Venta VS 100 Humidifier
Problem for Venta VS 100 Humidifier
Venta 207 digital humidifier
By bjm3 on Apr 03, 2008
how do I clean it before putting it away
Same Problem
Nov 20, 2008
-   Possibly I didn't store it right...? But I cannot believe that it won't turn on at all. How do I get it fixed? -   urbandorothy
Best Solution
posted on Oct 31, 2008
Very Helpful)
tuffma
Rank: Apprentice
Rating: 100%, 1 votes
product will not turn on at all. I tried different outlets and put in a new filter, but still nothing. I also cleaned everything again. where can I take it to get it fixed/
Was this helpful?
Yes
No
Solution #2
posted on Apr 18, 2008
Somewhat Helpful)
littlesheila
Rank: Guru
Rating: 90%, 197 votes
Caring For Your Venta-Sonic Humidifier
IMPORTANT!
Always unplug the unit before cleaning!
When to Clean Your Humidifier
 Clean your humidifier weekly or more often during heavy use, depending on your
individual water quality. Clean your humidifier before storing and after long periods
of storage.
 When cleaning the inside of your unit, keep water away from the air outlet. Exterior
may be wiped with a damp cloth when unit is off and unplugged.
Cleaning the Oscillator and Water Sensor
 Turn off the unit and unplug power cord. Remove tank from base and empty
reservoir in base. Use cleaning brush provided in base to clean off mineral deposits
and sediment from oscillator and water sensor. Do not scrape or clean with tools
that have metal parts. Be careful to not damage the surface of the oscillator.
ATTENTION: Damage to the oscillator may cause the unit to not work properly.
 The oscillator (ultrasonic transducer) is highly sensitive. Keep this important part
clean and treat gently. Do not touch the oscillator while the unit is operating.
 Do not use soap, cleaning agents, detergents, or other chemicals for cleaning the
tank and humidifier.
 After cleaning fill water tank (see instructions above) and return tank to base.
Storing the Venta-Sonic
Switch off and unplug power cord from A/C outlet. Empty remaining water from base
and tank. Clean tank and unit (see for instructions above). Make sure all parts are
thoroughly dry—allow at least 24 hours to dry. Leave the filling cap of the tank
loosened. This will keep the cap and gasket from sticking together. Pack Venta-Sonic
in original packaging and store in a cool and dry place.
You can find your manual at this link:
http://www.venta-sonic.com/pdf/vs207manual.pdf
Good Luck.
Was this helpful?
Yes
No
Solution #3
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Popular Solutions for Venta VS 100 Humidifier
Questions and Unsolved Problems for Venta VS 100 Humidifier
Do you recommend Venta VS 100 Humidifier?
Answer
Answer
how do I replace the filter 14909 for the Kenmore Humidifier 758.14407
Answer
it is not turning on to bring water to it from the hot water heater
Answer
how do the filters fit in kenmore model 75815420 humidifier
Answer
motor has burn't up
Answer
I need the part the hooks the new filter to the humidifier, is like a round white part,
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Venta VS 100 Humidifier:
Top Humidifier Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Humidifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
