Question about Whirlpool LER5636P Electric Dryer
DRYER MY DRYER WORK BUT NOT HEATIN UP
  • 14 more comments
  • quecatt Apr 06, 2008
    my clothes dryer is working normal but all of a sudden, theres' no more heat. It only blows cold air and no more heat
  • LORDVULGAR Apr 07, 2008
    I REPLACED THE THERMOSTAT CLOSEST TO THE ELEMENT BUT STILL HAVE NO HEAT,THE ELEMENT SEEMS OK AFTER INSPECTION BUT I NOTICED SOMEONE HAS BYPASSED THE THERMOL FUSE BUT THE FUSE SEEMS OK WHAT SHOULD I TRY NEXT?
  • DryerDan Apr 21, 2008
    My dryer heats somewhat. Any suggestions?
  • Anonymous Jun 18, 2008
    admiral heavy duty dryer no heat coming out do not know were to look for heating componets to replace.
  • erine508 Sep 11, 2008
    I have changed Heating Element,Thermal Cut off, Hi limit Thermostat cleaned whole inside of dryer, vents duct work checked plug, and circuit breaker why still wont dryer heat? It works on fluff but no heat settings,
  • Anonymous Oct 16, 2008
    everything seems to be working but nothing telling the element to heat up.
  • Anonymous Oct 19, 2008
    model whirlpool ler5636eq3
  • Anonymous Nov 22, 2008
    my dryer doesn't work. I can't get to the heater box to take the element out. What to do
  • hhorne31 Dec 20, 2008
    dryer runs but will not heat i have checked fuses cleaned vents
  • Anonymous Jan 13, 2009
    I am not sure what the two wires connected to the long silver thing is?
  • btaylor73173 Jan 25, 2009
    my dryer works fine but doesnt get hot
  • feelya1 Jan 31, 2009
    my dryer will not dry my clothes completely. the element is glowing and the tumbler is turning but my clothes aren't dry.
  • Anonymous Feb 25, 2009
    dryer want get hot
  • Anonymous Mar 29, 2009
    dryer spins but doesnt heat
    No heat. Husband has back off but can't figure out which part to buy. Need help to determine how to tell which part is bad. Can anyone help?
  • hojoranch May 02, 2009
    Dryer works fine but their is no heat.
  • 5,911 Answers
If the dryer turns on, drum spins, but you have no heat, any of the following components could be bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. You have to remove the entire front panel on some models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) – remove the two RED leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set.
I hope this information is helpful to you. Post back with comments if you have any further questions.
Posted on Apr 03, 2008
Dryer turned off keep heating smelled burning looked in dryer is black against rear wall had to unplug to stop heat
Posted on Jul 13, 2009
    Guru:
  • 462 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you feel confident here are the main things to do on checking for no heat Electric Heating Dryer:
1 Check for 220 Volt at the heater entrance to the heater box (accessible from picking up the top on most dryer models).
If you have 220v there the heater element is out.
2 If you don't have 220v on the terminals of the heater the problem is in the controls.
The fuse link, the timer contacts, the centrifugal switch on the motor, and the heater safety thermostat and operating thermostat(s), are all suspect and have to be eliminated 1 by 1.
Hope this helps.
With any luck all you need is a new element. Clean the duct out while replacing the heater if so because the main thing that causes heater element burn out is low air flow. A kinked Dryer vent hose, lint, and plugged up fan circulator on the motor, or if yours has little holes in the inside cabinet where the air is taken to be heated and recirculated, these can get clogged with lint also and cause a problem are the 4 main causes of low air flow..
Hope this helps and please rate me accordingly Thank you and good luck.
Posted on Mar 13, 2009
Thanks for your ongoing support,but i resolved the problem by replacing the cut uot which is sold as a set.the store i went to first didnt tell me so i bought the thermostat seperate at first and then had to go back to store to find out that didnt have the set so i had to go to another store bought the set replaced both components the dryer is working fine now so now all i have to worry about is the electric bill thanks again
Posted on Apr 17, 2008
No heat on hoover maxi 6 tv20 tumble dryer and have two yellow wires that are no connected to anything
Posted on Apr 16, 2008
Beko condencer dryer were is the heatin element
behind the drum, You have to dismantle everything to see it
Nov 13, 2013 | Dryers
My dryer is not heatin up
Depending on the brand of dryer it may have a reset button somewhere on the outside, If not the issue will be either a thermal overload or the element which would need a service person to look at it.
Mar 10, 2012 | Dryers
Dryer run 10 mins then stops heatin up and spinning
if your dryer works after cool down then you may have a bad motor winding. if that is the case, replace the motor.
Feb 05, 2011 | Kenmore Dryers
The filter light wont go off and its not heatin up
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 12, 2010 | Candy CDC266 Dryer
It shows 8.8 on the display and will not come on
use a heatin pad or blow dryer near the panel for 10 minutes and it will work. This was the first time that I had it in the garage and had this problem.
Jan 06, 2010 | Maytag Neptune MDE7500AY Electric Dryer
Heatin element broken on my fisher & paykel dryer model # DEGX1
Try doing a Google search on the internet...put in your model number and make...look for parts
Sep 23, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Power on but it won't spin.
You have a broken drive belt. To access the belt you have to remove the back metal cover.
The no heat problem could be a heating element or safety thermostat. These are also located under the back metal cover.
Jun 02, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My problem is where to find the heatin element f my frigidaire dryer ferb6600e so model?
the heater is located at the rear of the cabinet. It looks like a big spring. It will be in a large circle shape.
Dec 05, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
992 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
