Can't get disc tray to open on my R6640 DVD Recorder.Also the recorder seems to be freezing up, is there any to reboot or restart the recorder?
  • 818 Answers
In front of your dvd theres is a small hole where you can insert a pencil that permit to get off your dvd.
Sergio
Posted on Apr 03, 2008
    Genius:
  • 1,665 Answers
    Master:
  • 555 Answers
Who is the maker of this DVD player?
  • Matt Jurach
    Matt Jurach Apr 03, 2008
    I assume this unit if from "GoVideo" (or sometimes co-branded as "Soyo"). If so, the manual for your unit can be found here.
    It does not look like there is a specific sequence or key function for resetting the unit. Usually turning the unit off and leaving unplugged for a time (several hours) will force it to re-initialize when it is plugged in and turned back on.
    Genius:
  • 3,422 Answers
Try reseting it first.
  • Priya darshan Apr 03, 2008
    To reset the player unplug all the cords and then plug it back after 30min.
    I will be posting more solutions for you.
I have a 5 yr old liteon LVW5005 dvd recorder.I am a light user and this unit did recorder around 100 dvds. Now the recorder wont read any discs I have been using -r have tried +r no good as well the...
Hello
According to your description, it seems that the disc tray is not loading into it porperly i thinks. Just do one thing. Without any disc in tray, close the tray either by using remote control or the front panel opn/close button of the system. If the tray closes first, and then reopens again without any command, make sure that the disc tray mechanism does not working properly, and the disc is not loading into it in place.
If this is alright, place a disc in the tray, set close, and push the tray with your finger slightly as it closes, and see whether it loads properly and play the disc. If so, loading belt inside the loading mechanism is worn out, ans should be replaced. In most cases, this may be the fault. Check it.
You can do the repair work, if you have some knoledge in electroncis, and its mechanical function. If not, get it repaired by an experienced service technican. Most of them can do this work, as it is simply a mechanical one. OK.
Mar 31, 2011 | Lite On LVW-5005 DVD Recorder
Philips CDR775 2-Disc CD Recorder tray won't read/open
this depends on what make of disc mostly the philips machines only work with their own brand of disc try placing an original disc if thats ok then its the blank cd that you are useing got to be philips brand
Mar 30, 2010 | Philips CDR775 2-Disc CD Recorder
LG RH1757 (80 GB) DVD Recorder / HDD Recorder Drawer keeps opening Drawer keeps opening and closing and won't read discs! Rassie from Cape Town South Africa
Could be a timing issue with the tray mechanism - possible that somebody has given the tray "a shove" to make it close instead of using the open/close button and has put the timing out.or a worn tray loading belt
Mar 16, 2010 | LG RH177 DVD Recorder/HDD Recorder
Disc tray on RDR-HX720 doesn't open and display
1 of 2 things
can you hear the motor running inside the player ????
there is usualy a snall pin hole under the tray insert a paper clip into this hile and push it in if tray starts to auto open it might be just a dry set of rails
if rails asumed dry open unit and coat the rails with anti seize and try again with the switch on front cover
Aug 03, 2009 | Sony (RDR-HX710) DVD±RW Dual Layer...
Liteon DVD recorder LVW-5045 has disc inside and won't open tray
Use your knuckles to knock on top of cabinet just above disc tray door while at the same time pressing open button,99% of the time disc tray will open.The problem you have is caused by a worn out belt drive or the tray is out of alignment.The disc tray belts only cost $2,when tray is open you can see the minature belt that controls door to the right.Use twizzers to remove and replace.Belt size 1.9
Aug 02, 2009 | Lite On LVW-5005X DVD Recorder
LG DVD REcorder disc tray will not open
Most likely the tension band that is attached to the mechanical parts of motor and the tray detached. you'll need to disconnect the power and unscrew the cover open and put the band back in place.
May 21, 2009 | LG DR787T DVD Recorder
Dvdr tray
You have one of the following problems:
  • The device freezes and does not react anymore to the remote control commands.
  • The DVD is stuck in the tray. Sometimes the message BLOCKED appears.
  • A feature is not available in the menu without any logical reason.
  • A feature of the device does not work (for example start install).
  • There is some problem with the device you cannot solve.
Reset the DVD recorder.
  1. Unplug the mains cord from the mains wall outlet.
  2. Press the POWER/ON button on the DVD recorder itself.
  3. While keeping the POWER/ON button pressed connect the main power cord to the wall outlet again. A message IS TV ON? or a demo message will appear in the display.
  4. Start the first installation process.
Notes:
    1. The settings of the DVD recorder will return to their default settings. Install the DVD recorder as if it came out of the box.
    2. The data on the hard disc will not be affected.
Apr 28, 2009 | Philips DVDR7260H DVD Recorder / HDD...
DVD disc tray keeps popping out
I had mine for 2 years and within the first 12 months the tray would not always pop out when I wanted it to. Then finally the machine would not recognise the disc type. Its in getting fixed but although the dvd drive and associated pcb have been replaced the guy says it still can't recognise the dvd disc type. Still trying to work it out.
Mar 25, 2009 | LG DVB418 DVD Player
Hi. i have a dvd player/recorder philips dvdr5500 can i make it so it is region free ( multi region )
press open disc with remote
press home to see DVD recorder screen
highlight "disc tray"
enter "0086000" on remote
dont worry if you dont see regfree on-screen it did not on mine but does on some it seems.
close tray using remote.
May 06, 2008 | Televison & Video
Can't get it to record
if your cable box is digital it should have the yellow, white, red rca jacks in the back run those to the rear a/v input on your recorder then cycle through the input switch on the remote until you see the picture. (i have the same model i hope you have better luck with yours...i can't record on any new 4x or slower +rw disc i had mine since 2006 i should've got a sony!)
Nov 02, 2007 | GoVideo R6640 DVD Recorder
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
