Question about Cobra 200 GTL DX 4-Channels Base CB Radio
Cobra 200 GTL DX 3rd edition Installation
Hello I have purchased the above radio together with correct power supply and a Venom Aerial.Can you eexplain or tell me where to look for the following.
As well as fitting a lightning arrestor on thhe radio and earthing it ,do I have to earth the antenna.
I am not a techie and do not understand hoe antenna,s work.
Many thanks,
Hello John. A good earth ground for your antenna is more important than for the radio. Using the closest possible point to the antenna pole, preferably within a couple of feet, you need to ground the antenna pole to the earth. Go to a hardware store and buy a copper grounding rod which will be eight foot long and buy, as little as you can possibly get away with, some of 10 gauge wire and some kind of clamps that will attach the wire to the antenna pole and to the grounding rod. Google "antenna earth grounding" may help also.
Posted on Apr 06, 2008
Cobra 200 gtl dx only does 12 watts on high
Open radio up and adjust rv9for am fm high power or rv 14 for ssb for high power,do not use a screwdriver,a matchstick would be better.board information is available from cb
Dec 17, 2011 | Cobra 200 GTL DX 4-Channels Base CB Radio
Hi need to adjust the echo delay on my cobra 200 gtl dx !
Open your radio and, with a small flathead plastic screwdriver, adjust T713. Any other questions feel free to ask.
Jan 19, 2011 | Cobra 200 GTL DX 4-Channels Base CB Radio
We can order them Power cables. We have a few antennas instock or can order what you need. with the lowest prices around.
Dec 25, 2010 | Cobra 200 GTL DX 4-Channels Base CB Radio
Gtl dx will not transmit below 26.955
First off, the 200 GTL DX is a 10 meter radio. Running it on 11 meters (CB) is illegal, as it is not FCC type accepted. If you go below 26.965 mhz, you are outside of the 11 meter band, and operating illegally.12 meters does not start until 24.930, so ultimately, the freq's between 24.930 and 26.965 mhz are restricted even to a licensed amateur radio operator.
Jul 09, 2009 | Cobra Radio Communications
Cobra set up
Hello John;
You can ground both the antenna mast and the antenna. your best bet is to place an 8ft grounding rod in the ground from radio shack or local two-way radio shop. Then connect the grounding rod to your mast. You can get a polyphaser from your local two-way radio shop this will connect between your antenna and the radio. it will also be grounded to the grounding rod. This should leave you in pretty good shape.
Happy DXing
Apr 03, 2008 | Radio Communications
Cobra 200
Hello Jim. These radios do not work well with any power mic including the power echo mics because they have good modulation boards in them. But if you still want to try then check
Mar 26, 2008 | Cobra 200 GTL DX 4-Channels Base CB Radio
Talkback on a cobra 200 gtl dx
This procedure is not as simple as just cutting a wire. Note that you can possibly mess your radio up if any maintenace is not done properly. I do suggest taking your radio to a proffesional to have the talkback removed, but, if you really want to do it yourself, go to ghe following link and basically reverse what has been done.
This is the service bulletin for the addition of talkback to the Cobra 150GTL DX and the Cobra 200GTL DX.
As long as the talkback was added correctly, this can be put back origional.
If this does or does not help, please reply on here or email me at I look forward to hearing from you.
Rollin CBs
Mt. Vernon, TX
Feb 13, 2008 | Cobra 200 GTL DX 4-Channels Base CB Radio
Cobra 200 gtl dx
Could the battery be dead? Other than that, it may be a bad solder joint inside the mic.
Jan 24, 2008 | Cobra 200 GTL DX 4-Channels Base CB Radio
Cobra 200 GTL DX 4-Channels Base CB Radio Logo
163 people viewed this question
Top Cobra Radio Communications Experts
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
