Question about RCA P52926 52" Rear Projection Television
I have a sony kp-57hw40
It will turn on then wit the picture then after 1 or 2 minutes it will to a red screen with lines and it will go off i was told to unplug the red gun i did
still the same thing buth now its a green screan then it will go off the same
i was told it was the power board has a short in it now is this the problem
if so were is the board on the TV
  • 149 Answers
Seems to me that you don't have voltage to color amps or no video drive have an experienced tech check your tv is no expensive repair
Posted on Apr 04, 2008
SOURCE:
Sony rear projection kp-577hw40, screen turns red after being on for 10 minutes
This model and some others had bad picture tubes that are no longer available---there is an option here.
If screen gets bright red, green, or blue set will shut down as it detects too much current being drawn.
Seen over 100 with this issue--what can be tried and usually will help is a physical adjustment inside the set.
No parts to replace and takes about 15 minutes to do.
I can tell you how if you want to know.
Jun 13, 2012 | Sony KP-57HW40 57" Rear Projection...
The screen turns blue after about 2 minutes of turning on the TV
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Jul 25, 2010 | Sony KP-57HW40 57" Rear Projection...
My sony kp-57hw40 projection tv picture is not as bright as usual. There is blue arc lines that show up at the bottom of the screen.
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 07, 2010 | Sony KP-57HW40 57" Rear Projection...
Can see the picture for a minute or 2 then the screen turn blue
It's most likely that the automatic digital convergence system is messed up, without knowing more. You can read this article & see if you can fix it yourself:http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.htmlTo replace the convergence system, you'd be paying over $400.
Jun 11, 2009 | Sony KP-57HW40 57" Rear Projection...
Sony KP-57HW40 Error Codes 6 & 8
ITS PROBABLY THE RED PICTURE TUB (CRT). IT LOOKS EASY TO INSTALL, BUT YOU NEED TO MAKE ADJUSTMENTS TO THE SCREEN ONCE IT IS INSTALLED. THE PART IS $3OO. TRY TO FIND SOMEONE TO INSTALL IT FOR $150 OR LESS. HERE IS A WEBSITE TO HELP YOU MAKE ADJUSTMENT IN THE FUTURE ON YOU OWN.
PRIDAH
Nov 10, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony tv KP-57XBR10W
Correct ! One set is for RGB focus and the other set is for
RGB screen voltage............................T.
Oct 05, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony KP-57HW40
Have a Tech. replace the focus/screen block if the problem continues you have a bad red CRT.
Sep 21, 2007 | Sony KP-57WS500 57" Rear Projection...
Red Screen
Sounds like the red color tube is goeing bad you wil hafto call in a tech to conferm it Sony is noted for tubes goeing bad, in the future leave sony alone
Sep 24, 2006 | Sony KP-57HW40 57" Rear Projection...
RCA P52926 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
