Question about Samsung RB2155 Bottom Freezer Refrigerator
Samsung RB1944SL looking to buy, used, runs but won't get cold. Is this something DIY Fixable? Expense?
    Novelist:
  • 161 Answers
The only way I would buy it is if You can have him unplug it and leave the door open for at least 24 hours. Then plug it in. If it stays cold the first day or so it is a defrost problem and can be cheaply fixed. You could get lucky and have it be a start relay but I wouldn't take a chance. If the compressor is running and still not cooling I wouldn't take it if he gave it to me. Freon leaks and compressors usually are not worth fixing. You don't have the training, certification, or tools to work on the sealed system. The only other solution is if there is a tech school in your area. Sometimes they will fix things as a training exercise for only the cost of parts. You usually have to deliver and pick up the fridge.
Posted on Jul 04, 2008
SOURCE:
Accidentally broke a cooling coil in refridgerator, stove, sink combo unit, now it doesnt seam to work?
Sorry but get ready to buy a new unit . none that have had ICE picks rammed thru them have been fixable we use a hair dryer on ours .
Sep 05, 2015 | Refrigerators
Cold air comes and goes
Well if you have it set to coldest position and dose that sounds like low on refrigerant
Jun 27, 2013 | Heating & Cooling
Compressor goes in and out
Sounds like low on charge or internal compressor safety.
My Kenmore Freezer, 5649215011, won't get cold
Yes it is. You probably have a bad capacitor since it probably as been outside for this long. It is subject to aging even when not in use. This should be an inexpensive job.
Feb 13, 2013 | Kenmore 5 cu. ft. / 142 liter Upright...
When I turn on the tv, it has a bright white stripe across the screen,no sound and after only a few seconds something inside clicks and the tv turns itself off.....any ideas or time for a new tv. I just...
Sir the problem of your tv is the vertical section it is fixable but you should be handy and know all the parts of electronic this vertical IC is attache to a small aluminum plate it is the heat sink, try to look for loosed or cold solder you will see this cold solder in the solder part of the PCB but be sure to unplug the unit before opening it, and also look for bulging capacitor. ekcnoel_9.jpeg
this is the cold solder or loosed solder it is much better if you use a magnifying glass to identify the cold solder. ekcnoel_11.gif
this is the picture of bulging capacitor. Or you try to contact a technician to do it for you and save you from stress good day and best regards.
Sep 19, 2011 | Samsung TXM3297HF 32" TV
Our 5 year old washer...is giving us a reading of F 11.. which in the manual says its electrical.. we really cant afford to pay sears tocome out look at it and then tell us we need a new electronic...
This is usually the MCU Motor Control Unit has failed. The board is located inside the cabinet of the machine and is easy to replace but fairly expensive. Before replacing remove each lead and carefully check for corossion or loose connections, if none found you will need to replace the motor control board. Here is a link that should help http://appliancehelponline.com/washermotorcontrolboard.html
Sep 08, 2010 | Kenmore Washing Machines
WE HAVE A SAMSUNG RHS1DBBP AMERICAN FRIDGE FREEZER BUT THE FRIDGE PAT DOES NOT GET AS COLD AS IT USE TO (THE FREEZER PART IS FINE) BUT WE HAVE NOTICED ICE AT THE BACK OF THE FRIDGE DOES IT NEED DE-FROSTING...
You need to buy a repair kit from Appliance DIY Repairs to solve the problem you're having. We had exactly the same fault on ours, and the kit from Appliance DIY Repairs sorted it out in no time.
Aug 14, 2010 | Refrigerators
I have the samsung rb1944sl with digital temp control on front. refrig on top. the frig light went out and now the thing is beeping a warning sound the frig temp has risen to 59 degree but the freeze is...
I have the same problem and here is what I have found: The door switch is bad. I removed the switch (placed a screw driver under the left side and pried it off (see page 29 of http://www.thisoldappliance.com/library/Samsung_ref.pdf for a pic))
After I disconnected the switch, It worked. I am now off to find a new switch to order.
Hope this helps some one else as your original post is almost a year after mine.
Mike
Sep 23, 2009 | Samsung Refrigerators
Samsung RB2155 Bottom Freezer Refrigerator Logo
495 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Paul
Gerry Harvey
Gerry Harvey
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
