Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
HP 85gxi - How to scan to PDF?
I have an HP all-in-one 85gxi. I would like to be able to scan to PDF but don't know how.
Is this even possible?
  • Greg Shoop May 02, 2008
    I need to scan documents in and then email them as a PDF
My "work around" is to use a pdf creater like cutepdf (downloadable freeware). I "printed" the scaned JPGs to cutePDF and saved the output pdf. I also learned to specify the output DPI as 150 instead of the default 600 DPI to get the file a little more reasonable size.
It would be nice if it would scan directly to a PDF.
Posted on May 02, 2008
SOURCE:
Is it possible to scan PDF on the HP C4210 All in one printer? How? As well, can we save to scaned pages as 1 doc? Thank you
You need to have HP Solution Center Software installed on your computer to scan to pdf.
Open up HP Solution Center program.
Click on scan document.
Another window open with Document to PDF File highlighted in blue
Click on SCAN box.
Jan 01, 2014 | HP C4210 Printer
I want to scan to pdf on the hp 7310 all in one but it only scans to a file (jpg). How can I scan to pdf?
you will need to open a pdf creation program like adobe acrobat pro and scan while in that program. Then you can save it as a pdf. The scanning software will just scan it as an image.
Apr 20, 2011 | HP OfficeJet 7310 All-In-One InkJet...
New all in one printer/scanner. when I scan I get:- Adobe reader could not open 'scan_Doc0001.pdf'
Might need a bit more information about this: But I'm presuming you scan your document and save it as a pdf document using the built in HP software?
Couple of things to try:
1 - have you got the latest version of Adobe Reader? It may be that you are using an older version - the pdf document specification has been updated over the years and it may be that you're saving the pdf using a newer version of the pdf format than adobe reader is able to read.
2 - Adobe reader isn't the only pdf viewer, there are numerous other pdf document viewers (some free some not) You could try another pdf viewer, like Foxit Reader (free to use) and see if that can open it?
3 - When you save the scan, make sure that in the Save Dialog box it is really saving it as pdf. Common mistake is that people often just save a file with .pdf and expect the program to know that you want to save as pdf. When you scan there are several other file formats that you can use (Tiff, Jpeg etc) Is is possible you're saving the file as Tiff or Jpeg but with a .pdf file extension? If you're not sure, re-scan the document and resave it, but don't use a file extension, let the scanning program do that, see what it saves it as?
4 - check where you're saving the pdf on your computer? Is the place you're trying to open it from, the same as the place you've saved it?
Feb 28, 2011 | HP Office Equipment & Supplies
How do I scan a document into a pdf and send by email
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
astrtr21
Aug 12, 2009 | HP Officejet 5610 All-In-One InkJet...
How can I scan to a PDF file? I am using HP Officejet 5610 printer
To scan a document to PDF using HP Officejet 5610, try the following,
1.) Click the "Scan paper" icon to select HP Officejet 5610, and then scan documents from the scanner
2.) Click the "Build to One PDF" icon to create a PDF document contains all of the scanned documents.
Please let us know if that was helpful enough.
Good Luck & Thanks
Shiv.
Can't scan from HP Photosmart C7280 to my Mac Computer
The best way to scan documents from the scanner to your computer is to use HP Photosmart Essential. If you don`t already have it installed it can be downloaded from the HP site. Once in the program it is very simple to follow. It is basically a point and click operation.
Let me know how you make out and we can do other things if this doesn`t work for you.
Please remember to rate me.
Feb 02, 2009 | HP PSC 2410 All-In-One InkJet Printer
Connection issue between XP Pro and HP C6180 all-in-one
Hi Lynn,
Unfortunately, HP.com doesn't have a very satisfying online solution to your problem. Still, there are a few things you can try.
The first is a general diagnostic check of your scanner. HP provides a doc that takes you through some steps, many of which you probably already tried, to see if it's a simple fix:
An error occurred while communicating with scanning device
The next document is a set of diagnostic steps to address errors trying to scan to a PDF:
An error occurred while trying to scan to a PDF
I don't know if the current situation was created by a fault in the device or some recent change in your configuration settings. I do know you can use the HP Director software installed on your computer to set the scan destination settings:
Settting "Scan To" Destination using HP Director
Those were the most relevant solutions I could find for you. I hope some of this information is helpful. Good luck.
-Trip
Oct 07, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP C6180 All-in-One - Scan to pdf
u need a software for it its a pdf writer
here is link 4u 1st u have to creat file u will be print for pdf printer
http://www.cutepdf.com/Products/CutePDF/writer.asp
Jul 11, 2008 | HP Photosmart C6100 All-In-One Printer
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
228 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
