Question about Kenmore 22422 Top Load Washer
Cleaning washing machine
Would like to know how to clean the  inside of the washing macine?
    Novelist:
  • 184 Answers
THERE ARE COMMERCIAL WASHING MACHINE CLEANERS ON THE MARKET. YOU CAN ALSO USE AUTOMATIC DISHWASHER DETERGENT IN A HOT WASH TO CUT GREASY BUILDUP IN THE WASHER. BE SURE TO GET THE WATER A LEAST 120 DEGREES TO ACTIVATE THE DETERGENT. YOU CAN ALSO USE A BLEACH BATH TO CLEAN THE WASHER, BUT DON'T COMBINE THE BLEACH WITH ANY OTHER CLEANERS. IT CAN BE TOXIC.
Posted on Apr 10, 2008
Clean filter washing macine
With any washing machine the filter is located at the bottom front and under flap unscrew plug.Beware water will come out.
Sep 27, 2014 | Amana Washing Machines
How do I clean my machine?
Start by removing the bobbin cover/throat plate. Using the brush that should have come with your machine, make swift upward strokes to coax all dust and lint out of the bobbin case and feed dogs. If you have a manual showing how to remove the bobbin case, remove it. If you don't have a manual, make sure you know EXACTLY how the case was originally in the machine because they can be the deuce to replace.
With bobbin case removed, again use quick strokes with your machine brush to clean out the lint. You may use a vacuum to remove the deep down lint. If you have the attachments that are small and made for cleaning keyboards etc, use one of them to gently probe into the machine for a deep cleaning. You may also use a cotton swab. Turn your handwheel toward you and wipe dust and lint from any moving parts. You may put a small amount of macine oil on a swab after removing dust. This will help to oil moving parts that are expose. DO NOT attempt to oil any hidden parts.
After cleaning the inside and bobbin case, use your brush or a clean swab and gently check the thread take up leaver and the tension discs.Remove lint and debris but do not oil this area.
This should take care of it and your machine should purr with gratitude!
Nov 04, 2010 | Janome Memorycraft 6500P Computerized...
Washer won´t start, not all leds light on and when i press the start bottn, it just won´t start
Hiya,
Machines not starting are often due to the water not getting through 1st check would be to make sure the hoses are connected correctly & that the water taps to the machine are switched on this is a common problem when an apliance has been moved for either cleaning or re-instalation after a move, if it is the taps not switched on the macine will start working again straight away if it's not the taps then it could be the pump.
Hope this helps
Apr 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
The dial on my washing machine is getting stiffer
its usually gunked up behind the dial thats causing friction... usually removal of the dial and cleaning will help...
Dec 18, 2009 | Hotpoint Aquarius WD63 Front Load...
The machine is not filling and all the display lights are flashing.Thankyou.
It sounds like ether youre plumbing is not leting water down the pipe or the valves have gone inside youre washing machine try filling the washing machine up via the powder dispensing draw with the front door of the macine shut and the macine off when the machine is full of water swich it to the program you want and see if it works if it does then its the valves in the machine burt before you do that unhook the filling hose from the wall and see if water is coming out if not its youre plumbing
Nov 27, 2009 | Office Equipment & Supplies
Water is leaking on to floor checked all
Does the machine have a filter that needs cleaning at the bottom front of macine
Jun 06, 2009 | Roper RAX4232KQ Top Load Washer
Washing leaves spots in dress shirts
What you could possibly try, is run an empty load, to wash the washer drum clean of sediment. If the washing macine drum is stained, clean it by hand with a cleaning compund, like clorox or some other kind of cleaning solution. Another thing that you can try, is to use the dish washer cleaning solution that they sell, to clean dish washers of sediment. It comes in a small white, plastic square container and Walmart sells it.
Jan 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
pull dispenser up and off lossen large plastic wing nut in bottom of agitator throat lift agitator off if you wish to remove basket pull plugs out front corners of top remove phillips screws lift top up remove agitator as described remove ring on top of basket it just snaps off lift basket straight up
Jun 13, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Steam escaping from milk container
When you say change Oring do you mean the Oring in the capp. or in the machine?
Nov 10, 2007 | Saeco Primea Cappuccino Touch Plus Coffee...
Kenmore 22422 Top Load Washer Logo
64 people viewed this question
Ron Lankford
Archaeology
Archaeology
2mikecurtis
