Question about Canon imageRUNNER 5000 Copier
IR5000 Service Mode
After going into service mode and clearing out all of the Department IDs, the screen to enter a department ID and password is still popping up (and there aren't any ID numbers). But now we are unable to hit the Additional Functions button (*) to get back into service mode, or to even just add new Department IDs, which is what we really want to do. Does anyone have any suggestions beyond turning on/off the machine? I am having the same problem on the IR5000. When I power on the unit the Department ID Screen shows up. It does not allow me to use the additional function button when in this mode.
Any ideas on how to clear this out altogether?
  • jeff heightchew
    jeff heightchew May 11, 2010
    hello chris,
    I am puzzled.You say that you are not able to get into service mode? Please forgive me for asking but you do understand the difference between service mode, additional functions mode, and management mode.And that once you are in department ID mode and have cleared all the valid ID'S the machine is still in that mode and therefore you cant use the machine, which is where it sounds you are. I can think of no possible reason you should not be able to get into service mode, it is a fail safe. Service mode being * 28 *. Now realize that if the machine is in dept id mode, and there is a management password the copier will "seem" to not recognize the the asterisk(*) but it will respond if you follow the complete service mode sequence. So, press * 28 * and enter service mode. Then go to "copier>function>clear. At this point you can either press 'pwd-clr" which will get rid off the administrators password or you can do the "full Monty" and do an MMI clear which will blow out everything a user may have set up or changed. I keep looking at the first sentence of your inquiry which says you went into service mode to clear out the dept ID'S. That is where the misunderstanding lies. The only way you could have done that in service mode is to have performed an MMI clear.In which case you would not have posted your question. I by no means am trying to be a turd, I hope I dont sound that way.I just want to help. Good luck and let me know if I can help further. :-)...........................SPINAL
Call usa cannon and ask for the help desk...they will walk you thru this
Posted on May 30, 2008
How to enter service mode of canon ir2270
) Go into Service Mode by hitting [Additional Functions-2 and 8-Additional Functions]
2) Select [COPIERicon1.png]
3) Select [FUNCTION] (One of the buttons across the top of the LCD)
4) Select [CLEAR]
5) Scroll to screen two of the LCD using the Right arrow key.
6) Select [PWD-CLR]
7) Hit [OK]
8) Hit the RESET button twice in order to return to the Main LCD Screen.
This will turn off the Department ID Management feature on the machine (without deleting the configured Department IDs and Passwords) and will clear out (delete) the System Manager ID and Password.
This is the information plus additional if you need some extra service features.
Apr 29, 2014 | Office Equipment & Supplies
I have mistakenly pressed some keys and locked my canon ir2200 and i am now asked to enter my department id and password
enter service mode:
press asterix key *
press 2
press 8
press asterix key *
Should do the trick!
Hope that helps!
Jul 17, 2011 | Canon imageRUNNER 2200
Machine is asking Department ID and password what is this pls send me answer in mail
enter the service mode ( * 2 8 * >copier>function> clear>password>ok).it will clear the password and will not ask again.
Jan 14, 2011 | Canon imageRUNNER 6000 Copier
I would like to Reset/Retrieve Password for Copier Setup Canon, ImageRunner canon ir 2318
If you know the password, then under user mode, i think system sett., must be option for department id management where you can change passwords.
If you dont have pass, you can do clear all under service mode ( * 2 8 * ) if canon changed service mode, like on some series, you can try MENU and #.
Hope that helped
Jun 29, 2010 | Canon imageRUNNER 2200
I forgot my password
If it is the system manager password, the one for the web management site, you will need to have a dealer or technician reset that in service mode.
If you are talking about your department ID code, you will need to talk to the person who manages those IDs.
If you are talking about a mailbox password, you should have your system manager reset your mailbox.
Apr 26, 2009 | Canon NP 6050 Copier
Installed new department code access without any department codes
If you can get into service mode...try COPIER, FUNCTION, CLEAR THEN CHOOSE PWD-CLR, awitch off then on.
Mar 23, 2009 | Canon ImageRUNNER 330s Copier
Admin password for Canon ir2270 MFC
Mar 17, 2009 | Canon Office Equipment & Supplies
IR5000 Service Mode
you may need to clear the passwords. what happens when you hit the Additional Functions button?
Mar 19, 2008 | Canon imageRUNNER 5000 Copier
Startup Password
Press *, 2&8 (at same time), then * again to enter service mode. Select FUNCTION from the icons along the top of the screen. Press Clear and find PWD-CLR. Press PWD-CLR and press ok. Press RESET (yellow button) twice to exit service mode. Password should be removed.
Jun 14, 2007 | Canon CLC 1150 Color Copier
Canon imageRUNNER 5000 Copier Logo
745 people viewed this question
old marine
old marine
