Question about Panasonic KX-T7633 Corded Phone
FWD/DND light won't turn off on KX-T7633
FWD/DND light stays on, and can't figure out what it is or how to turn it off. Any solution please?
    Scholar:
  • 38 Answers
Depending on how your system is programmed, you should be able to turn the light off by simply pressing the FWD/DND button. Otherwise it will require you to dial a "cancel code" which also can be different on various installations. You can try *7100, but that is just one popular code.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
Posted on Oct 14, 2008
Kx-t7433 how to turn on fwd/dnd does not work
What happens when you dial 165 on the intercom? If you get voice mail, then try dialing 7104 165 # on the intercom. That sets CF-No Ans to voice mail for your set and the FWD/DND button should light solid (or not, it's a program option) or flash. If you dial 7101 it should turn on Do Not Disturb (7100 cancels). In DND, the FWD light should flash.
Once you have set these two conditions up, the FWD/DND button has 3 states, FWD, DND, and OFF.
Carl
Jul 10, 2012 | Panasonic KX-T7633 Corded Phone
I have an issue with my FWD/DND function. Until yesterday, I was able to receive "in" calls. Apparently I accidentally hit the FWD/DND button! At first I wasn't getting ANY calls (never used...
I don't know about a "user guide" but the Operating Manual would work wonders. http://www.public.carl.airpost.net/Pana/TDA/200_TDA_OM_06-121.pdf
The FWD/DND button has 3 steps of keypress, Off, FWD, DND. The idea is you press it until it stops flashing or being lit and you have nothing set. If that doesn't work, try Call FWD/DND cancel, *7100 on the intercom.
Carl
Mar 10, 2011 | Panasonic KX-T7633 Corded Phone
With the Panasonic KX-T7633 - how do you change the time on the display?
Press Program button
Dial **1234
Dial 000
Press SP Phone Button Twice
Dial Hour (00-12)
Press FWD/DND button
Dial Minutes (00-59)
Press Auto Answer button to select AM or PM
Press Autodial/Store button
Press Hold button
Sep 28, 2010 | Panasonic KX-T7633 Corded Phone
FWD/DND
The behavior of the FWD light is programmed in system options. By default, it's usually set to be solid on FWD and blink on DND.
Here's a quick cut and paste from the OM for 76xx phones.
Dial *7x0y Where x=1-3 and y=1-6 for the following conditions:
Do Not Disturb *7101 / Cancel *7100
Call Forwarding (FWD)
– Both Calls *710
– Outside Calls *711
– Intercom Calls *712
2 (All calls) + phone no. + #/
3 (Busy) + phone no. + #/
4 (No Answer) + phone no. + #/
5 (Busy/No Answer) + phone no. + #/
7 (Follow Me) + your extension no./
8 (Follow Me Cancel) + your extension no.
So, if your voice mail is 500, you would dial *7105500# to set CF B/NA for intercom and outside calls.
Carl
Sep 14, 2009 | Panasonic KX-T7633 Corded Phone
Fewer rings before voicemail...
Does your system use the FWD/DND option or is it the programming. I also need to know what kida system this is.
If it is for the TDA then you can (if you have access too)
Prog soft key below LCD ->
the press FWD/DND button ->
Down on the silver button about 3 times. Should see 53:FWD N/A Time then enter
Should see timer (sec) :xxx with your current time.
Press new time example 015 for 15 sec then press enter.
If that doesnt work let me know and I get you the other way.
Jun 16, 2009 | Panasonic KX-T7633 Corded Phone
Panasonic kx-t7633
On the intercom dial *71x1 where x is 0 for all calls, 1 for outside calls and 2 for intercom calls. *71x0 cancels, or you can just press the FWD/DND button until it goes out.
Carl
May 07, 2009 | Panasonic KX-T7633 Corded Phone
FWD/DND light is on and so is an extension light but the FWD/DND setting is off but when i check messages, i get a busy signal.
If the FWD/DND light is lit solid, the extension is in DND if it's programmed properly. You can test this by pressing the FWD button and reading the display. It will clear and press it again and it will set and tell you what it did. (if DND and FWD are both set it shows 3 states).
At the phone, press intercom and dial *710x where x=2 for all calls, 3 for busy, 4 for no answer or 5 for busy/no answer plus the extension of the voice mail plus #. Your FWD light should blink and you have now set FWD to voice mail.
Carl
Mar 12, 2009 | Panasonic KX-T7633 Corded Phone
Panasonic vb-42211 phone won't ring. How do I
1) Press PROG, follow by programming no. 50 or FWD/DND button.
2) Press ENTER or STORE, follow by selection no. 0=OFF FWD/DND, 1=ON FWD/DND.
3) Press ENTER or STORE to save the setting.
4) Press EXIT or PROG to quit setting mode.
YBC (/\)
Feb 18, 2009 | Panasonic KX-T7633 Corded Phone
Digital panasonic kx-t7633
The 7633 has a FWD/DND button. Is it blinking, lit solid or dark? It's designed to be pressed 3 times for FWD DND or OFF....It's programmed as follows, assuming that 500 is your voice mail access code:
From the intercom dial *7101. That sets DND. Dial 710x 500 # to set call forwarding where x-2 for all calls 3 for BUSY for for NO ANS 5 for BSY/NA. 7&8 are FOLOW ME commands and they have a different set of instructions ie Dial *7107 plus your extension to have calls come to the phone you're at and *7108 plus your extension to cancel it. I have never seen it used. *7100 cancels all forward and DND arrangements from your phone..
This is just hte command set for ALL CALLS. You can also set up forwarding for Outside Calls and Inside calls seperately and you can program buttons to do the forwarding.
Your Panasonic dealer has 2 manuals that you would find interesting, one is the TDA Operating Manual and the PTPM Manual. The operating manual has a complete set of programming instructions for the manager and users of TDA systems, the PTPM has a complete set of programming features that can be performed from a Panasonic 76XX display phone.
THe pdf's aren't huge and they can be sent to your email address if you provide one under the Ask Me button.
Carl
Oct 01, 2008 | Panasonic KX-T7633 Corded Phone
Panasonic KX-T7633 Corded Phone Logo
1,266 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
