Question about SanDisk Sansa E280 MP3 Player
Screen frozen Hi, my Sansa mp3 is frozen on Music Options, will not move. I tried to shut down button and everything else, nothing happens its frozened. what can i do?
  • 758 Answers
I would recommend you to go to the sandisk site to update the firmware on your device even if you have done so in the past or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Posted on Apr 03, 2008
My Sansa Fuze MP-3 player has "locked up" even though I don't have the device in the locked position. Can you help me to unlock my device?
Hi!
Seems that there is a problem with the Hold Button of the mp3 player. Please check the manual of the similar device. Hope it will help!
https://manualsbrain.com/en/manuals/120191/?page=6
Sep 15, 2017 | SanDisk Sansa Fuse MP3 Player
Sansa mp3 screen has frozen up
try reseting it. hold down the power button for15-20 seconds and release
Jan 18, 2010 | SanDisk Sansa e250 MP3 Player
My sansa clip won't play the songs I loaded on!
I've had this happen a couple of times in the last 6 months. You can get it to play again by chosing the format option from the settings menu. Of course, then you've lost everything you had loaded on to it. Download your music/audio books again and they will play.
Jul 15, 2009 | SanDisk Sansa Clip MP3 Player
Music mode screen is frozen after listening to FM radio
press the middle button and the power button for q0 seconds
Oct 11, 2008 | SanDisk Sansa e260 MP3 Player
Frozen on the Sansa Rhapsody Screen at Start Up
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Jul 26, 2008 | SanDisk Sansa e250 MP3 Player
Sansa I just got has blank screen...won't even shut off.
-Tha Mp3 Doctor
Jun 26, 2008 | SanDisk Sansa e270 MP3 Player
Frozen screen
All you reaaly have to do is let the battery run out. Then once the mp3 is dead, charge it. The screen should be unfrozen.
Jan 06, 2008 | SanDisk Sansa e250 MP3 Player
FROZEN!!! PLEASE HELP!!!
DEFRAG IN MSC! Then check, then format.
Found here, worked for me:
search: format sansa c150
www.fixya.com/support/t137630-mtp_db_mismatch_format
Jul 02, 2007 | SanDisk Sansa c150 MP3 Player
Frozen on refreshing database
-Tha Mp3 Doctor
Apr 18, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
52 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
