Question about Alpine CHM-S620 6-Disc CD Changer
Chm -s620 cd changer not loading cds
Chm-s620 cd changer unit doesnt load cds, just goes through 1-6 with out hooking them in then displays CD 0 on display
Any Ideas would be gratefully recieved!
    Problem Solver:
  • 13 Answers
Usually this problem coming from one or two SW, Det. SPVC21 -E07 of CD Mecha. The replacement of these parts should solve a problem.
Posted on Oct 08, 2014
I've got the same problem with my Alpine changer. It seems like a widespread problem, but known cause or solutions.
Posted on May 25, 2008
Alpine CHM-S620 6 Disc CD Changer Components
sounds like the changer was plugged into the antenna jack of the radio. this means that you can run it through any radio simply by sending a signal to a preset station on the radio and listening to it through tuner. the control unit ran the changer itself. you may be able to obtain replacement cables from pacparts.com
Apr 01, 2010 | Alpine CHM-S630 6-Disc CD Changer
My Alpine CHM-S620 CD changer broke down and so I
Check out www.crutchfield.com . you can cross-reference your vehicle model and they will show you what is available for your vehicle. They carry a large inventory and I have purchased from them several times.
Sep 26, 2009 | Alpine CHM-S620 6-Disc CD Changer
Have alpine chm s620 ,error message say no disc magazine is loade
have you tried a different magazine.  Could this one be warped?
Apr 03, 2009 | Alpine CHM-S620 6-Disc CD Changer
Which radio for land rover
Usually an Alpine unit.  Try ebay.
Mar 24, 2009 | Alpine CHM-S620 6-Disc CD Changer
Changer does not work
Had the same problem!! Found the solution here under "Wont Play" question. Push that cd chngr magazine (holder) all the way into the unit and tap with a blunt object( Dont tap too hard,it's plastic!!) screw driver worked for me! Push the eject button and you'll hear the unit working! Pop it in and out and it seemed to unfreeze whatever was frozen!! It finally loaded a cd and started playing again. I checked all 6 and they were okay!!
Thanks support guys for your help!!
I'm now a member!!
Jan 15, 2009 | Alpine CHM-S620 6-Disc CD Changer
6 disc cd changer
have you cleaned the lens on the cd changer??????
Oct 07, 2008 | Alpine CHM-S620 6-Disc CD Changer
Alpine CHM-S620 CD Changer Magazine
if you open the cage on the unit, you can pop the tray back out of the mechanism by VERY GENTLY turning the load gear on the carriage, be sure to not slip any gears on the drive or the changer will be out of sync and will be garbage unless you have it serviced by an Alpine service center. you are best to turn the 1st. gear beyond the carriage motor, or you can apply power to the motor (which I don't advise) to let the motor eject the tray. if you do choose the power method, be 100% sure of the polarity first otherwise you will damage the carriage and drive gears. the motor has a brass gear and the rest are nylon gears, the brass gear will very easily shred a nylon gear. want to be extra careful? manually turn the load motor gear itself, it will take alot longer to do, but will be the safest. I've been inside these machines quite a bit, hope I was able to help.
May 14, 2008 | Alpine CHM-S620 6-Disc CD Changer
Alpine CHM-S620 Tape/CD button inoperative
Dont know Steve, i am no fundi with electronics but could it be that your system is set up for the steering remote, or perhaps not activating because of a wiring or button contact issue ?
Hope you get it sorted out.
Richard.
Oct 30, 2007 | Alpine CHM-S620 6-Disc CD Changer
Won't Play CDs
hi make sure that you cart is inserted all the way in, push the eject button why hitting the mag with the handle of ascrew driver. this may dislodge the jammed arm/lever. otherwise its down to your repair agent.
regards
Mark
www.carradiospares.co.uk
Oct 08, 2007 | Alpine CHM-S620 6-Disc CD Changer
Alpine CHM-S620 6-Disc CD Changer Logo
817 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
