Asus MB av7333 x
Have nothing on how to hook up board. any place to et walkthrough on insallation i can not even find 4 pin power plug on board
  • fgs2 Apr 07, 2008
    i can't tell you what this means to me
    i have come down very ill in the midle of a few things and with the meds and illiness the mind just does not grasp things
    i hope i can use this service more as i try to build this thing
    thanks to ya
  • 2,351 Answers
Hi fgs2, the manual will walk you through setting up the board including the CPU, memory, connecting case leds. (Everything).
Download your Asus A7V333-X manual from Asus web site by clicking on the the link below. (You might want to save the link).
Good Luck! Take your time.
Have more questions, feel free to ask.
Posted on Apr 04, 2008
When I plug my computer up nothing comes on but the green light on the motherboard but when I plug the power supply to the motherboard half way in the processor and the power supply comes on but its like...
This is really poor practice and an excellent way to destroy a motherboard.
You should always have the board connectors plugged in before turning on the power supply, otherwise you may be blowing ICs left and right. It's perfectly OK to plug the supply into the wall or turn on its power switch with the board connectors in place. Also, nearly all modern boards have a set of pins that go to the front panel 'power' switch which does not switch AC but sends a logic signal to the power supply to turn the rest of the voltages on. Those pins have a 5V potential on them that is typically grounded to tell the supply to turn on.
If you're lucky, you still have an undamaged motherboard.
Aug 28, 2011 | ASUS P4P800-VM MB, 865G/ 800FSB/ SATA/...
I have my rest and power hooked up in the right plugs but nothing is happening only thing comes on is the light to the motherboard when plugging the power from the computer case to the motherboard the...
You may have the reboot or restart wires backwards.Or on the wrong pins on the motherboard.
Here is a link to your mobo. Shows correct hook up.
Also be sure your memory sticks are in proper slots.If you have 2 they need to be seperated.
One in one channel the other in the second channel slot.Usually the slots are color coded.
Aug 09, 2011 | ASUS P4P800-VM Motherboard
I don't know how to plug in the wires for the ASUS a8n sli deluxe motherboard
Here is the manual for your motherboard (since describing a diagram probably isn't very useful...)
You want to look at pages 27-35, they describe what you need to plug into the motherboard. Basically make sure you have connected:
1) 24-pin power cable (from power supply)
2) 4-pin power cable (for CPU from power supply)
3) Any case fans with 3/4 pin connectors.
3) hard drives (SATA or IDE)
4) USB front panel ports
5) Audio front panel ports
6) Case plugs (power LED, hdd LED, power switch, and reset switch).
Apr 19, 2011 | ASUS A8N-SLI Deluxe Motherboard
Extra wire /fan 3pin hole 1wire where to plug in X 2 fans
If your cpu fan has a 4 pin connector & your mb has a 3 pin you can still use it. Just leave one pin exposed. The extra pin is for a speed control sensor that not all mb's support. The chassis fan has a different connector on the board marked "cha fan". This one is a 3 pin connector. Most of the asus boards have 1 of these. If you wish to run more than one you can either buy a "y" adapter that allows you to connect 2 fans to 1, you could use an extra 4 pin molex to power an extra fan but that would give you no control over the fan, or you could buy a fan controller and hook all your extra fans to it. Hope this helps & please take a moment to rate my solution fixya. Thanks.
Feb 14, 2009 | ASUS MB M3A78-EMH HDMI RT Motherboard
First Time Build
Be careful to note whether you have the power switch connector plugged into the correct place. Sometimes with the two rows of multiple pin connectors it is difficult to tell if you have plugged it into the right place.
make sure you have the main 20pin power connector AND the 4 pin standby connector both plugged into the mb. The 4 pin receptacle on the board is sometimes hard to see because it is close to the CPU.
Unplug all the case connectors going to the mobo and try this. Take a small metal object like a small screwdriver and short out the two "power" pins on the mobo. The motherboard should power up. If it does, try plugging the case wires in again, being careful to plug them in across exactly the pins you used to turn it on by shorting it. If it still doesn't work, it is probably a faulty power switch on the case
Sep 06, 2008 | Intel Motherboard
ASUS Crosshair won't boot
some motherboard have 2 power supply plugs 1 for board 1 for cpu check and see if yours is like this 1 is a wide one with about 15/20 pins in the other is asmall square one with 4 pins
Jul 25, 2008 | ASUS CROSSHAIR Motherboard
Mother Board connection
Go to the site below. Its a manual for the 800/i65GV group. Go to page 67 and zoom in. You'll get a nice look where everything goes. Two rows of pins. Upper row and bottom row. Real close to each other. Do not place connectors up to down. Connect only left to right.
The reset connector has two pins. One will be white or black. These are - grounds. So connect it to the bottom row onto the most right two pins. Moving to your left. Skip one pin. Take the Power Switch a two pin connector. Remember Black & White is ground & ground goes to your right for both rows of Mb pins.
Go to IDE_LED next. Its the last two pins towards your most left of the bottom row of pins. Move to the upper row & the power LED. Same as the bottom row keping the grounds to your right. Lastly is the speaker. Its connector holds four pins but you only use two. One in each end.
Good luck & please vote....
Dec 22, 2007 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Computers & Internet Logo
804 people viewed this question
David Payne
David Payne
