Question about HP Scanjet 8290 Digital Flatbed Flatbed Scanner
Feed will not take papers
Please help me figure out why my documents aren't getting picked up in the ADF feeder.
  • YVILLEGAS Jul 02, 2008
    MY SCANNER WILL NOT FEED THE PAPER SHEETS THROUGH AND THERE IS AN ERROR MESSAGE THAT SAYS ADF PAPERJAM BUT I CAN NOT FIND THE JAM
    Genius:
  • 2,785 Answers
Your feeder is having problem.get the printer serviced
Posted on Apr 04, 2008
Hp laserjet 1536 dnf MFP. How can I repair document feeder?
how to fix and repair the adf doc feeder Q5997A hp laserjet ...
? 1:36
https://www.youtube.com/watch?v=lpTj4jiLaY8
Dec 12, 2011 - Uploaded by BrokenPrinter1
Parts Available @ BrokenPrinter.com how to fix and replace the rollers on a hp laserjet 4345 mfp and color ...
Fixing Paper Pick-Up Issues - HP LaserJet Pro M1212nf ...
? 5:40
https://www.youtube.com/watch?v=ZXtAhSDYqyU
Jan 23, 2013 - Uploaded by HP Printer Support
Learn what to do if your HP printer does not pick up or feed paper from the ADF when you do have paper loaded, and a Doc feedermispick error message display... ... FIX YOUR PRINTER: ERROR: Printer Does not Grab Paper fromTray ... Kit m3027 mfp- Kit Hp m3027 mfp - Kit Mantenimiento m3027 mfp ...
'Document feeder mispick' Message Displays on the Control ...
Dec 13, 2015 | HP Office Equipment & Supplies
Multiple pages feed when printing on hp 7410
  • If the automatic document feeder (ADF) does not pick up any pages at all, the rollers inside the automatic document feeder need to be cleaned.
  • If the automatic document feeder picks up multiple pages instead of single sheets, the separator pad inside the automatic document feeder needs to be cleaned.
SolutionLoad one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.note.pngNOTE:If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water. If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually. Follow the procedures below to remove the face plate from the front of the automatic document feeder, access the pick assembly inside the automatic document feeder, clean the rollers or separator pad, and then reattach the face plate.
Please Click on this link to know more in detail.
Thanks
Apr 01, 2012 | HP OfficeJet 7410 All-In-One InkJet...
What does document in ADF mean
Hello, Thanks for using Fixya today.
ADF is auto document feeder, used to feed a document into a scanner or printer. The error is associated when there is a document or paper jam at the document feeder, or paper trail.
This would happen mostly on scanners and all in one printers after witch a document is left in the feeder or there was a paper jam occurrence. We hope this answers your questions today?
Please contact us again if you still have a issue, or need help with anything else.
Thanks for using Fixya.com
Best regards,
Rulds2008
Jun 14, 2011 | Canon PIXMA MP830 All-In-One InkJet...
HP Officejet Pro LP 7880 feeder does not work, how to fix it?
Step one: Check the paper in the ADF The condition of the paper or the amount of paper loaded in the ADF might prevent the ADF from picking it up and feeding it through the product.
  1. Make sure that no more than 50 sheets of paper are in the ADF input tray.
  2. Make sure the original is not photo paper or carbon paper. These types of originals must be loaded on the scanner glass.
  3. Make sure the original document that is loaded in the ADF meets the following criteria:
    • Free from curls, folds, creases, and tears
    • Does not have staples or clips attached
Step two: Make sure the ADF pick assembly is in good working condition
  1. Remove the document feeder and open the ADF cover.
  2. While lifting the blue-green lever, carefully rotate the pick assembly toward the open ADF cover until it stops.
  3. Examine the pick assembly.
    • Make sure the bottom roller is held firmly in place by the two-catch, which is located to the left and the right of the roller.
    • Make sure the stack stopper, which is located between the top and bottom rollers, fits within the double slots just above the bottom roller. The stack stopper should move freely within the double slots to flow up and down when the whole pick assembly is lifted and lowered into position.
