Dishwashers
Problem for Dishwashers
Generic problem for all Dishwashers
Water does not drain
By jdgranato on Apr 03, 2008
water does not drain
Solution #1
posted on Apr 03, 2008
Somewhat Helpful)
APP-TECH
Rank: Guru
Rating: 88%, 179 votes
IS THE DISHWASHER CONNECTED TO A DRAIN OR A DISPOSER?
IF IT IS CONNECTED TO A DISPOSER, BE SURE THAT THE DISPOSER IS NOT RESTRICTED. I HAVE HAD NEW DISPOSERS INSTALLED AND THE INSTALLER FORGOT TO KNOCK OUT THE PLUG INSIDE THE DISHWASHER DRAIN PORT.
MOST DISHWASHERS TODAY HAVE A DEDICATED DRAIN PUMP/MOTOR ASSEMBLY. CHECK TO SEE IF THE DRAIN MOTOR IS RUNNING DURING THE DRAIN CYCLE. IF IT IS,
THERE IS MOST LIKELY A RESTRICTION SOMEWHERE IN THE DRAIN HOSE. IF THE HOSE IS COUPLED TOGETHER WTIH AN EXTENSION TO REACH A DRAIN, START AT THE
PLACE WHERE IT IS COUPLED TOGETHER.WORK YOUR WAY BACK UNTIL YOU GET A FLOW OF WASTE WATER.
THAT IS WHERE THE RESTRICTION WILL BE.
IF THE PUMP ISN'T RUNNING, CHECK FOR VOLTAGE AT THE MOTOR TERMINALS. NO VOLTAGE, CHECK THE CONTROL. IF YOU HAVE VOLTAGE, YOU HAVE A BAD MOTOR.
SOME DISHWASHERS HAVE A DRAIN VALVE ACTIVATED BY A SOLENOID. CHECK FOR VOLTAGE AT THE SOLENOID.
NO VOLTAGE, CHECK THE CONTROL. IF VOLTAGE IS PRESENT BUT THE SOLENOID IS NOT ACTIVATED, REPLACE SOLENOID.
Was this helpful?
Yes
No
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
who makes the best trouble free dishwasher today that is 18" wide
Answer
we are about to buy new dishdrawer lookin fisher and paykel
Answer
Looking for a manual for a Nelson sc 45 aws-11 or sc40
Answer
My new Kitchenaid Dishwasher leaves a film on dishes, doesn't empty the soap dispenser
Answer
dishes are not getting clean and many times find what looks like grit in cups, glasses
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dishwashers:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
