PDF
To acquire another instruction manual go to: www.waringcommercialproducts.com ... Before using your Waring® Commercial Waffle/Waffle Cone. Maker for the first ... NOTE: The first time you use your waffle/waffle cone maker, it may have a ...
Professional. Belgian waffle maker. For your safety and continued enjoyment of this product,. always read the instruction book carefully before using. Share.
PDF
off parts, and before cleaning appliance. 6. Do not operate any ... Preheat your Waring Pro® Belgian Waffle Maker on setting #4 or ... We recommend setting #4 for Belgian waffle recipes. If you prefer ... www.waringproducts.com. Printed in ...
The most common reason for thermal fuse failure is running the iron with the top open, especially when set to a higher number (longer cycle time) and/or not flipping the iron over at the strart of a cycle.
Keep it closed except during the 10-15 seconds needed when adding the batter or removing a waffle.
Thermal fuse 240C often available on ebay 4/$2 or Amazon 10/$7-$10
Just spray the grids before each use with something like Pam, or put a thin coat of oil on them. I found it's better to spray before each waffle so it won't stick.
You are wise to be cautious. The Consumer Product Safety Commission (CPSC) needs to know about this situation, and your input, along with that of others, will be used to start an investigation.
If it is less than one year old, and you have the receipt, go to the waring site, and look up the nearest dealer for repair and bring it to them. They should be able to contact waring for you and get you a replacement.
My replacement had a silver body virsus the original black body. The shop told me they have yet had a customer repeat of this problem.
Go to the waring site, and look up the nearest dealer for repair and bring it to them. They should be able to contact waring for you and get you a replacement.
