Drive failed to boot up next time it was turned on have tried conncting as a slave computer recognises drive but say its 138mg when its 40gig, and there is nothing showing on the drive! have tired running Seatools for windows and all the test say there are no problems with the drive. I have in stall a nerw 250gig drive (Seagate) with NTFS file system and the problem one is a Maxtor with fat file system .
  • silverend Apr 04, 2008
    the failed hard drive was set to master on my computer and was working with no problems to my knowledge nothing was changed to the system and the next time i tried to use it it tried to load windows but failed. i tried to access it from the list _ start windows in safe mode etc but it just went back to the beginning and tried to load windows again.
    i then bought a new hard drive which is a seagate 250gig and that's working OK so as i need to retrieve the data on the Maxtor 40gig drive i set it up as Slave on the same computer that it was Master on hoping that it would allow me to copy it onto the seagate drive, but it did'nt. i then tried,still with both drives installed as above to run Maxdiag which gave an error message for the Maxtor Slave drive - D20SY2 i have also tried running Seatools for windows which reports that the drive is OK.
    the Maxtor drive has a os - windows XP professional
  • silverend Feb 28, 2009
    all working ok now thanks a lot
    Sergeant:
  • 202 Answers
Hi silverend,
I have some questions and some recommendations for you...
The original problem of the system not booting might have been temporarily compounded by moving it to a different system as a secondary or slave disk. You'll want to make sure that is not an issue 1st b4 continuing w/ trouble-shooting or testing the failed disk.
(01) Is the hard disk installed in the same computer it was running in properly before?
(02) If not, was it the Master of 1st drive on the previous system - the system where it originally failed? In other words, did it contain a boot volume? (Was it the disk that the system used to boot off of?)
(03) You said the file system is FAT. Is that FAT16 or FAT32?
(04) Does the drive have an operating system on it? If so, what operating system is it?
(05) Are you sure the jumpers are set correctly for the configuration you have it in now (slaved to your master drive)?
(06) Check to see if the drive jumpers are set for LIMITED CAPACITY? (See HERE for more information regarding jumper settings on Seagate hard disks.)
(07) Are you using a MASTER/SLAVE configuration for your two hard drives or are you using CS (cable select)? If you are using CS, both drives must be jumpered to CS and the primary (MASTER) drive should be the LAST drive on the cable (at the end).
The drive may very well be, physically, fine. However, the best way to determine that is to...
1st, Ensure that the jumper settings are correct for its current configuration (slaved to your master hard disk or as a secondary CS disk on the primary EIDE controller) and...
2nd, run diagnostics on a hard disk using boot media rather than from w/in an operating system. This is a much more reliable and thorough means of testing your hard disk.
I recommend that, once you've determined that your jumper configuration are correct (for BOTH hard disks), you run Seagate's boot diagnostics (Seagate Utilities) to test the hard drive.
(07) Do you have any data that needs to be recovered off of this drive? If so, let us know and we'll help you to recover it.
(08) If not, you can use the Seatools diagnostics to write zeros to the drive effectively erasing it and along w/ any corruption. This will allow for a more thorough surface test, too as the diagnostics will test the surface while writing to it. (This is a last result, however. Particularly if you have an operating sytem, data, etc. that you'd like to preserve.)
Please, let us know if this response was helpful for you or, of course, if you have any further questions.
Thank you
BJ
Posted on Apr 03, 2008
  • B Joan Rapier
    B Joan Rapier Apr 04, 2008
    I still think you may have a jumpering problem that is compounding the issue. Here's what I recommend.
    For now, take the new Seagate and the failed Maxtor hard disks out of the picture.
    Get your system booting up properly again. Once that is done, shut down the computer to move on to the next step.
    Make sure that the cable on the Secondary IDE controller is a (known working) CS (cable select, (high density)) cable. If it is not a CS cable, replace the one there (on the Secondary IDE channel w/ a CS cable).
    Jumper the Maxtor hard disk for CS (cable select) or for "Master-without-Slave" or for "Single" or "Stand-alone". (Which options are available will depend upon your hard disk.)
    Connect the Maxtor to the connector at the END of the CS cable. (not in the middle somewhere)
    Now, boot up your computer and make sure the Maxtor hard disk is detected.
    You may need to enter your BIOS in order to change the device type for that IDE position (Secondary master) to MASS STORAGE or HARD DISK (IOW, make sure it isn't set for CD-ROM or OPTICAL disk)
    Once you've established that it is being detected (you should see that it is recognized in the BIOS), shut down your computer to proceed to the next step.
    Place the new Seagate hard disk on the Primary IDE controller in the slave position. (The Master drive should be on the connector at the end of the CS (high density) cable.) Jumper both of the drives for CS or as Master / Slave. Whichever you prefer. Just remember the appropriate positions on the cable.
    Do the same in the BIOS for the new Seagate. (If at 1st it isn't detected properly in Windows.)
    Once you've gotten the Seagate hard disk working on the Primary IDE controller and the Maxtor is at least being detected on the Secondary IDE controller, you can run data recovery software to pull data off of the Maxtor and place it on the Seagate. (We'll help you w/ this part, too.)
    Genius:
  • 1,027 Answers
Plug the drive into your pc as a slave.
  1. down load GParted live cd iso
  2. boot from cd
  3. accept default settings
  4. view the problem hard drive and note any partitions.
This will allow you to change partition sizes without losing data.
Just a thought to see your hard drive outside the Windows environment.
360 harddrive
Is this a new hard drive that you are fitting to a desktop PC?
