Question about Maytag PYE2300AY Electric Dryer
MAYTAG PYE2300AYW ELECTRIC DRYER not heating
I replaced both thermal fuses with the correct parts, and when that didn't work I replace the heating element. The dryer runs, but still no heat. I wanted to fix it myself, but unless someone can clue me in, I will have to call a repairman and be out extra bucks.
Would appreciate anyone's expertise.
-Frustrated
  • ozymandias Apr 27, 2008
    I have exactly the same problem: runs but no heat. I cleaned the exhaust of lint and replaced both fuses (though not the heating element yet). I tried to call Maytag for more suggestions, but their offices are closed on weekends (of course!).
    Any help would be greatly appreciated.
  • Anonymous Mar 19, 2014
    our epic z electric dryer model MEDZ600TW2 SN/MW2203750 no longer has heat. Motor and tub work properly.I think it could be element or thermal fuse. I would like to try to repair this myself but need to know if im on the right track and also what part numbers to order. Also, do I remove the front or back of dryer. Thanks
  • 52 Answers
Check the terminal block and make sure you're getting 220. If you only get 110, the dryer will run but without heat.
Posted on Apr 04, 2008
SOURCE:
Roper electric dryer will not heat after replacing heating element and thermal fuse. what's wrong.
It doesn't necessarily mean the heating element is busted when the dryer stops heating and the thermal fuse is not part of the heating circuit, it is part of the motor circuit. The heating circuit is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The most common part that causes the dryer not to heat is the thermal cut-off and/or the high-limit thermostat. Verify this condition by bypassing the said components. Click on the link below for the detailed instructions. Indicate the exact model number of the dryer should you need further assistance.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Feb 12, 2011 | Dryers
My he4T dryer is not heating at all. It is only cold air. What could this be so I know what part to order?
Hello there
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
dryer_heating-element.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
function isValidEmail() { var emailAdd; emailAdd = document.all.infobar_EmailAdd.value; if(emailAdd == "" || emailAdd.indexOf("@")
Feb 01, 2010 | Kenmore HE4t 3.8 Cu. Ft. King Size...
My dryer will run, but will not heat.
Hello there
Heating Element
Thermal Fuse
Thermostat
Timer motor
Jan 25, 2010 | Speed Queen AES28AWF Electric Dryer
My dryer works but has no heat whats could be wrong
hello there
:please go through each of these steps that i have provided belw
investigate these five areas if your dryer is not heating up:
Proper Voltage
Heating Element
07fcef1.jpg Thermal Fuse
f9921fb.jpg Thermostat
17a0736.jpg Timer motor
Jan 25, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer runs but does not heat replaced the heating element a few months ago and fuses breaker box is good
hello there:
Please follow this troubleshooting guide that i will provide below
My dryer will not heat up. Investigate these five areas if your dryer is not heating up:
Proper Voltage
Heating Element
Thermal Fuse
Thermostat
Timer motor
Jan 25, 2010 | Dryers
Dryer will not heat up when running. Was told to check the thermo fuse, ignitor and/or coil. Is that right? How do I check those things.
hello there
Please follow this procedure I have provided below and it will tell you how to test each one ok
Hope this is very helpful
Proper Voltage
Jan 24, 2010 | Kenmore Dryers
Wont heat up
Generally either a bad thermostatic fuse or an open in the coil. I would suggest checking Here:http://www.repairclinic.com/ for issues related specifically to your make and model as well as repair/diagnosis advice and parts.
Jan 22, 2010 | Dryers
Will run but won't heat
HELLO THERE
There are 5 things that can make a dryer not heat please review the following items that i have provided for you
Proper Voltage
Jan 18, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer will not heat
Hello there:
There are 5 things that would not make the dryer heat up i will post you them here ok
Jan 17, 2010 | Dryers
Heating part of Indesit ISA60v tumble drying has stopped working. Can you give me info as to where to look im a Electical-tech cheers chris
Hello there chris
Proper Voltage
81f68d1.jpg Heating Element
97ed1ca.jpg Thermal Fuse
0a798b8.jpg Thermostat
7e97613.jpg Timer motor
Jan 13, 2010 | Dryers
Maytag PYE2300AY Electric Dryer Logo
409 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
