Question about Refrigerators
Refridgerator isn't keeping cold
I have a 6 year old Kenmore refridgerator that is suddenly not keeping cool. The fridge section is not keeping cool at all (the groceries all spoiled), and the freezer part is working okay (though not as cool as normal), but the ice maker (inside the freezer) is barely functioning (making one thing of ice per day, rather than filling the entire bin in a couple days). It steadily got worse over the course of about 2 weeks or so, but now the fridge section isn't cold at all (it's room temp).
What do you think the problem is? Is it fixable by a normal handy husband, or should I call a repair person? And how much do you think this repair should cost (if I hire a repair person)? Thanks!
  • 5 more comments
  • Elizard Apr 03, 2008
    There's a small # 106 and then the Model # 72102100 Ser # EL5017676 Mfg. date 12-01.
    I don't know what a compressor sounds like. I don't hear any clicks.
    The fridge sounds normal... but then again, I don't listen to my fridge on a normal basis, so I'm not quite sure what I'm listening for. I listened to it very closely and I hear a normal hum of the fridge, and I hear a slight whirl-hum on the top half (which is the freezer half).
    There is no frost inside anywhere of my freezer (there never is).
    I don't know how I would know if the freezer fan is running. Where is it located, and how would I know if it's running?
    Thanks so much! :-)
  • Elizard Apr 04, 2008
    Okay, I pulled a bunch of food out to access the back... and I found frost at the back of the freezer. What does that mean?
    I can't figure out how to get the cover off of the back part inside the freezer. I think I'd have to break it. Any ideas on how to do it? I found the manual to my fridge, but it doesn't say anything about anything technical like that.
    Alright! So is there a specific part that my DH can replace? He's very handy. And where can we order it from? Is there some sort of fix-it manual for the fridge (since the users manual doesn't seem to have anything related to the technical workings of the fridge)?
    Thank you SO much!!!
  • teenwolf May 08, 2008
    I'm having the same issue, I think! My refrigerator is not keeping food cold and the freezer is working fine. This happened just after we noticed that the freezer was a little too cold. We reduced the temp by 1 and noticed that the fridge hardly worked after. Since then we've cranked the fridge up to seven (highest setting) and still nothing, but the freezer goes on staying very cold. I have unplugged the fridge and plugged it back in, hoping it would reset and then started searching on the net for answers and found this post. To answer your questions to the original poster, I noticed frost in the freezer for the first time today. I have a freezer on the bottom model Kenmore (model # 596.75232402). Help! I'm having a party tomorrow and need to fix this right away! Thanks!
  • ExclusiveApe Oct 28, 2008
    I have an LG fridge with the same problem. THe freezer is fine, no frost, but the fridge isn't very cold.
  • mrcoffee4 Jan 29, 2009
    refridgerator doesnt get cold enough i have temp control turned all the way up to 9
    ty larry
  • robert samples May 11, 2010
    need the model number will be about 10 digits starting with 110. or something like that is the freezer fan running is there frost on the back wall of the freezer is the compressor running and do you hear a hum or a buzz and then a click
    President:
  • 1,314 Answers
Its in the freezer when you open yhe door the compressor is in the back take the cover off and see if trhe compressor is running
Posted on Apr 04, 2008
  • robert samples Apr 04, 2008
    it means you have a defrost promblem and you can fix it
    im going to help you send me an e mail at [email protected] and say kenmore fridge
SOURCE:
What is the coldest setting for a kenmore refridgerator
If your refrigerator section is not cold enough at the normal setting you may have a problem.
If you can't find enough information at the link below resubmit your question and include the model number. It should be inside the refrigerator section. It's usually on the upper right wall.
refrigerator not cooling but freezer is fine YouTube
kenmore refrigerator not cooling YouTube
Sep 07, 2014 | Refrigerators
Kenmore elite refridgerator
check to make sure door is not stuck shut... or food may be blocking door outlet (usually located upper left hand corner of fridge side
Aug 29, 2014 | Kenmore Refrigerators
Kenmore trio freezer and refridgerator not cooling
Sounds like you have a relay switch or igniter not working. If it is less than 6-8 years old, this probably,is the problem.
Feb 10, 2013 | Refrigerators
My amana fridge keeps blowing the GFI circuit
change the GFI circuit to 20 amp
Mar 30, 2017 | Refrigerators
Kenmore side by side refridgerator - freezer works very well, refridgerator not very cold, setting is on coldest set point.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 09, 2011 | Refrigerators
Kenmore Refridgerator/Freezer does not work.
check your damper vent door located between the fridge and freezer and make sure its opening up to let cold air into the fridge,also check the evaporator fan motor and make sure its operating to blow the air around the inside of the unit
May 23, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refridgerator has power but does not get cold
Can you tell me if you hear the compressor running under the refrigerator? Is fan running beneath the refrigerator? Need to get the exact Kenmore model number found when you open the fresh food section. Let me know, Sea Breeze
Mar 19, 2009 | Kenmore Refrigerators
Door ajar alarm ringing and refridgerator not cooling enough
it sounds like either a defrost problem or damper door problem it is very well worth fixxing
Dec 28, 2008 | Samsung RS2630SH Side by Side Refrigerator
Fridge does not stay cold
If the compressor is running continually, could be short of gas , or a compressor problem, ie not pumping properly,make sure it has plenty of ventilation
Dec 06, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
1,992 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
