channel Mixer Spdif System Logo
286 people viewed this question
Top Alesis Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
gggg
Are you an Alesis Audio Player and Recorder Expert? Answer questions, earn points and help others