If it is a new - empty- hard drive it will have to be formatted before you can install Windows.
If it is a hard drive that you are fitting as a slave you may be fitting it on the wrong part of the IDE data cable, or if SATA, on the wrong motherboard connector. IDE data cables have many pins and are grey and wide.
On an IDE cable you may have 3 connectors. One which fits the motherboard, and 2 connectors to fit drives. The connector FURTHEST away from the motherboard is the MASTER. The middle connector is for the slave.
On the rear of a hard drive you also have 'jumper connectors'. The location of these connectors sets the drive as either master or slave. On an IDE data cable the master drive must be at the cable end with the jumper connector set to master (or 'cable select'). The slave drive - on the middle connector - must have its jumper connector set to 'slave' (or 'cable select').
If you are using SATA, the hard drive should be set to master or slave.
However, it would appear your computer IS recognising the drive. To check, restart your computer and press the delete key as it boots up (or it may be another key ..it tells you on the start up screen which key to press to access the bios settings).
Access the bios settings and look for the disk information. It will tell you if the disk is detected and whether it is a primary master or primary slave. You can always try disconnecting your dvd drive (power off the computer first..) and fitting the hard drive in its place. Restart the computer and go into the bios settings again. Is the drive now recognised as the secondary master? It well may be just incorrect location on the cable/jumper settings/where the cable is connected to the motherboard.
If it is just a single hard drive you have and it is new, Your computer will tell you that it needs formatting before you can install an operating system or software.
If it's a second hand drive you are fitting, your computer will not boot up even if the hard drive already has Windows on it. You will have to reinstall Windows from a dvd.
If it's your existing hard drive which had been previously working ok, remove the data cable and reconnect it. It may be a 'dry joint' causing the problem. If disconnecting and reconnecting the cable on an existing hard drive does not work .. begin to suspect a failing hard drive
Jun 08, 2013 | Transcend StoreJet Computers & Internet
The computer would not boot with a 2nd IDE drive installed
Try setting the jumper on the IDE hard drive to SL (ie slave).
Mar 17, 2012 | HP (SHP) HP DC7100 CMT SRP US HP...
Maxtor D780X-6L see drive letter but not data. this is a slave drive. jumpers are set accordingly. BIOS see's it as slave. "My Computer" see's it, but although 40gig is used, I can't access the...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
Apr 20, 2011 | Maxtor Hard Drive
My computer has no problem booting up from the C:/ Drive, but when I try booting with a CD from the A:/ Drive (Windows XP Home Edition), it does not find any hard disk drives installed in my computer. ...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Dec 12, 2010 | Hitachi Travelstar 5K100 HTS541060G9SA00...
My hard drive has stopped being recognised by my computer! Please help! One day it was working fine and then the next it just completely stopped being recognised by the computer. I have tried the drive in...
that really happens when hardisk crashed..
there is nothing to do but replace it.
but wait.. I have experience that also, could not retrieve all my files in my drive. So what I did is hide it in my stock room for a couple of weeks.
Then one day when i am about to throw away the drive,I get this crazy ideas to try my hardisk again as back up drive.
I connected my drive, put the jumper in it as slave and open my computer.
At first, it reads very slowly after booting, hardly recognized the disk, but it did...
when I am in windows and started browsing the disk, it would take it some time before loading all the files.
When that happened I back up those files and save that to my master drive.
Don't lose hope It might happen to you..
I think what happen is when I hide the disk for a couple of weeks the disk itself discharge all the left volts in it.. not sure about that.
May 19, 2010 | Iomega Black Series USB 2.0 & FireWire...
Cannot boot up Inspiron 8200
Could be a tough one. Can you get into the bios ( F8  or F10 ) while booting and check if the HDD is being recognised in the first place ? If it recognises, then check for Boot sequence. I would also suggest to try the Recovery CD that came along with computer.
Feb 02, 2009 | Dell Inspiron 8200 Notebook
No booting
The problem is Operating systems are co-dependent on hardware.
If the motherboards, processors, ram, video adapters, etc don't match you would not be able to swap hard drives and expect to boot.
You could try pressing F8 on boot and try to access safemode.
If it does boot into safemode immediately it will want to reactivate windows.(because of all the hardware changes.
If it still can't boot, you may want to put the 80 gig in as slave to the 40gig and ghost the 40 gg hard drive over to the 80.
If you don't want to lose your data on the 80 gig then reboot with an xppro cd and reinstall windows in the same partition overlaying the installation on top of existing windows directory.
the new windows will have to be activated but all data will still be there.
Apr 15, 2008 | HP PSC 2210 All-In-One InkJet Printer
New Maxtor SATA drive into computer with OS on IDE drive?
try to change your master as the 300gig then secondary master 40gig then your slave 20gig. then check it to the bios
Dec 20, 2007 | IBM (02R4087) Motherboard
PC not recognising the slave drive
Assuming you set it as slave or cable select as required by the motherboard, you have to first get the bios to recognise it press F2 or Del on boot up to enter cmos and then there should be an option to auto detect drives, save settings for a re boot. When in windows, right click on my computer icon and select manage>disk management and then your drives will be listed, right click on the slave drive and select format or set as active and it will then show, but only 137GB may show depending on the bios version.
Oct 03, 2007 | Samsung (MP0804H) 80 GB Hard Drive
Hard Disk Drive
Tell me, what OS do you have?
Sep 06, 2007 | Compaq S5322CC (DT147AR) PC Desktop
Computers & Internet Logo
336 people viewed this question
David Payne
David Payne
