Question about Acer Aspire 5100 Notebook
Putting keys back on acer 3100 laptop
Hi my daughter pulled off my backspace and enter keys. it looks like two pieces one metal that's fits into the plastic key. like a metal square piece.
how can I snap these back on I have all the pieces and actually one metal square is still attached to the keyboard base. Iam pretty handy with tools and I saw one post that they snap back on by pushing on the top and down. the snap ears look like they are at the top not in the middle.
Thank You
Joe
email: [email protected]
  • joesaw1 Apr 03, 2008
    Yes, I do have all kinds of tools at my disposal
    I need to know how to get them lined up and started to reattach them .
    Genius:
  • 3,587 Answers
Yes..this is particularly a delicate operation. do you have a magnifying glass and small pliers..
Posted on Apr 03, 2008
6ya staff
SOURCE:
Backspace key types, h key deletes nothing else works any ideas?
Try function and scroll lock at the same time the try to enter the password, if this does not reset your keyboard, remove the power and the battery for 3 minutes then turn it back on and try again.
Tony
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Apr 27, 2014 | Acer Computers & Internet
Tip
Repair ACER Keyboard
Many a times, laptop's keys fell off the keyboard or it gets damaged. Don't fret on buying a whole new keyboard when you can repair the keys yourself.
This is an installation guide to repair keys of Acer’s laptop keyboard.
You should have a key cap and 2 or more retainer clips (plastic pieces), that goes underneath the key cap.
To install the key on your laptop keyboard, start out by observing the metal plates on the keyboard.
Always be sure to look at the metal keys because they differ in every keyboard. The larger metal hooks can be at the top, bottom, right or left side. The position of the metal hooks determines the position of plastic pieces.
Here you can see that it has one large metal hook at the bottom and two metal hooks at the top.
Take the larger plastic piece and observe that it has two holes at the top corners, two sticks at the bottom and two holes in the middle. The top holes are going to go into the top metal hooks on the keyboard. The smooth part of the plastic piece faces away from the keyboard.
Take the smaller plastic piece and observe that it has two holes at the top, two sticks at the middle and a bar with larger hole at the bottom. The sticks in the middle are going to go into the middle holes of the larger plastic piece. The bottom bar is going to click onto the bottom metal hook on the keyboard. The smooth part of the plastic piece faces away from the keyboard.
Place the smaller plastic piece onto the larger plastic piece and insert its sticks to the holes of larger piece. It’s one piece now.
Insert the top plastic sticks into the top metal holes and the bottom bar into the bottom metal hook on the keyboard. Get a thin object or a blade and stretch the plastic pieces downwards to insert completely.
Take your letter key cap, put it in the middle of the plastic pieces and push down evenly from all four sides.
That's all to repair ACER keyboard key.
Source: Acer Key Repair
on Dec 17, 2009 | Computers & Internet
Which key is the enter key
Hi
Think its on the far middle right hand side downward faciing rectangle key just below the backspace key it normally has enter written on it
Mar 23, 2011 | Acer Aspire 3680 Laptop
My lap some button are not working ,like enter
Hi! The problem could be on the keyboard itself. You will have to replace the keyboard to make all the keys to function. Once replaced they'll all be back to normal. Hope this helps and have a good one!
Jul 11, 2010 | Acer Aspire 5600 Series 5630-6951 Laptop
Popped a key off my Dell Inspiron laptop keyboard by accident.
You should be able to just pop off another key from your keyboard using a flat screwdriver. Then just compare how that key looks and reassemble the plastic components and the key just snaps back on. Also you may want to check your warranty at support.dell.com under warranty status and enter your service tag. If you are under warranty dell will replace it. Also ebay dell keyboards are cheap to buy and easy to install just two screws and a simple cable. If you need more help let me know.
Nov 30, 2009 | Dell Inspiron 6400 Notebook
Acer aspire one notebook broke
you might be able to fix it by taking the battery off and popping off the keys and cleaning underneath the keys with gentle cleaner - that worked for me when i got sticky keys from orange juice; but be gentle when you take the keys off as they are on very fragile hinges and you don't want to break them...also - be sure that anything you do from here on out may void your warranty
Nov 18, 2008 | Computers & Internet
Keyboard key issue in laptop
The metal bar needs to be clipped on to the plastic shift key. Look under the plastic shift key and you can see recess where the metal bar fits. Place the shift key over these recess and push down until it clicks into place.
Jun 12, 2008 | Gateway 2520915 Keyboard
Help!!
Try pulling out adjacent keys and then put the enter key back . The smaller keys can then easily be fitted back.
Feb 06, 2008 | Compaq Presario M2000 Notebook
Acer Aspire 5100 Notebook Logo
132 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
