Have computers in 2 locations 3/10 of a mile apart. need to network these computers. WiFi will not work because of trees. Ethernet is not feasible because we cannot string wire on posts. Internet? Need list of software providers or any other alternitives
    Scholar:
  • 70 Answers
If you have internet, you can connect your PC with software such as PC Anywhere. The concept is a remote desktop control, the desktop of your remote computer is right in the monitor of your computer in front of you. Means, at home you work with the computer in your office. It is not a "real" network.
There is also some other alternatives, try this one:
https://secure.logmein.com/dmcq/097/home.asp
Posted on Apr 03, 2008
    Scholar:
  • 50 Answers
Assuming you have Internet in both the locations. ..and some kind of networking setup in each location .. . get a VPN box and VPN into the other network ..to access the information
u will spend about $400 for a Cisco ASA
    Genius:
  • 1,027 Answers
Directional usb antenna may be an alternative.
link
There are other usb antennas that can work for your situation, this is just a simple solution.
What is your budget?
this other product has the wireless card attached.
I have a Samsung Blu-ray DVD player with a network in it that has Netflix etc. How do i connect it to Netflix on my computer?
If You have WiFi go into settings, go to network config. you will have options Ethernet, and WiFi! You need to set it to wifi! if you don't have wifi, then you will need an Ethernet cable hooked up to the back of player which go's to your internet modem, or router.
Jun 15, 2016 | Samsung Televison & Video
Where do i find my ssid on my router
Out of the box your SSID should be linksys
You can find your ssid and change it by logging into the router interface, and checking the wifi settings. You will have to be connected with an Ethernet cable or use a computer that is already connected to your wifi network.
Start by getting the ip address of the router:
1.Press the "windows"+"R" keys (this will open the "Run" dialog box)
2.Enter "CMD" in the Run window, and press ok
3.In the Command Prompt window enter the following command "ipconfig" and press enter
4. locate the Ethernet adapter or local area connection if using an Ethernet cable. If you are using a wifi connection, you want to locate the wireless Ethernet connection.
5.Under one of those headings you want to locate the "Default Gateway" address. It will most likely be similar to one of the following: 192.168.1.1 or 10.0.0.1
6.Open a web browser and enter the address you found under the default gateway.
7.You will get a login page for your router. Usually the login formation is as follows:
admin/admin
admin/password
admin/leave the password blank
9.Once you have logged in you want to locate the wifi/wireless menu on the page.
10.Here you will find the SSID of your wifi network
Nov 28, 2013 | Linksys Wireless-G WRT54G Router
Tag was removed with pin number for my linksys mod wrt 160nv-2
You can find your WiFi security info by logging into the router
Out of the box your SSID should be Linksys
You will have to be connected with an Ethernet cable or use a computer that is already connected to your WiFi network.
1.Open a web browser and enter 192.168.1.1
2.You will get a login page for your router. Usually the login formation is as follows:
admin/admin
3.Once you have logged in you want to locate the wireless menu on the page.
4.Here you will find the pin for your wifi network
Sep 22, 2013 | Linksys WRT160N Wireless Router
Pin number
2.You will get a login page for your router. Usually the login information is as follows:
admin/admin
Aug 24, 2013 | Linksys WAG160N Wireless Router
Apple tv linksys password
admin/admin
4.you will want to then select the wireless security menu
5.Here you will find the password for your WiFi network
Nov 23, 2012 | Linksys Computers & Internet
Does the acer aspire z5700 desktop have a built in wifi router or do i need to purchase and set up a router to enable home sharing network?
While it doesn't have a built-in router, it DOES have a wireless adapter built in. So if you were to purchase your own router (or rent one from your ISP), the computer would work fine with it.
More details on your computer here:
http://reviews.cnet.com/desktops/acer-aspire-z5700-u2102/4507-3118_7-34132723.html?tag=doormat;rnav
May 02, 2011 | Computers & Internet
Im trying to connect my ps3 to my wireless router. it has recently stopped working. is there anything i can do?
Sure! Try this:
1 Turn your network off. Modem router, computer, printers etc. turn them off.
2. Leaving the wireless router connected to the modem with an ethernet cable (modem power off) , turn your wifi router on and let it cycle up.
3. After the router is cycled up, turn power on to your modem , leaving the ethernet cable connected to the wifi router's internet port. Let the modem cycle up .
4. After this, turn on all computers, routers and etc... no particular order.
This should allow your modem to find the wifi router and direct it to your computer via wifi or ethernet..
Dec 08, 2009 | Computers & Internet
I am connecting 4 nodes through 2 switch located at 400ft distance. the data transfer is not working. 2 nodes are connected to each switch, both nodes connected to individual switch communicates with each...
Just to clarify, you have 4 computers connected to two ethernet switches. Two computers are connecteh to each ethernet switch and a network cable connecting the two ethernet switches 400ft apart.
For all the computers to communicate with each other, they all need to be in the same workgroup "name".
The cable joining the two ethernet switches need to be connected to the RJ45 UPLINK port on both the ethernet switches, and the uplink port may have a switch (the switch allows it to function as a standard RJ45 port or a RJ45 uplink port).
If there is no RJ45 uplink ports on the ethernet switches then a cross over network cable is needed to connect the ethernet switches together.
Oct 28, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
My acer extensa 5220 laptop WiFi not working; device manager shows Ethernet controller need software, "Found new hardware" notification sometimes apear
You should download a wifi card driver and install it from this location:
http://www.laptops-drivers.com/acer-notebooks/download-acer-extensa-5220-for-windows-xp.html
Jan 09, 2009 | Computers & Internet
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