  4. Return the pick assembly to its original position.
  5. When the product is turned on, the top roller will reset to its original position above the separator pad. There will be a gap between the separator pad and the top roller.
  6. If there is no gap between the ADF top roller and the separator pad, press the Power button to turn off the product.
  7. Wait three to five seconds and then press the Power button to turn the product on. The ADF rollers should reset to the correct positions.
  8. Close the ADF cover and replace the document feeder.
Step three: Clean the rollers and separator pad
  3. Lightly dampen a clean, lint-free cloth with distilled water, and then squeeze any excess liquid from it.
  4. Use the damp cloth to wipe any residue off the rollers and the separator pad. If the residue does not come off using distilled water, use isopropyl (rubbing) alcohol on the cloth instead.
  5. Return the pick assembly to its original position.
  6. Close the ADF cover and replace the document feeder.
Step four: Detaching and re-attaching the ADF pick roller assembly If the ADF pick assembly is detached or not connected properly, follow the steps below to resolve the issue. If the ADF pick assembly works well, do not perform these steps.
  1. Press the Power button to turn off the All-in-One.
  2. Remove the document feeder and open the ADF cover.
  3. Press the blue-green ADF-release button to release the ADF rollers from the pick assembly as shown in the figure below (the red arrow is pointing to the ADF release button).
  4. Re-attach the ADF pick rollers by placing the rollers into the roller slot of the ADF pick assembly as shown in the figure below. The red arrows show the gears on the ADF pick assembly aligned on one side. The yellow arrows point to the two-catch notch.
  5. Once the rollers are placed on the two-catch notch, push them in, so that the two-catch clicks into place. The photo below shows a correctly installed ADF pick assembly.
  6. Close the ADF assembly and cover.
  7. Turn the product on and make a copy with the ADF to check that the pick assembly works.
Jul 16, 2010 | HP Officejet Pro L7680 All-In-One Printer
Canon Imageclass D880 automatic document feeder problems
Clean the ADF rollers and pad with alcohol.
Check to see if your ADF has done over 90 000 copies and if it has, change the ADF pick up assembly only.
Good Luck
Oct 19, 2009 | Canon imageCLASS D880 All-In-One Laser...
Automatic document feeder not working
Open the adf and rotate the pick assembly till you hear a click and then take a coin and run it up and down against the separator pad and then see if the adf picks the paper or not.If this does not work try this *# 329 and scroll thru and select adf pick test if that fails its time for you to get the printer replaced or get an upgraded printer
May 29, 2009 | HP Officejet Pro L7650 Printer
Automatic document feeder does not work-- does not pick up paper
Here, you will find information on feed issues with the ADF. If you still have problems, you can find information on the "clear jam" error here.
If the above fails, you can find information on paper pickup issues and also how to perform a partial reset here.
Hope this helps. Please remember to rate this information.
Thanks
May 27, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Feeder tray does not feed during fax
Hp help
Automatic Document Feed (ADF) does not pick up paper. Follow each step, problem seems to be in pick assembly. Prcess took less than 5 minutes with a successful outcome.
Apr 28, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Document Feed
first u switch off and switch on the machine, that time ur document feeder get rotating its not feeder problem. otherwise pls u check ur feeder driveres.
Jul 23, 2008 | Office Equipment & Supplies
Top Paper Feed Won't Work
Like a worn running shoes, the paper feed roller of the Automatic Document Feeder (ADF) have lost it's traction and has to be replaced or cleaned. Paper just slids and doesn't picked up properly without that little push. Professional servicers use a cleaner specifically designed for rubber rollers. However, YOU CAN get extra miles on it by dabbing a Q-tip in warm water and cleaning the paper feed roller on the ADF. Like all eletrical devices, the unit has to be turned off and unplugged before working on it. Take all precationary measures and goodluck.
Nov 29, 2007 | Brother MFC-3240C All-In-One InkJet...
HP Scanjet 8290 Digital Flatbed Flatbed Scanner Logo
218 people viewed this question
Seeker5211
Seeker5211
