Question about SanDisk Sansa e250 MP3 Player
Sanse e250 no disk.
How did you make it work using windows media? No disk here either. Any help would be awesome!!
May Half To Download Windows Media Player 11. Works For Mine
Posted on Apr 06, 2008
Posted on Apr 05, 2008
You can try to format the mp3 player.
Go through the : Setting>Control Panel>Administrative Tools>Computer Management>Disk management>
Try to format fat files system.
hope this help you
Dec 29, 2009 | SanDisk Sansa Fuze MP3 Player
My sansa mp3 won't work on my computer
the problem is you have not installed the drivers yet all mp3 player have to have some sort of drivers in order to run correctly on your pc if you have you sansa e250 disk still around id recomend reinstalling the information stored on that disk and go from there hopefully this helps you
Feb 04, 2009 | SanDisk Sansa e250 MP3 Player
use windows media player in sync mode at top of screen
Jun 04, 2008 | SanDisk Sansa e250 MP3 Player
Sandisk Sanse e250
What I would recommend you to do is to make sure that your device is under MTP mode instead of do that go under menu,setting, usb and then there should the two mode listed there...In would recommend thaf you upgrade your windows media player to do that go to and then click on the download now for windows media player 11...then you want to plug your device in the back of your computer..not in the front..that is very important....once you do up your windows5.gif media on your start thee sync panel..if your device is recognize properly it will be showing there on the right side..and if its not listed properly, it will say connect a device..if thats the on your start menu right click on computer and then click on propetties, click under hardware and then device manager..your device should be showing there...check under disk drives to see if your device is showing there and if it doesnt you want to right click and hit uninstall...we dont want your device to be under disk drive ..we want it to be under windows portable device...once you uninstall it...go to and find the driver for your device..and then connecct the device on the back of your should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
Please rate accordingly
Thank you
Apr 01, 2008 | SanDisk Sansa e250 MP3 Player
Help no installation cd
No installation CD is required with the E250. I use Windows Media Player to catalog my music and load it to my MP3 player. It works pretty well with the Sansa.
Mar 13, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 using micro sd card
Go to the knowledge base on the Sansa site and find this (chances are you have an SDHC card in an incompatible unit):
Sansa e200
 - verify the version of the player.  To check, go to SETTINGS > INFO
For 01.xx.xx firmware (e200 version 1) - up to 2GB microSD cards
For 03.xx.xx firmware (e200 version 2) - up to 16GB microSDHC cards
NOTE: Firmware is not interchangeable.
Sansa e200R - up to 2GB microSD cards
Sansa e100 - supports SD cards up to 2GB
Nov 12, 2007 | SanDisk Sansa e250 MP3 Player
Lost driver
The disk had Rhapsody and / or Best Buy Software and Sansa Media Converter. Which can be downloaded from and the Sansa media Converter is here; It did not contain any drivers. As long as you have Windows XP / SP2, and Windows Media Player 10 or higher, you will not need anything off of the disk. Best of Luck.
Sep 13, 2007 | SanDisk Sansa e250 MP3 Player
Two problems with my mp3 player
Hi Mina. An internal memory corruption might have occurred on your player, and would need to format your player through "Disk Management" (I'm assuming you have Windows XP or Vista). Here's how: (1) First, set your player to MSC mode by navigating your menu as follows: Menu >> Settings >> USB Mode Choose "MSC" (2) Open "Computer Management" by right-clicking on the "My Computer" icon, then selecting "Manage" (3) Your "Computer Management" window should be divided into 2 panes. On the left pane, click on "Disk Management" (4) On the upper right pane of "Disk Management", you should find the drive letter corresponding to your Sansa E250. The lower section also contains the drive # pertaining to your E250. Right-click on either drive letters pertaining to the E250 and select "Format". Follow the on-screen prompts. Make sure that the "Quick Format" checkbox remains un-checked. In general, Disk Management is more the effective tool for formatting your E250 and assuming the format processing completed without any errors, you may now use your player as you would. You may want to set the mode of your MP3 player back to "MTP" (if you're going to download subscription songs -- otherwise, just leave it in MSC mode) by navigating your menu as follows: Menu >> Settings >> USB Mode Choose "MTP" In case you get the error "Unable to Complete Format" or the format process is unable to complete, you may want to call the SanDisk Tech Support guys for more advanced troubleshooting (I call `em when I'm at my wit's end lol) I hope it works :)
Jun 02, 2007 | SanDisk Sansa e250 MP3 Player
Sanse e200 freezing up for no reason!!!
Hi. It seems like your player decided to throw a hissy fit by deciding to experience internal system errors. Best that you reset the firmware. Here's how: Switch your Sansa E250 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E250 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E250 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E250 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E250 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E250 (for better results, please save this file on your "Desktop": Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred. Step 3: When the process is complete, unplug your E250 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E250 and 90-99% of the time, it would boot up successfully. Step 5: Enjoy using your Sansa E250, just like I do. (I love this player)
May 14, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
100 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
