Center speaker hookup to a MARANTZ mdl 2238
I would like to connect a KLIPSCH sc-1 center speaker to my MARANTZ model 2238 rcvr/amp. The amp has L/R speaker outputs and the center speaker has only one input......is this possible. I would also be interested in using this combination with the A set of speakers, 8ohm INFINITY's, at the same time. Haven't tried yet, I dont want to overload the amp. Any ideas? Thank you.
DHS
  • 1,512 Answers
Hi tliguyanadig
You can hook up the speaker "between" left and right outputs. Just connect the center speaker between left +ve and right +ve outputs respectively. It will give a spacial effect that some like and some dont:) Try it and see for yourself. Your marantz amp will handle the load OK. It is rated 38 watts into 8 ohms, but there is not alot of load presented by this sort of setup. Let me know what you think.
regards
Graeme
Posted on Apr 06, 2008
SOURCE:
I have a Marantz turtntable, a Marantz CD player, an Eltax tape player and a Marantz amplifier with two Cambridge speakers, how do I wire them up please.
If you have a pure amplifier, there may only be one set of inputs, and one or two pairs of speaker outputs. The inputs are probably RCA plugs. Connect the CD or tape player to these. The speaker outputs are typically heavier binding posts or wire clamps. Each speaker should have one pair of wires. One for the 'Red' post, another for the 'Black' post.
If you have a 'Receiver' you will have several inputs to use and switches in front to select them. The CD and tape can be plugged into either tape, CD, or Aux inputs. (Not 'Phono') The speakers hookup is the same as for the amplifier.
You may also want to google the make-model of your amp to find a manual....
Mar 11, 2015 | Marantz Audio Players & Recorders
Connecting Marantz Power amp to Marantz reciever
Please see my answers regarding the hookup of Marantz amps and preamps.
Feb 21, 2014 | Marantz MM7025 Amplifier
Can i hook up 4 8ohm speakers to my marantz 2252b
You can but you will have to put two speakers on the main L/R and two speakers on the remote L/R. DO NOT HOOK UP MORE THAN ONE SPEAKER TO A CHANNEL. Doing so can result in the amp running hot and damage will occur.
Oct 25, 2012 | Marantz Vintage 2252 B Stereo Receiver...
I have bose 901 series 2 speakers, marantz 8200 and 2 marantz ma700 monoblock amps how do i hook everything up? Thankd
Do you mean SR-8200? You can't omit the details of a model number if you want a good answer.
Assuming it is...
http://www.retrevo.com/support/Marantz-SR8200-Receivers-manual/id/511ci775/t/2/
Run the 901's with the Active EQ between the receiver Front L and R Pre-Outputs and the mono block amps, one chanel to each.
Pre Out Channel X >>> Bose EQ Amplifer IN, then Bose EQ Amplier OUT >>> Monoblock IN
http://community.klipsch.com/forums/storage/74/1341919/200w%20mono%2005.jpg
I can't find a manual for the MA700. Set them up to a certain volume and then use the speaker setup routines of the SR to match everything up volume-wise. Control will be in the AVR.
Aug 22, 2011 | Bose 901 VI Main / Stereo Speaker
I'm having a problem with sound from a Marantz SR48 MKII. I have a pair of Klipsch monitors connected to the "system 1" outputs on the Marantz and a Polk PSW100 connected to the "system...
I'd say you DO need to evaluate how the PSW is attached. I can't find the specific manual for it but the prescribed way for most subs that accept speaker level inputs (and HAVE speaker level output terminals) is run one pair of speaker outputs from the receiver to the sub and daisy-chain the Klipsh speakers from the sub.
Aug 19, 2011 | Marantz SR-48 Mark II Receiver
Can I connect my Bose Acoustimass 5 - Series II to Bravia unit?
Yes, there should be no issues using your Bose speakers with your Sony receiver. Sony has a "hookup guide" to help here -
http://esupport.sony.com/US/perl/model-home.pl?XID=M:products:crmportal&LOC=3&mdl=DAVHDX265
Please rate my answer, thanks.
Apr 30, 2009 | Audio Players & Recorders
No audio output - Marantz 2238
This can be as simple as a poor connection somwhere in the voltage regulator circuit or a defective driver transistor or output transistor. In any case, this is a simple repair for any shop that works on vintage receivers. If it is the outputs, that will be the most expensive repair from a parts perspective. The outputs will cost in the $5-$10 range for each one and it could be 2-4 pieces. If you wish to attempt this repair yourself, you will need a multimeter that has a diode checker. Let me know and I'll provide additional details and instructions.
Dan
Apr 06, 2009 | Marantz Audio Players & Recorders
Multi Room Function on marantz SR-19
Hi..
Put a RCA (phono cable) splitter at the pre-out /main in.
That way you can go to both amps with the same signal
Jan 14, 2009 | Marantz SR-19 Receiver
How do I connect a Polkaudio powered subwoofer (psw 125)
Connect a set of stereo RCA cables from the 'Output 2' on the Hafler to the line imputs on the Sub.Turn on the '1+2' output switch on the Hafler and rock out!
Dec 16, 2008 | Marantz PM7200 2-Channel Amplifier
369 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
