Question about Ricoh CL4000DN Laser Printer
Thermistor Location on Ricoh CL4000DN
Hey guys
I need to know where the "Thermistor" is on the Ricoh CL4000DN. Somebody pls help!
thanks!
Matt
    New Friend:
Sc541 pls gib me solution ricoh 9100dn
Posted on Oct 14, 2013
    New Friend:
  • 63 Answers
Thermisters are located in the fuser unit. They contact the rollers. Good luck
Posted on May 04, 2009
SC542 Error
First fix fuser unit thermistor bad then service mode and rest set code
Feb 06, 2012 | Ricoh Aficio CL4000DN, SPC400DN, SPC410DN,...
Code error 307 ricoh CL4000DN
sc 307 is a charge bias error having to do with the yellow photoconductor unit (PCU). Replacing the yellow PCU should resolve your problem. If the problem persists even with a new PCU, you will likely need to have either the high voltage supply board or the drum positioning plate replaced.
Thanks for using FixYa!
Nov 24, 2010 | Ricoh CL4000DN Laser Printer
Ricoh aficio 2232c sc542 error
SC542 means that the thermistor hasn't detected right temperature in given time.
Often you only have to reset service code.
Try this reset:
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arror to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
from http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/ here is another service procedure:
  • Press Mode(The Yellow Button)
  • Enter 107
  • Press STOP Button for 3 second (RED Button)
  • Copy Sp
  • 5810#
  • Execute
  • Power Off
  • Power On
Nov 19, 2009 | Ricoh Aficio 2015 Copier
Need to find # of pages printed.
Press "menu"
Use arrows to scroll to "list/test print", Press "ok"
use arrows to scroll to "Config. Page", Press "ok"
The page is printed, Press "menu" to return to main screen.
Total counter is on this page - top right corner I believe.
Please rate solution :)
Apr 25, 2009 | Ricoh CL4000DN Laser Printer
SC366 on CL4000DN
I just came across this post, you've likely solved it by now; However it is a "Toner density" error related to your cyan photoconductor. It is a defective connector. Replacing the cyan photoconductor should solve problem.
Feb 05, 2009 | Ricoh CL4000DN Laser Printer
SC 366 on CL4000DN
cyan problem --check if cyan pcu is set properly or replace cuan pcu(drum)
Ricoh cl4000
It is working now, however I had to have Ricoh come out they cleared up the error code and told me I needed a new transfer unit and black PCU. I got both items from a 3rd party and installed them problem did not go away. I called Ricoh, they sent their guy back out at n/c and he got it going after taking much of the machine apart but he was not very clear on exactly what caused the problem.
Jul 22, 2008 | Ricoh CL4000DN Laser Printer
Ricoh CL4000DN Thermister installation
The thermister is located in the fuser section of the machine. It will slightly rub on the hot roller, or fusing belt.
Apr 03, 2008 | Ricoh CL4000DN Laser Printer
Ricoh CL4000DN Laser Printer Logo
275 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
